Recommendation For Watchmaker Lathe
bobm12
I have a Star lathe & over the years I have gradually built a nice collection of collets & tools. All are used but work just fine.
The hardest part when making parts using a watchmakers lathe is not the make of lathe but the skills required to use one. My brother in law purchased a Chinese lathe a few years ago & he produces excellent work from it.
Clockboy,
That is well said.  The important thing is that the lathe is set up and properly adjusted to do the job. Earlier today I watched a video on this forum showing a Dremel tool wired down to a bench and a piece of angle iron used as a T-Rest. He then proceeded to make a watch stem out of a nail. After more than 30 years in manufacturing as a tool and die maker, CNC programmer,   machine designer  and automation circuit engineer, I have to say that this video rocked my world. I could not have dreamed what I saw in that video; hats off to that guy.
david
JDM,
Turns are an early form of lathe that utilizes  two dead centers instead of  a rotating headstock. The piece to be turned is secured to a driving dog that is engaged to a pulley with a pin. As the pulley is turned the pin pushes against the driving dog and rotates the part. A Jacot tool is really a specialized form of turnes. The pulley can be driven by a bow, handwheel or motor. The advantage of turning this way is that rotating the part around dead centers is extremely accurate. The disadvantage is that the work has to be rotated very slowly. Using this method the part can be removed from the lathe, measured and repositioned with almost no loss of accuracy.
There is a Steffen Pahlow video on Youtube called TURNING BETWEEN CENTERS ON A LATHE that shows a part being turned on a set of turns.
david
Fafal,
I have only seen pictures of a Cowells Lathe. They are beautiful looking machines but seem to be very expensive and are not radially available in the USA.
Here is a picture of a Derbyshire Instrument Lathe from Tony Lathes:
Image result for cowells lathe
The bottom picture is a Cowells Lathe.
david
Cowells model you posted above is ME which is made for metal engineering, they have another model for watchmakers - CW 90 (I think) There is a website where are offered used ones, but mostly ME type:
http://www.myford-lathes.com/other_lathes.htm
Its from UK so it may be a problem for those on other side of big pond. But prices are more acceptable... Those are great lathes, I hope maybe I will get one of them :)
Edited by Rafal
Rafal,
Those are nice looking machines. From the pictures the ME and CW models seem to be similar except for the chucking components. One of the pictures shows an IME Lathe. IMEs are among the finest watchmaker lathes ever produced. The good news is most people don't know about them and they can be purchased for a reasonable price.
front view ime watchmakers  lathe for sale
david
  • 11 months later...
  • 2 years later...
Lathe experts, would you mind giving me some help? Do you think this is a good buy?
https://www.ebay.co.uk/itm/Bergeon-8-mm-lathe-with-original-accesories-motor-table-and-other-Parts/324012283798?hash=item4b70a31796:g:FiQAAOSw29Zd9Ie3#viTabs_0
Buying a used lathe seems to be an absolute minefield. There are so many makes and so much available second hand!
I want to be able to make my own parts like pivots and balance staffs. I already have a great Jacot Tool for finishing. But now I'd really like a great watchmaker's lathe that I know I can find accessories for. I do like Burgeon products but I'm a sucker for expensive brands. I guess that's how I became interested in watches in the first place. :unsure:
Although this listing doesn't have much info, it also doesn't have too many disclaimers! It's advertised as perfect working condition! So I should be able to lean on my eBay buyer protection if it turns out to be a lemon.
    a trained machinist  serves a 4 year aprentistship.     if you want to specialize on watch lathes,  look for a book "using a watch makers lathe."   or  repair a used lathe.  vin
39 minutes ago, Tmuir said:
Yes seems too expensive to me and does not come with many collets.
Collets are expensive you want to get as big a set as possible when you buy the lathe else you could end up spending as much again on collets
     yes,  proper set of collets are essential.   what about the difference of MM or SAE  measurement and thread pitches ?    vin
You need to check out German ebay, prices are far easier on the pocket,
This seems about right for  a almost complete boxed lathe
https://www.ebay.co.uk/itm/ALTES-UHRMACHER-WERKZEUGE-LORCH-DREHBANK-DREHSTUHL-8-MM/383425549061?hash=item5945f19305:g:IXIAAOSwsCdeSqdv
Factor in shipping and customs, also ask question about condition, I have used this seller before with no problems
UHRMACHER DREHBANK  (watchmakers Lathe )is a good search phrase to use on German ebay.
19 minutes ago, clockboy said:
Looks a bit pricey. Also a personal presence this, for me no tip over rest. When cutting a balance etc the tip over makes life so much easier. If your based in the UK then this company are always worth looking at for tools/lathes etc. https://pennyfarthingtools.co.uk
Thanks for this. I am in the UK and didn’t know about these guys. Great tip. There is some interesting stuff listed. How about this? It looks pretty comprehensive.
https://pennyfarthingtools.co.uk/pultra-1750-10mm-bench-lathe/2020/02/07/
33 minutes ago, nickelsilver said:
The Bergeon is definitely too expensive. The Lorch above looks great, but it's a reversed lathe; the Germans sometimes liked working with the headstock on the right. The lathe itself can be oriented as you like, but the cross slide can't be reversed.
How much of an issue do you think this is? Is it a deal breaker? I don’t want to train myself on something that is totally non-standard.  But that set does look great.
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
