Cleaning Fluids
I buy these from AliExpress now, if in the UK they are extremely cheap. I shorten them first by breaking them to half length or less, and then re-sharpen them, as Nev said they are much too long for re- pivot work and can break easily. -
@Stevo2022 you are unlikely to get a response from these members as they haven’t logged in for a few years. I think you will do better starting your own thread, more people will see it. Tom
Are there no obvious notches or indents around the back? Is that just a rubber plug? Normally something like this would be to access the balance for adjustment without removing the back, but it seems in a strange position for that.
I don't think you'll get a response as @CaptCalvin hasn't been on the forum for nearly 3 years. Edit That should have been nearly 4 years.
As you've shown the crown and stem is the winding position. You then need the second hole to be able to push the crown further towards the case to screw it down.
