Funny mishap
I thought I would share my latest mishap. I was repairing a quartz (Ronda 715) which had a faulty date change. The fault was traced to a mis shaped date jumper spring. So I had to make another. I was checking it's size etc. and moved in close to get a closer look & PING straight into my mouth.
I did not swallow & it did clean it up a bit I suppose. :D
  • Like 7
I was working on Seiko 7t32 chrono and low and behold one of the subdial hands turns up missing, I thought it was a goner and well the usual angst ensued, bench cleaning, cursing and the like, but upon exiting the WC, (two days later), I happened to catch something shiny in the rug, well the picture says it all....Luckily it wasn't damaged, wish I had the good fortune to use my mouth to catch such elusive parts!DSCF0437.JPG
I know this feeling...oh...yes, I do... I have more than a few MIA watch sweep hands that went flying somewhere in the room.
“Improvise, Adapt and Overcome!”
 Clint Eastwood, Heartbreak Ridge
On 27 January 2017 at 8:00 AM, Watchtime said:
in this room you can always find everything you drop....:D
Unless it is white ?
I was going to respond with a phrase using the words "spit" and "swallow" but I am afraid George or another admin would have to censor it -
either way it was a good catch.
Cheers
Vic
Was working on exactly the same movement today, following an excellent walk through which one of the member posted here.  I got right to the last operation - inserting the date ring detent spring,  and "click"..........   Unfortunately I must have swallowed this one as no sign of it after hunting the lino floor for an hour. :)   I guess I will have to make something up.
Oh come on!  The chances of two such two similar events occuring under the same circumstances  is a bit hard to swallow....:D
LOL, very witty noirrac.   My movement is the Ronda 715 LI, which is the same but has a plastic full diameter adaptor to take a larger, 10 year battery.   I had another look for the spring today, swept the floor clean, but no sign any where.  How does one go about making a replacement?  Is the special wire available on a reel or do I just reshape from another similar spring?
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
