I've been asked by a friend to look at his Seiko 7019 - 7060 which is running ridiculously fast.
Never worked on one of these so am unsure about stripping it down.
The main symptom which I can see is the balance wheel is only moving a total of about 90 deg, hence the fast running.
Any ideas would be welcome as to what is wrong with it.
Also does anyone know where I can obtain Seiko diagrams etc.
Many thanks in advance, Mike
As in the most of times if no one tinkered with the hairspring , the hair spring can be either Dirty or Magnetized. In rare cases the hair spring have become slightly deformed.
Fast running with poor amplitude, the first thing I look at is the hair spring. Most common causes are;
coils sticking together due to magnetism. Easy solution - demagnetize.
coils sticking together due to stray oil. Easy solution - clean.
coils fouling the underside of the balance cock, or the balance wheel spokes, or the hair spring stud. Not so easy as this usually means a damaged or deformed H/S.
Hi   diagrams can be found at cousins uk  Gleave and co and the Seiko site they are one of the brands with freely avaiable tech sheets. As regards the fault advice already give is prime.
clean the hairspring first. remove the whole balance assembly and dip it in brake cleaner from the auto parts store that you have sprayed into a small bowl.
Remove the movement, observe the HS from the side, as balance wheel oscillates so you can see the fault, which can be any of above said.
Or, you may could tilt the movement inside the case, balance side outward. So you can observe the HS.
Check regulator pin, only one HS strand should be held by it.
I'd try demagnetising first. Damping the spring (e.g. with Rodico or inside a poly bag) stops it vibrating in harmony with the A/C field. This is something I just learned on a different thread.
I'm curious or confused. Can we have a link please? Thanks
If the watch is new to your friend he needs to be aware that these Seikos need to be shaken quite a bit to build some power. That is the main disadvantage of not being able to be hand-wound.
If the watch has been working well before then the above posts covers the main problem areas.
Cheers!
Anilv
Hi Mike does your friend play golf, if so does he wear the watch I have had a couple where the
balance spring hooks up on the regulator due to impact hitting the ball and causing a shock through the wrist  shortening the spring and running very fast . Just a thought
Yes, sorry for being so vague. I was talking about the hairspring.
The gist is, if you allow flexible components to vibrate in harmony wíth the magnetic field, the demagnetising effect is reduced or non-existent. Obvious really, but never occurred to me until I read the thread. If the balance and hairspring are out of the movement wrapping them in tissue paper is recommended (by Fried). If the movement is complete, demagnetising whilst it is running apparently works best.
    • Does your parts list actually have the description as mine just shows the parts. Is 1520 the gear that sits in the auto bridge to couple to the barrel. You could try letting the power down and then remove the idler gear between the 2 barrels and see how it winds then. I presume you're doing all this at the moment without the auto bridge in place.
    • I love my brass tweezers and use them for 90% of my work. I like that brass is soft and does not scratch parts and it seems to grip parts better than stainless steel. And brass is also non-magnetic, which really helps when working on quartz movements. However, brass is a little too weak for jobs like pulling back yoke springs. So I thought of upgrading to bronze. But I can't seem to find curved bronze tweezers. And Cousins price for a pair of Bergeon straight bronze tweezers is around £45. A couple of months back I had the idea of swapping out the carbon fibre tips of my tweezers and putting in bronze tips. And that is what I did. I got a piece of 2.0mm bronze sheet from AliExpress and cut out 2 curved tips and replaced the carbon fibre tips. I'll probably thin down the tip further gradually to a point where it still has strength to draw back thick yoke springs.
    • Ah, well that's a relief, though the parts document does list a 1520 which is a coupling clutch. This threw me for a while (it's a quiet day in the office) until I realised I couldn't see a listing for the reverser wheels. So, we're back to the mainspring should slip in the barrel. It can really only be one of three things (that I'm aware of) mainspring 'coned' and pressing slightly on the lid the kink, close to the  end of the spring, which puts a sort of a self lock grip on the spring and may not allow the spring to release enough there to allow slipping quantity of lubrication, either not enough, or too little Two of those require new mainsprings, which aren't readily available, though I may post a query about alternative mainspring sizes. The third, will more grease or less be required? The word breaking in breaking grease suggests more means more breaking?
    • The idler gear I'm referring too is the one between the 2 barrel wheels. These movements just rely on the spring slipping to prevent over winding.
    • Not sure how useful this might be, but a while back I bought some bamboo tweezers (multipack with a ridiculous amount of them in) and have been using them in place of pegwood. Seems to be working just fine
