Hi, Levine:
I could be wrong but my understanding is that there is a piece in the staking kit for punching out the balance staff as well as a piece for re-establishing the rivet once the new staff is in place. I have watched this same procedure done by a couple of different folks on YT and apparently the toughest part is getting the hairspring, et a,l dismounted to remove the broken balance staff.
Time is a craftsman's finest tool, so use as much as you like.
Best Wishes,
Bruce
Anybody ever seen a staking set like this?i got it on eBay. But I’ve looked and looked and never seen this sort. It has five kind of long stumps and 15 or 20 long stakes and also about 10 shorter stakes. No makers name anywhere either I noticed that someone has numbered a few and the rest are just plain. Any input is appreciated.B6AFC254-8EBA-4E61-8B99-5F8FA5C701EB.thumb.jpeg.b185935e25d5a82f693b2867eb0a9002.jpegE5C17EAE-0713-482A-B4A0-26259CC88BE9.thumb.jpeg.51198e9da8412ce566de59f362f3f884.jpeg7AC31CBD-BA9A-493E-927A-BD35AC21595C.thumb.jpeg.876205261fc1477ae6b5c91fac2c2c33.jpeg
I think K&D is the best staking tool, it has so many functions. Luckily I got a set from a retiree.
In addition, I also record some brands, maybe some mistakes, because they are too much.
*(K&D )Kendrick & Davis
West Lake Metalix
C & E MARSHALL
Levin
Vigor
Paramount
G&F
F.R
*Boley
Leinen
Lorch Schmidt
Henry Paulson
Helios
Georg Jacob K. G. Leipzig
Manhora
MKS
GEM
Mascot
FAVORITE
*Bergeon
Horia
*STAR
Seitz
*ESSER
Pearl
GESCo
DRACIP
Bayside
F.LORCH
Add to that, F.lli Bonelli, Italy. But my set is smaller than that
  • 3 months later...
Does anyone know if staking sets generally came with a reamer spindle for reaming/broaching holes? I have never seen a 4.7mm reamer spindle which could hold reamers/broaches for jewels.
P1080640.thumb.JPG.8172ecd3d67f96523f1ab4b722523d8f.JPGP1080641.thumb.JPG.bdfa0b5d0ab26e3950829a0731fe1f17.JPGI
I have one. I have to be honest I can't remember where it came from and it is totally unmarked so I can't tell you much about it. It has a tapered hole that accepts the Seitz reamers, is 4.7mm diameter, and fits my MKS staking frame perfectly. So they do exist.
That looks very useful. Unfortunately, it seems to be quite hard to find! Especially one that fits the Seitz reamers.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
  • 3 months later...
That piece looks like the broach that is part of a set of 4.7mm end mill pivot cutters, like the Bergeon 30007...which Bergeon claims comes with 15 interchangeable pivotal strawberries in hard metal  😀...
https://www.bergeon.swiss/09-polissage-abrasifs-affutage-limes-manches-outils-de-coupe/outils-de-coupe/fraise-a-pivot-pivot/assortiment-de-15-fraises-a-pivots-interchangeables-en-metal-dur.html
Edited by rehajm
Exactly that is it.
B. also sells a 4.7mm broach with 3 small collets for small drills.
Frank
1 hour ago, praezis said:
Exactly that is it.
Frank
Curiously enough I have one of those too....
But....
the "strawberry" cutter (top) doesn't fit the carrier (bottom), and the reamer (bottom) doesn't fit the top carrier; they are not interchangeable.
I also have only 1 cutter as well 😐
... and there is a 3rd type of 4,7mm holder, also from a broaching set. It takes straight shanks and holds them with a screw, like screw driver blades.
Frank
21 minutes ago, watchweasol said:
Hi LWS   thats one nifty set up   was it one of your Dads.
Yes it was. I do not recall him setting it up on the lathe though.  He had four staking sets and this was one of them.  I set it up on one of my lathes to try it out and it works, but I have never used it on an actual project.
I made a post about it with pictures here.
Edited by LittleWatchShop
  • 2 months later...
Hey boyos. This is 100 bucks on the bay right now. I saw love for g-boley staking sets in the thread but they usually had numbers and i don't see a number for this one. I'm legit not even sure what you do with a staking set as i'm only doing basic services but i am almost certainly going to horology school at this point and i know it's something i'll need. Vintage Boley from a watchmakers estate. There's stakes missing but i'm assuming you can fill in the gaps as you need to. You guys think should i go for it? It looks in good condition and also like something you could probably club a rock to death with and it would still work fine.
Edited by Birbdad
Thats a nice set with the base to reverse the stakes. If its a buy it now then grab it quick. If its up for bids then likely it will 3 x that.
Yikes given the fact i will need a staking set eventually what should my ceiling be on it you think 300 or so?  It is sadly not a buy it now.
EDIT: Bid 200 on it. I see staking sets coming up in random watch repair vids usually involving balance staffs. I should probably start watching vids on them.
Edited by Birbdad
4 minutes ago, Birbdad said:
Yikes given the fact i will need a staking set eventually what should my ceiling be on it you think?
Affraid I'm  no expert on staking sets or their value. I have a Star that was mostly complete that came in at a good price of around £80. But i was very very lucky and here in the UK the price is usually higher than USA.The Boley I'm sure is much better quality than mine. If i  personally was looking again and saw a complete set in good condition, i would be wanting to stop at around £300 but I'm also tight.
Well if i get it and it sucks i'm holding you personally responsible haha
So what do you typically use your staking set for?
Edited by Birbdad
I got a Chinese set for about $100 and have used it a few times and very happy - so if you don't get the one on eBay this may be an option for you - check out thread Quality Chinese Tools on this forum
Haha. As far as i know the Boley is a good make but maybe not the best. If i was serious about a career in watch repair i would want the best i could get and in a complete condition.  Plenty here that can advice you much better than i can what to buy . Earlier this week i could kick myself for holding back on price with a very complete production lathe. It went for 50 more than my top bid yet i originally planned to go higher than it sold for 😢.  For starters the staking set will replace you a broken balance staff which is a common issue. I dont think there is anything else that can install one.
Used my set for closing up the hole in the barrel bridge where there is too much play in the barrel arbor/bridge. Worked a treat and really improved amplitude. Chronoglide have an excellent video tutorial (look up 'hammertime' on their youtube channel) on the best way to do this with your staking set.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
