I feel a conversion coming on. I purchased a set of these from China ages ago and don't use them very often. Like Colin says,mother optics are excellent.
Hi, I had problems adapting an ordinary Olympus stereo scope for watch work.
Rather than buying a genuine boom which would cost a fortune I manufactured one using an old retort stand from the science dept.
I was still left with the problem of tipping over, even though the base was cast iron. I ended up filling the base with lead which is easily melted into th base. Finally filled the odd holes with resin ( car bodywork filler ) and ground it flat.
It is now stable and works a treat.
I will post photos if anyone is interested. Mike
Hi Guys, this is my first post on this forum after reading almost everything for a couple of weeks and seen all Mark's video's (great input).
I am quiet new to service mechanical watches, done some purchases on tools.
Still waiting for a great part of my order from a Dutch company, one thing I didn't order yet are magnifying glasses.
French company deliver much faster as my Horotec screwdrivers delivered right on time.
As I have some problems with sight, I wear glasses (-6) and one eye has a scar right in the middle of my sight (sorry I don't know how to explain for I am Dutch) I have no focus on my right eye. Just no focus, everything around is okay, just the middle is blurry. Normally day use no problems as the eye and mind compensate for it.
Positive thing, I have great closeup look without magnification needed, left eye only that is.
But for magnification I have a question, I have great comfort reading computer monitor, has someone combined magnification with computer monitor like digital microscope?
It is not very expensive i think, like the http://www.carson.com/microscopes/digital-microscopes/1476-mm-840 but U have to work from computer screen instead of  the real time movement.
Any thoughts or recommendations?
Thanks,
Welcome to the forum Forester. I think you might be better getting an Optivisor with 2.5x to 3.5x magnification. You could always cover one lens if required. A 10x loupe would also be required for lubricating the escapement.
The electronic unit that you mention is listed as having magnification of 75x/300x which is far too powerful for watch repairing.
Hi forester & welcome. I to suffer with terrible eyesight, however as Geo suggests the digital microscope you mentioned would be far from suitable for the job in hand. I currently use an optivisor for normal work & a conventional zoom microscope for inspection. The 0.5 Barlow lense on my microscope gives 3.5 to 45x zoom. At 45x zoom I'm literally looking at specs of dust etc.. Also, I've tried looking at a monitor whilst working on a movement & for the life of me my hand eye coordination would not function that way.
Sent from my GT-I9505 using Tapatalk
Thanks all,
The 75x zoom in my example is somehow overrated I think.
I think the actual zoom level is much smaller.
There are models, much more expensive, with larger (longer) working area.
One of my expectations was the hand eye coordination would be difficult as you are not looking direct at the object, so I'm glad DJT2 has some experience with this and confirm it is hard to work with.
So I think I go with the Optivisor to start with.
I like to have something i can look at the jewels with? If there properly oiled or worn in some way or the other. Looking at pivots for example .
Have a Bergeon x12 . But i think it's to difficult to see anything in . Had a nice old  tv lens for the camera that i turned upside down . It worked okey but was difficult to take pictures and then put them in the computer to look at them . In normal i use a Bergeon 2
I've been patiently waiting for this baby to show up .  I took Vics suggestion to get a stereo microscope to work on Accutrons . It's from Amscope , 7X x 45X , mounted on a boom , LED light ring , and has a 1.3 MP camera that comes with it .
  I've never used one so I hope this one works good .
where are the pictures taken with the 1.3Mpx camera?
:D
I've been patiently waiting for this baby to show up . I haven'y received it yet . I think it will be here today . I'll post some when I set it up .
I'm still fiddling with adjustments , software downloads for the camera , and the space for it...it's kinda big with the trinocular head , double boom , and camera . I think I might get the reduction Barlow lens that will give me a bit more room under the lens .....but as I said , I still learning how to use it .
BTW , the microscope I ended up receiving is an upgrade from the pics I posted with the double boom . And I don't believe the software allows video capture , only snapshots , although the live camera shots are active video .
Amscope has a lot of videos on YouTube , and so far their customer service has been great with questions .
Edited by ricardopalamino
Hi Ricardo, it's definitely worth getting the 0.5x reduction lense which should give you 3.5 to 45x magnification. I got a similar microscope of Aliexpress, probably similar to the amscope model you received. 2302f9a1c185e63a7d176b46137ca837.jpg it's a trinocular like yours and has simul-focal. I purchased a 5mp hdmi camera to go with it. The problem I found was the camera was always out of focus to the subject I was viewing. I had to constantly adjust the zoom to take images/video. After purchasing 3 different cmount reduction adapters 1/3, 1/2, 1/5 ce2c85648bf6a172122e5cd92a88ae69.jpgI realised if I used the 0.5x cmount adapter, then placed a 3mm spacer between the camera & adapter it worked a charm.
5MP TV HDMI USB Industry Digital C-mount Microscope Camera TF Video Recoder DVR,lens for microscope camera
http://www.aliexpress.com/item/5MP-TV-HDMI-USB-Industry-Digital-C-mount-Microscope-Camera-TF-Video-Recoder-DVR-lens-for/1836066761.html
Really is fantastic, I particularly like the fact I can just put a memory card in & it doesn't have to be connected to the computer. I do have it connected to a monitor via hdmi to review images etc. But I'd definitely recommend it.
All this gear looks terrific. I am looking forward to some photo's of little bits of accutrons etc.
The Brunel scope I have is the same as the one Lee has, in fact he helped me with info for the purchase that meant I got a good deal. The only extra I bought was two 20x wide field eye pieces that bring my magnification up to 75x which is ok for me.
I think I will leave the photography side to those who know what they are doing and stick to snaps with my camera and devices, it looks like too much brainwork for a lazy git like me.
Cheers,
Vic
Cheers,
Vic
Howzit Vic , I'm on a vacation right now , but when I get home I'll post some Accutron pics . I was amazed at a pic of the index mechanism with the teeth on the index wheel visible , the small misalignment of the pawl jewel , and the pile of debris at the end of the index jewels .
The best bargain around
I have a similar unit  I was able after some trial and error to find a LED bulb that worked.  I found that rather than a single bulb I found a bayonet bulb that has 5 led's in it that work very well and stays cool.   I use my loupe up to 10 x then for 20 x and more I use the scope.  I have a video but its too big to upload   I paid $175.00 USD for mine a few years back from the listing attached group.    One on my best investments
Thanks all
Jim
I know this is going to sound lame   but I have no experience with youtube   :pulling-hair-out:    I will need to have my son the youtube genius assist me.  It might take a bit.
Sincerely,
Jim
A friend just helped me   remember this is me trying to hold my phone camera over one lens   20x    The unit goes up to 40x    came with two sets of lenses  10x and 20 x   with two view ports 1x and 2 x
I thought it was a great deal for 175.00  USD
Sincerely,
jim
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
