Screwdrivers dressing
1 minute ago, jguitron said:
Looks great!!!
Can you show a pic 90 degrees to the one you took?
I couldn’t open the vid. Maybe a Tapatalk issue?
Hi Jguitron,
Sure, here you go, I didn't sharpen like a knife, the tip will be too fragile.
Darak
Hi Jguitron,
Lansky is known for its easy sharpening system, it’s not challenging at all to sharpen either a screwdriver bit or knife with this kit and I can reproduce the results consistently, you can see the video that I post, I can view the video via the phone, just need to wait, or view it on a PC.
The screwdrivers that I fixed today are 0.6, 0.8, 1.0, 1.2 mm, all come out beautifully, but I need to say, using the Lansky kit are more fiddly, you need to take out the bit from the handle, fix it on the Lansky jig and sharpen it, versus a screwdriver sharpening kit(sharpening stone and screwdriver roller), but the Lansky kit comes with a lot of different stones of your choice and you can sharpen your knife with it.
For my use, because I’m just a hobbies, I don't need to sharpen my screwdriver that often, so the Lansky works great for me, if this hobby become more serious, means need to sharpen them every day, I might buy a professional screwdriver sharpening set, with a lot of different stones.
Darak
I'm not familiar with the tool you are using, but it looks like it is giving good results.
Screwdrivers are more forgiving than knives with shapening, to sharpen my screwdreivers I purchased a 240 grit and 400 grit diamond sharpening plate off ebay for just $3 or $4 each and have one an A&F spring loaded screwdriver holder for sharpening and find that gives me pretty good results.
The most important thing is using your Loupe to check you have inserted the screwdriver correctly before sharpening.
Also if you are removing a chip on the blade you will normally have to hold the blade at 90 degrees to the diamond plate and take a small amount off the end so they screwdriver blade once sharpened to ensure it doesn't bottom out in the screw.
  miniture screw drivers can be nicely "by eye".   it is not "an art",  but the result of a machinest's  apprentiship.   twist drills can aso sharpened "by eye".  i will admit the small ones can be dificult ---- practice.   vin
I tend to just use my "metric calibrated eye",  ;) and of course files/fine grit paper.
You can use one of these, If your eye requires a little more precise calibration.
https://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=2.5mm+metal+Watch+Screwdriver+Sharpener+Sharpen+Watchmaker+Repair&_sop=15
They do work, but you will still end up finishing by hand/eye with good magnification, and obviously they only work with straight blades, so not much use for drill sharpening or cross headed drivers.
19 hours ago, Darak said:
My nice Bergeon screwdriver set was chipped after few watch services,
I recall a fairly recent topic which where some was saying that Bergeon screwdriver had become worse and worse with time. We got the proof here.
Sharpening is a science and an industry. Trivia facts follow
Drill_Point_Geometry_nt.pdf
Edited by jdm
  • 3 months later...
In school we uses this one, also to make hollow blades on a screw driver.
https://www.beco-technic.com/werkzeuge-verbrauchsartikel/schraubendreher/zubehoer-fuer-schraubendreher/schleifwerkzeug-fuer-schraubendreherklingen/schleifwerkzeug-profi-fuer-schraubendreherklingen.html
But is very expansive.
This one is cheaper, but don't know if you can use it on al screwdrivers from the Bergeon set, because it only have 3 holders.
https://www.cousinsuk.com/product/screwdriver-sharpener-tool-horotec
But this is wat you really need:
Edited by Koen
On 10/3/2018 at 2:57 PM, Tmuir said:
Hollow ground screwdrivers are really only of use if you work on the same model of watch all the time.
The reason is if your flat ground screwdriver is too thin you just stone a tiny bit off the end to make it fatter.
On a hollow ground screwdriver you need to remove a lot more material to make it fatter, and then hollow grind it again to suit the screw you want to undo, so its harder to swap between brands of watches that you need to adjust your screwdrivers for.
If you worked as an 'in house' watch repairer of an expensive brand of watches, and always did the same movements then hollow ground is the best, but for most of us that works on what ever watch comes our way the flat ground is best being a compromise between time taken to reshape screwedrivers and the risk to 'chewing' screws.
I agree. From what I know, The British Horological Institute and watchmaker schools in the Netherlands teach to work on watches with flat ground screwdrivers.
Hollow ground is useful for screws made of a softer metal such as gold and convex screws that you sometimes see in older watches and also sometimes used as case screws.
Well because with hollow screwdrivers, you have more grip the teacher say ( Omega service center ) and les chance to slip away or to damage screws...
You don't want to damage movements, especially now with open case backs. But thats what we learn the first lesson, I am only the pianist. ;-)
See above the good postings by Tmuir and measuretwice. Parallel blades drivers aren't given that much importance, for whatever the right and wrong reasons. Good that you are being exposed to comparison at school so you can base your own judgment, I want to do the same.
Edited by jdm
What is a hollow screwdriver?
Sent from my GT-N5110 using Tapatalk
I also find it odd to immediately have everyone's screwdrivers hollowed.
A friend of mine is also an Omega certified watchmaker but has never used a parallel blade in his life. The same goes for Anthony from NoBSwatchmaker, who's certified for Rolex, Breitling, JLC, and Omega.
No doubt that parallel blades are useful in some cases but it sounds like a personal thing from the teacher.
*edit The great George Daniels was also all about flat ground screwdrivers.
Edited by Nutiborskoku
Like I say, I am only the pianist.
But hey every body will have there thought about something... Only time will tell my experience... but for now I am a rookie and just follow the pack. ;-)
But I can understand the point that hollow blades fit better in the screws and so you wont damage them.
Again, what is a hollow blade
Quite normal in watchmaking schools, one have to do a lot of filing and tool making before undertaking actual horology subjects.
Good for building dexterity and machinist skills but really there is whole lot more than that to make, at least, a good repairer.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
