Thank you kindly. I am sorry for the stupid questions. As I go along I discover things and realize the questions I asked are stupid. Can you point me to a page that describes how to set the scope up for the first time because I am not sure what any of these knobs do and I am having trouble because the object appears to be out of focus and dark in the lenses. Again....thank you kindly for your patience.
Best bet is to check out the original instruction manual
  • 3 months later...
Hello all
Recently I have been interested in getting a microscope for better jewel inspection and to give me the ability for photos. Any recommendations for models / makes? Thanks in advance.
You will need a Binocular Microscope. I have one over my lathe for pivot/balance staff work & one on my bench to look at jewels/Shock springs etc. To take pics see link below. PS. I have never tried the method suggested below but will give it a try myself (when time !!)
The microscope  over my lathe is a Bausch & Lomb & the one on my bench is an Olympus. Both purchased used from a guy (Macombe) who runs company called
http://pennyfarthingtools.co.uk
http://www.instructables.com/id/Take-digital-photos-through-a-microscope-without-a/
The magnification is OK but how good are the optics !!. This is why I chose Bausch & Lomb & the Olympus. They are not cheap but I think the quality of the optics is important.
Agreed but how about type? I am seeing zoom models in the 3.5x-40x range. Is that sufficient. I agree with the glass quality. All my rifle scopes are Leupold or Vortex top line. I am in the states so I would rather not buy from your buddy. There are good places to buy in New York. Was just looking for recommended features and configurations.
I'm trying to specify one myself, although it will be a bit of time before I pull the trigger. I've been looking here -
Amscope
And am looking at something sort of like this -
7X-45X Trinocular
But specifically,
A trinocular head with the simul-focus feature. Allows eyepiece and camera use at the same time.
Double arm boom stand allows flexibility.
Extend the magnification with 0.5 and 2.0 barlow lenses, which mount on the objective (the nose, not the eyepieces) to give a total of 3.5X-90X, although not all at the same time.
Probably an LED ring light.
Some other things I still need to decide on, but I'm also curious if I'm heading in the right direction.
Maybe this will help you narrow down amongst the billions of choices. By the way, this setup is generally known as an industrial inspection microscope, and is most commonly used in the electronics industry, but also for engraving and I'm hoping watchmaking.
Good luck!
Amscope
7X-45X Trinocular
But specifically,
Good luck!
Awesome info. Exactly what I was looking for. Thank you!
Yep, very close to what I'm looking at. Pilar instead of boom stand, no simul-focus, but you save a bunch of money that way.
Does simul-focus have to do with the individual eyepieces or the camera port?
I was originally looking for a boom microscope, but I want to save on money and space.
Sent from my XT1064 using Tapatalk
Amscope
7X-45X Trinocular
But specifically,
Good luck!
I have this exact model stereo microscope ,...It's big , so you need the room , and the pedestal alone weighs 22 lbs .  I like it except for a couple of things .
1,] When you use the camera , you lose use of one the the bi-nocular eyepieces .
2.] My computer is an Apple and the software I downloaded for it is limited . I can't take video shots with it . Having said that , I think I will contact customer service at Amscope again to see if they have a software I can use for video . Downloads are free .
Other than that it works fine . I got it to work on Accutrons and its fine for that . I want to get a Barlow lens to give me more working room under the lens . I particularly like the LED light ring , the fact that it's on a boom so I can pull it in for use as needed , there is a course and fine focus adjustment , and the actual microscope head is very adjustable for heights and angles .
I got mine new on ebay for $400 from a seller that described it incorrectly and used the wrong pictures from the Amscope website .  I thought I was getting a single boom , but the one that arrived had a double boom and a few more features than described .
Edited by ricardopalamino
I use an Amscope with an LED ring and its more than adequate. Cost was right $600 which i thought was a bargain when compared to others. Yes, optics are important, all of my loupes are B&L but I found the microscopes had a more limited field of view than the amscope.
I was told by Amscope that simul-focus allows you to use both eyepieces and the camera port at the same time, otherwise it's either eyepieces or camera and you have to re-focus when you switch.
Cheers!
Looking for recommendations on a microscope that would be good to use in watchmaking.  I would prefer one with a boom rather than the traditional one so I can have lots of room to work under magnification.  Also would like a stereo microscope.
Hello Douglas,
there was a thread about this some time ago and it led on to me buying my stereo microscope which is especially essential if you work on Accutrons as well as being useful on other watches.
I have a lot of other magnification-devices such as loupes and a visor as my sight is not what it used to be but the Microscope was a luxury that I am pleased I treated myself to.  It is a lower end scope but perfect for what I wanted.
http://www.watchrepairtalk.com/topic/337-brunels-entry-level-bm1-long-arm-microscope-review/
There are other threads as well but people have chipped in with their thoughts and it gives you a few ideas.  My Brunel mag is up to 75x and there is still enough room to get at the watch. There are attachments available for cameras and measuring but I have not ventured into those spheres.
Cheers,
Vic
Edited by Vich
Hi Douglas,
I had the same kind of need and I got a Basch and Lomb stereozoom4 on a boomstand off of EBay. This came in at about $150 all told, but you can get then for less if you are not fussy about the stand. The boomstand is very stable and gives me no trouble at all. You need to watch for the shipping charge which can be steep as the stand is heavy.
These come with a zoom of 0.7-3x and with the 10x WF eyepieces gives me variable magnification of 7x to 30x. it also allows about 4" of work height underneath it.
At the same time I also got the 0.5x objective auxiliary lens which, somewhat counter intuitively, makes the magnification less strong, but increases the working height to about 6" this is shown in the photo with a ring light (low cost - off ebay as well)
My eyesight is not the best so for me a stereo microscope is now essential. Having a real close look at the jewels/hairspring operation are the pivots seated correctly etc really helps. I have an olympus scope on my workbench much the same as "waterboy" that I can swing out of the way when not needed.
in the good old film days.  you would just slide in a " camera microscope adapter". to one of the objectives. i  would also like to know how to do it with a didital camera.   let us know what you find out.  vinn
I think that you can just get an adaptor that takes the place of one of the eyepieces. I've never used one though. in this vintage it would be 23.2mm diameter (I think)which is a standard.
the downside is that you would need to remove one eyepiece to use the camera, but on mine this is trivial.
A quick scan of Amazon shows that they are available at a variety of prices.
i believe that adapter is for a "vintage"  film camera like Nikon.Leica.Canon or Contax.  many of these "labratory "  had a prysm to also  look down that eye pieces,  yet again for  film cameras.  vinn
    • HI everyone Some context: I'm "in love" with old Timex. As someone who has always liked watches, I knew Timex (my first watch and another project) but, in fact, the brand had never really caught my attention. By pure chance I bought, in a set of two others watches, a small m24 that was sold as not working (run and stop), which actually started working by setting the date by manually moving the hands (15 days). This coincidence made me interested in its history, its reputation, simplicity/complexity of the movements and also because some were made in Portugal back in 70’s and 80’s. A few days later I found this beautiful 1975 Viscount, m33 (very low price, almost offered) and this is where I need your help.  It is in very good condition and works well (-20s per day is not a problem for me), and although the day of the week changes correctly, the date is "stuck" on the 10th. I live in a small town that only has one watchmaker and when I purchased this watch (and having read about these movements) I thought that since it was something theoretically "simple" (probably not related to the movement), he would easily solve the problem. I couldn't be more wrong. It was as if I had proposed a pact with the devil. He refused and said he wouldn't touch the watch (although he had serviced several of my watches before - Seikos and old Swiss brands). He suggested I wear the watch like this or trash it. As I mentioned in my presentation to the forum, I have some experience in digital watches, but in manual watches I am a complete beginner. I know how to remove hands, crowns and little else. I've been doing my homework, reading the technical manual and watching a few videos on YouTube. I think I can get to the part of removing the dial without any major problems. I know that in the Date Frame there is a wheel that at the top has a tab that activates the Day Wheel and that at the bottom activates the Date Lever My aim is to try not to ruin anything and  get the date working again. The help I needed (I intend to post photos) is that what should I expect? What are the most common problems that cause this system to get stuck (in this case just the date).   PS -  My secondary objective is to buy a strap at a overpriced value from the watchmaker just to rub it in his face that I managed to get the watch working properly. PS2 - In the photos you can see that before midnight the day of the week is already changing but the day of the month has not changed.   Sorry about the english. Best Regards Vasco
    • What is it from and how did it become bent ? It should bend back - I would heat it whilst bending
    • Ha, same here. I just looked and I've lots of pictures of my cars, be hardly any of me - I have a face better suited for radio. I did find this from about 20+ years ago. I'm the young looking one at the back, under the front nozzle.
    • I have a 6564 with me what is take a same tropic 12 crystal,most likely have the same parameters for the bezel. Do you need the measurement for that?
