7 minutes ago, JohnR725 said:
Not working usually means better price. This allows us that can fix watches to pick up things cheaply or hopefully cheaply.
I've no idea where an old Fortis with a Venus 180 are going for, but for $40 I thought it would a nice little project. The movement look pretty undisturbed and I've seen a new balance staff, if that's the problem, for a tenner 😉
Edited by Endeavor
On 6/2/2023 at 10:28 AM, AndyHull said:
Another little bit of  a gamble. This is a "Catorex" pocket watch. The brand appears to have produced mainly midrange or high quality watches, with a fair few having Unitas UT 6310 or similar quality movements. I have no idea what is in this, but then again, that is reflected in the price. It may be white gold, it may be made of old soup cans. Time will tell.
Neither made from gold, nor baked bean cans, it showed up today and is a very attractive, high quality, very well made,  Peseux 320 based stainless steel cased little watch.
As the "least expensive Catorex on the web", it was certainly worth the gamble. I would guess it is from the sixties or early seventies, as it has a fixed stud, rather than the later moveable one.
I'll post pictured once I have it cleaned and serviced.
Here are a couple of teasers just in case I forget to post the finished result.
Edited by AndyHull
  • Like 6
On 6/4/2023 at 6:07 PM, HectorLooi said:
You should have held off buying the platform first because the symptoms described might be due to other things. Like insufficient depth of engagement between the contrate wheel and escape wheel pinion.
Broken balance staff pivot, downwards tilted pallet fork jewel failing to lock the escape-wheel, broken pivot on bottom escape wheel pinion and some damage to the tops of the contrite-wheel teeth (which are hopefully repairable).
For the rest; perfect and very nice ! No real wear and I'm the first one in since the clock left the factory 😉
Edited by Endeavor
An attractive movement. The graining on plates gives it a retro modern look consistent with the case and dial…
Sounds exactly like mine. Most likely due to the clock falling off the wall hook.
I managed to reshape the teeth of the contrate wheel with the blade of a screwdriver that was reshaped to fit the space between the teeth.
But you can get a replacement wheel from the same seller in Ukraine.
Picked up this rare Seiko LM dual time for $30, non runner but certainly worth restoration.
Powered by 5619A, its a good grade Seiko movement, will be a  nice addition to my collection.
Thanks for the tip ! 😉
This is one I've been chasing around eBay for a while. It's so perfectly 70s weird.
Bidding didn't go as high as I expected, so here's hoping it's not a scam! As far as I can tell it looks correct. No pictures of the movement, but the seller seems reputable so I took a chance.
Winging its way across the pond from the UK, so we'll know in a couple weeks.
 image.thumb.png.ebb71f5b260e5720f95f7e7c2f28403a.pngimage.thumb.png.5b7b9c0ec095c382f10c504f7229a002.png
  • Like 5
2 hours ago, oldhippy said:
Why the hell would anyone want that ugly looking watch.
Hi OH,  The Spaceman audacieuse is a much sought after piece. Its futuristic designe by Andre Lemarquand resembles a helmet that the spaceman is suppose have on when he visits us.
They also come in square case, boys, gents and ladies.
Usually an AS 2060 or variant of it beats inside.
Starp are impossible to find, as it is the first part to wear out.
I think I have about fifteen pieces and some parts, movement and case parts.
I agree though its sure is ugly.
10 hours ago, rehajm said:
Oh man, that watch 60s-space-show rocks!! Did you also order the shiny onesie to complete the ensemble, Dr Smith???
Haha Lost in space was one of my favourite Sunday morning re runs in the 80s along with Land of the Giants.
There was a guy on Ebay selling new old stock Tressa Lux versions of the Space for around 100 quid a couple of years ago.
Spot on Joe, i found the nos seller not the Tressa version.
56 minutes ago, oldhippy said:
I have every episode of  Lost in space
Danger Will Robinson!
The NETFLIX re-make that was recently made was very well done.
Because some of us don't think it's ugly at all and chose to spend money on it? Just guessing here.
19 hours ago, RichardHarris123 said:
Fibreglass back?
Sure is.
Turns out I already had one in my closet.
I still see a lot of them around, especially out of Brooklyn, NY. They're mostly the brown dial and strap and not as much fun as this one.
This was the one I originally (and still) wanted, but almost all of them come out of Pakistan and look like exactly the same photos, so I'm hesitant to test my luck there.
Edit: also quite a bit more expensive in general. E.g. image.png.df1c37f6f311b262b50ea568100a41fa.png
Edited by ManSkirtBrew
Sure is.
 Some back plate on these are aluminm some SS, either case you want to see the back plates before you buy as some aluminum ones are badly worn.
Eyup watch peeps. Just arrived in the mail this morning.  A Smiths Astral  Natonal 15 in reasonable condition,this was my focus for buying the job lot. A 70s Sekonda , the others Rone, Sabro,Emka and Mentor. All running but 3 of the dials a bit rough, the Emka looks like someone has used tongs and a hammer to remove the dial so beyond any real improvement. Shame as the movement is a nice FHF. Not 404s but the way inflation is in the UK at the moment they are certainly within our inflation increase of the last 2 year at just under a tenner each.
Edited by Neverenoughwatches
Come on, @Neverenoughwatches, you know we want photos.
1 hour ago, broccolini said:
I got this neat Caravelle with a display back for $7.
I have the same Caravelle. Mine doesn't have a display back though and it has a different movement. I paid $8 for mine 🙂
A couple of pocket watches are on their way.
The first is a cylinder movement, which I would guess is possibly from the 1950s, maybe a little earlier.
The second is a Ruhla - East German pin lever, probably from the 1960s.
Both are non runners, but they look to be complete. They both also look filthy and in need of a service, a thorough clean and a crystal.
    • My profile photo is age 20, last century, but I still look exactly the same so I'm not sure it counts ¯\_(ツ)_/¯
    • Hello everyone my name is Tom and I and I am new to the forum and new to the hobby. I have always had an interest in mechanical watches and finally decided to pursue it. I’m going thru online trading and have purchased the basic tools to set up a work area. I’m really looking forward to learning and thank you in advance for all of your knowledge!
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
