Looks like this watch will be my first vitim....
Don't think of it as victim, rather a patient that needs a doctor's touch. B)  I could see in the pic that your primary winding wheel screw has been used a bit more than normal. (often an indication it had been over torqued at some point in time) Probably wouldn't hurt to capture each step of disassembly with photos, in case you are called away from your "victim". Good luck and if you get stuck with something, just ask, someone should be able to help.
Molnija 3602? An improved SSSR variant of a 15 jewel Cortebert 616. Good choice, I think. Solid movements, affordable and still plentiful. Quite a few sites and videos about them too, Molnija is quite popular.
Another bonus is that one can imagine working on a vintage Rolex movement in a Panerai while rebuilding it, as mentioned Corteberts were used by them... :)
Good Luck ... I am new too... What I did my first time was take just a few components off and put it back together , then the next attempt go a little deeper and put it back. It was a good exercise and built a little confidence also gets you familiar with where things go.
Also as WileyDave suggested taking photos of each step is invaluable.
Using method I described above I was able to fix a broken watch ( it was just the mainspring) my first time out. Must have been beginners luck, because it seems the more I know the more problems I am starting to have. LOL
Regards
Anthony
I saw that screw you are talking about, it doesnt look to bad in the other photos.
13 hours ago, CapMoy said:
Hey Douglas1701
Good luck !...
I'm going to do the same to this elgin and see how it goes...I will try to do the same way adioro110 did on his .
Regards...
Good deal...hope it works out good...gonna be a little while before i get started. Still waiting on stuff to arrive. Im sure this one will look brand new when you get finished with it.
Doug
It is in not working condition seller said balance is not good but I will try to take all apart clean it and see how it goes ...I do not know , if possible , how to fix it .
I will take this as a practice before servicing my working Rockford watch...
Moises
6 hours ago, Endeavor said:
Perhaps this may be of any use? http://linuxfocus.org/~guido/molnija-pocket-watch/
I just serviced one, very nice and easy to work on; great "starter";
Thanks for the post. I actually found that site a few weeks back. The one i ordered was runing a bit fast, so i adjusted the speed very slightly and I put to test with a digital stop watch to see of it was keeping time pretty good...tested it for 30 minutes and it kept up second by second untill i stopped the test. I jave check it for two days now and it remains insync with my ipad....not to bad for $45.
thanks again,
doug
That's a good price !! I guess you have seen on that website that a nearly similar, or similar, movement was used by Rolex. Can't be that bad.
The one I just serviced was very nicely polished on the back (even with blued screws), but crudely finished underneath. Money had to be saved somewhere.
Chances are yours has a good finish all around. That you received a next to "freebee" is even better as a starter. Take your time, and the first watches will be under your belt ;)
Here is a pic of the one I ordered. There is a spot at the 10:00 o'clock position...looks like some hot gold solder or something similar dripped onto the plastic dial. Im going out on a limb here...and correct me if im wrong..but from what i have read about American railroad watch accuracy, this watch keeps better time. So far its at about 2 seconds per day which from what i understand is pretty dang good.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
