Cleaning Fluids
Hi Joe, Use the same direction - from inside to otside - for both pressing out the old setting and pressing in the new one. This is the way to prevent the bush of the setting from danage. There is another option too - to replace the stone only, if a stone with the right sizes is found. By the way, the stone will break only for a reason, andĀ there is no much reasons but one, so check if the pivots of the weel are intact. -
Hello and welcome from Leeds.Ā Ask away, that's what we're here for.Ā -
Pretty sure the marks aren't standardised, each repairer having their own code. -
By HorologyHead · Posted
H Watch Repairersāis there is a āstandard formatā for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches? Ā Sometimes I can see there might be a reference to year/ month but other times am confused. Iāve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
