Bestfit Catalogues
Maybe me that not as good on computers? But where do i click. Says download here at a lot of places. Don't want to download any virus or trojan . Do i need a special program to download these? What is Mega Movie search? should i download that?
Edited by rogart63
I'm starting again.
Anyone who would like a copy of the Bestfit Catalogues Vol 1 and 2
You will need this pasword to open each volume. tickandtock
Links
https://www58.zippyshare.com/v/BGNuxKTX/file.html
https://www105.zippyshare.com/v/xrUeOPSy/file.html
Thanks for sharing but this zip site is full of cookies and apps that are a huge security risk. Any way you can share a Dropbox location with a password. This is much better and safe. Thanks.
Sent from my GT-N5110 using Tapatalk
I went for the orange box that says “Download Now” and my iPad hasn’t exploded yet. If you click on any of the Russian pictures then bad things are likley to happen to you :startle:
P.S. Thanks OH - are you sure these are free to distribute?
Here are two new links. I bought both so they are mine.
 https://www.mediafire.com/file/mz809lm3bms8zk3/bestfit_part1.pdf/file
https://www.mediafire.com/file/eqbhdor949r0ilp/bestfit_part2.pdf/file
Sorry I didn't know zippy was now full of crap. If you have adblocker you might need to disable it for mediafire. These are safe I have tested them.
  • Like 7
Thank I will try a bit later
That worked perfect. Thanks OH .
  • 4 months later...
  • 8 months later...
On 6/1/2019 at 12:58 PM, FrankLancs said:
Thanks For Sharing, Just downloaded Great for what i need right now.
But would love to get hold of a hard copies, Anyone selling a spare set?
Sorry I'm late too to thank OH for that.
On the matter of printing I'd recommend against that, not only you would save a 1,000 pages, but you would lose the search function that is on the very first page - use a full featured PDF reader for that,
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
