I've seen brand new watches that don't look as good as that. Very impressive.
As to the size of the parts, they are a real challenge on some of these tiny ladies movements.
You really need a microscope to inspect things like jewel holes (or at least, I do). The opportunity to loose something vital is also much higher.
I have a  Citizen Crystron Quartz in the todo pile. I've got the service manual, and also had a quick inspection of it. It has some really tiny bits, and I have no donor if anything vanishes.  Always a bit of a worry.
Thanks Andy, I did use an old binocular microscope that my sister gave to me, it was being thrown out from a school where she worked at. Good look with your Citizen Crystron, no idea what they are but will look it up now, interesting name.
They are Citizen's early quartz watches.
This is the one I'm working on.
Today, just for a change I thought I'd give you a little bit of a miniature treat in the form of a 7''' 21600 Chaika 1601A Sekonda.
This movement is absolutely tiny, and the balance is so fragile that every time I picked it up I was sure I had probably done it a damage. But no,  it survived my somewhat clumsy cleaning and servicing and seems to be none the worse, and indeed much the better for it.
It was gummed up, had a very strong perfume odour and wouldn't wind when it came in a while back, and I had put it aside when I looked at the other recent Sekondas. It also had a missing crown, but the stem was still intact.
However it was too clean and new looking to simply put back in the junk pile, so I decided to risk servicing it, a task not for the faint hearted I might add.
This is a "zero coffee before you start" watch, as the slightest shake of the tweezers will send one of those tiny screws off in to the 5th dimension.
It cleaned up almost like new, the perfume smell has entirely gone, it has a new crown and I'm pretty happy with the performance. -15 to +20 sec/day and a swing of a little over 300 degrees, which I would say is pretty acceptable for a tiny movement like this.
This little thing was effectively free with a bunch of other stuff, so add in say 10p for the crown from my stash and ignore my time spent servicing it and it easily qualifies to join a number of other similar ladies watches in the 404 club.
Edited by AndyHull
http://d1v6dnm22vfd7d.cloudfront.net/monthly_2020_10/image.thumb.png.63b248df889b1ab9e43bf9b6569eadb2.png
I had a little trouble with that link, so here is what it links to, just to save confusion. Nice watch though.
BTW  what happened to the "paste image from URL" option that used to be on the bottom of the WRT editor?
Thanks, I still haven't found an OEM bracelet. They're like hens teeth and usually very worn/loose. That is just a £10 no name interim.
I tried posting the usual way in Tapatalk by clicking the IMG button and inserting that URL but all it did was post the bare link. Not sure what's going on.
A Luch 2356 based Sekonda probably from around 1984 today.
I thought it would be a 2356 from the ebay pictures, and I wasn't disappointed. It looks a whole lot better after a clean polish and service and of course once I ditched the hair puller band it came with.
Edited by AndyHull
Ingersoll pin lever with exactly zero jewels, since the "shock protection" appears to be one of those strange plastic jobs.
It arrived stone dead and fully wound, and I was a little suspicious that the balance might be kaput.
The balance however was fine, so I didn't mess with it, as I'm not convinced that those things wont faint at the fist whiff of any form of solvent, and never wake up again.
Instead it got a quick teardown, some hand cleaning and re-assembly, a spot of the horse liniment witches brew to loosen its aching pivots, a light dial and hand cleaning session and a scrub and polish of the case and crystal.
The strap stitching almost matches the second hand, and it actually looks very presentable, and indeed very readable too.
One of my first watches as a teenager was an Ingersoll, bought by my parents for a birthday.
I kept telling them it would not work and Dad wore it for a few days and it never missed a beat. Still wouldn't work on my wrist though
Figured I'd kill two birds with one stone. This thread needs a weekday bump and I need to attempt to post a photo. This pre-Invicta Glycine Combat 6 has replaced my G-Shock GW7900B as my EDC with the exception of days where I have to roll up the sleeves and get dirty.
On 11/24/2020 at 9:53 AM, AndyHull said:
Very nice. Is that a midnight blue dial or black? Hard to tell from the picture.
Thank you. It is the black dial. I'm not sure why the photo turned up so dark here. It's much brighter on my phone.
On 3/22/2019 at 10:37 PM, AndyHull said:
Today I'm road testing the black dialed Citizen Eagle 7 - 21 jewel automatic I cleaned up yesterday.
It has had a hard life, and has a plethora of battle scars, but is still keeping good time. The sapphire crystal responded quite well to the long tedious process of polishing out the worst of the scratches.
I will probably eventually replace the crystal, but it was a worth while test of my polishing skills as this one was about as bad as they get.
Best I can tell it is from September '93 - which at 25 years old, makes it a relative youngster in the 404 club.
AndyHull it is a beauty.
Did you ever get around to change the crystal?
I have the same model land would like to put in the crystal as the  old was lost... in an unfortunate accident of me trying to replace it.
Nope. I stuck with the one that is in it. From memory, Cousins have a suitable crystal. It was a pretty common size as I recall. I would go with a sapphire one if you want it to really enhance the look.
Its Big 'Q' Timex Thursday today.
This 404 club watch is most probably late seventies or perhaps early eighties.
Either way it is not far shy of forty years old  and still going strong.
It wasn't a particularly cheap watch in its day, retailing for around £34.95  GBP which equates to about £157.00 today.
Edited by AndyHull
Really like the Q at 12, very distinctive and bold.
Thanks. It took a few attempts to get the catchlights the way I wanted them in that picture.
I didn't want to break out any special lighting, so they are both done with the camera hand held and with just the table lamp next to the sofa and the main light in the living room.
They are perhaps not as sharp as they might be, but I think the softness works with the warm tones. I also managed to ruin about a dozen shots with random whiskers from my hairy arms and some distracting reflections.
You wouldn't think taking a decent shot of a wristwatch could be so tricky. Maybe I should start a separate thread on how not to take pictures of watches, I'm rapidly becoming an expert in how not to do it.
Likewise, this is one of my favourites?
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
