I was referring to the moonswatch, the plastic quartz collaboration between Swatch and Omega, that’s over £200 and I would rate seiko movements over the Swatch quartz. 😀
Tom
Sorry, didn't see the "s" 😉
Yes, for sure. Unlike the Pagani, the reviews of these moonSwatches aren't very good either .
I roam regularly a German website "Kleinanzeigen" and currently there are no less than 514 "MoonSwatches" for sale; new and second hand, but next to new. It seems that people like to get rid of them. (https://www.kleinanzeigen.de/s-moonswatch/k0)
On the Pagani I may pull the hands and re-lume them with Superluminova. I like to have the legibility in the night as good as these moon watches are during the day. Besides, good lume comes in handy too when reading the newspaper in the dark 🤣
I enjoy the affordability and style of some of the mechaquartz chronographs, but I really don't like it when one of the registers is being used as a 24-hour indicator, especially on a watch without a date function. That doesn't seem to be a very faithful homage or a useful complication. Of course, even worse are the ones where the large second hand is a normal running seconds hand, and you find upon receipt that one of the small sub-dials is used for the chronograph seconds. Or the ones where what looks like a 12-hour chrono register is just a 12-hour mirror of the hour hand...
The extreme hype around this watch was difficult to understand, but it shows that what really matters is looks and brand. Other than that, a plastic quartz watch, not making me too excited.
Hi watchie.  Spot on,   It’s what it looks like on the wrist no matter what’s in side.  Certainly looks the part  but there again so does a dollar watch untill it breaks. One for the fashionistas.  I love Omegas but this doesn’t ring my bell either.
For me, a bit of a "kinky" side step; two partially broken vintage quartz watches no less ! 🙃
They do run and the chronograph functions do work, but, from both, the small chronograph seconds recorder (1/10 sec) doesn't reset and they don't run 😬
I've found some instructions on how to reset the small seconds recorder, but it doesn't say whether the recorder hand should run, or not, after a battery change;
"Resetting the Chronograph to Zero:
If your chronograph and 1/10 seconds subdial hand are not aligned after a battery change, do not worry as this is common and easily fixed. Simply make sure the crown is in normal position (pressed in against the case), the push Button C (bottom left) twice. The second hand will move, press C again. Pull out the crown to time setting mode. Now you can adjust the two misaligned hands: Button A will advance the central second hand forward, Button B will advance the 1/10 second hand forward. Push the crown back in."
So, since both of them do have the same problem, it could be simple and the seller didn't know how to reset, or there could be more to it? Is it a coincidence that both movements do run (cal. 3510 + cal 3530) and do have the same problem ??
They added thrill is that these Citizen / Miyota 3510 movements (12 jewels ! 😲 ) are discontinued and apparently (very) hard to get (??).
Perhaps one of those: "There is a thin line between a Hero and a Zero" 😂
Anyhow, without further ado here some pictures of what should be in the post;
Edited by Endeavor
  • Like 5
On 3/2/2024 at 4:46 AM, rossjackson01 said:
Flaming heck!
Any chance of opening the back please? Would like to see the movement.
Sorry, been busy with the day job. Or rather, the hunt for one. 🙂
I order to boycott the Swiss (not really 🙂) I like to try a Seiko (6139-7100). Bit of an iconic 1970's model, nick named "the Helmet". Below sellers pictures and it seems to kinda run ...... according to the sellers watchmaker; ceased due to dried up oil and the seller didn't wanted it serviced, hence sold as defect. Case, glass & original bracelet should be in "super" condition .........
Curious what's under the hood !? 🙂
Edited by Endeavor
What I consider ebay "Paydirt" - taking the back off a watch and finding years worth of accumulation of crud around the edges, so it is as previously worn rather than someone else's failure or Frankenstein attempt they are getting shut of.
And even better when you also find an immaculate movement with no sign of rust or chewed up screws!
Another couple I think are fantastic old ones, from an ebay job lot (under £2 each).
They both look like they have been worn to death, with little plating left.
The "Claridge" one (upper) has the date 1922 (or 23) scratched in the back, and the Ingersoll has 2/48/FW in the back. (Is that when it was sold, or serviced)?
The movement in the Claridge looks like it was a reasonably high end one at the time, from the finish? It's also got quite a fancy dial. That one tries to run, but is very sticky.
The Ingersoll is only a pin escapement type, but it's still going strong with good amplitude!
Edited by rjenkinsgb
  • Like 5
I was searching around for a Lord Matic or King Seiko, so of course I bought a Bulova Sea King. 1972, allegedly running.
Not into the bracelet, but definitely feeling the case and dial.
Nice! I'm a sucker for these. This is one from the "President" line and should have an 11AOACB with a quickset date. Now you have to collect them all 🙂
I already have a President "P" and "A", so I'm on my way 😁
Speaking of Presidents, I happened to be wearing one when this guy arrived in the mail. It looks even better in person.
Unfortunately the quickset doesn't work, and it clearly has the wrong crystal glued in, but for the price I paid I'm happy to fix that.
Casio MDV106G-1AV Gold DURO200
I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable.
Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them.
Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀
The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
  • Like 7
I just broke my Rule #1 - Do not buy a watch unless you can see a good pic of the movement.
I currently don't have anything to work on (itchy fingers) and as I just got this for £20 from ebay, (sold as "working"), I thought it was worth the gamble.
I liked the look of it, It has 21 jewels, so I'm assuming automatic. The back says "Incabloc" and "waterproof", so it looks to be reasonable quality. The case looks good.
From the little I've found on google, the Credos Lugran company was formed in 1954., and bought by Bucherer in the 60s. This looks 50s-60s to me. There's a reference to using good quality ETA movements. I hope so.
Edited by mikepilk
12 minutes ago, RichardHarris123 said:
Let us know what's inside.
I can't wait to see. I'm hoping for something good. I just hope it's not one of those bleeping FHF 96, as in the Mumbai Specials 🤣
Well it's arrived, and it's a pleasant surprise. A 11.5''' 21 jewel FHF 72. It's running (just) and looks in great condition.  It needs a good service, and new crown and strap.
It's a front loader but doesn't have a split stem. There's a small lever (visible when you remover the bezel), which when moved, frees the stem and the movement from the case (a new one on me).
Edited by mikepilk
The 73 was my setting lever make Mike, same piece fitted to your 72. I enjoyed working on the movement, fair quality.
73 wasn't front loading,but a tight spacer ring that i had to fit onto the movement before casing up. I had to adjust endshake on the third wheel  so apart from the make everthing else was good.
Much like @mikepilk, I took a chance on a movement-unseen Citizen Square Custom. If I did my serial decoding right, it should be vintage 1969.
Some discoloration of the dial, but otherwise looks to be in nice shape with the original bracelet. There's a video that shows it running and the price was right, so fingers crossed.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
