Pallet fork lubrication: pallets and pivots.
As I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing. -
By Hawaiikook808 · Posted
Thanks again, Marc. Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts? Mahalo. Frank -
I think it should be the other way round, thanks to you.
