My Basic Watch Repair Tools
jdrichard
My current collection of watch repair tools. All tools have a special purpose and there are only a few duplicates, where I found a more professional tool. You basically need all these tools to repair watches. Did not include and oils or cleaning solutions. Did not include my ultrasonic cleaner or and timing tools (I use both PC and Tab Software). Did not include my Drummel tool used for case polishing .59cecdb313155f4bc4c8e6faf9767512.jpg94c9959b45c27b417334b356bc38614d.jpg
Oh, below the sleeve wrench to the right, looks like you have not one but two ! K&D balance staff removers. There getting very hard and expensive to get hold of these days. Excellent set off tools
Sent from my SM-T585 using Tapatalk
One is for watches and the other is for Pocket Watches. And they were hard to get.
Nice tool set you got. Have Jacot tool but it's probably worn or something cause the pivots never run in the groove as they should. Or if it's me  that don't now how to use it properly.
I mad a video on YouTube on how to use the Jacot tool. No way the grooves should be worn out.
A nice starter kit lol!!!
Very nice set indeed. :thumbsu:
My wife has started to notice all the tools coming in the mail over the years. She usually says "why so many?, You can't use the all at the same time". The is what she says about my guitars....don't ask how many.
Sent from my GT-N5110 using Tapatalk
I think I might give up.. I thought I only needed a bed spanner, lots of enthusiasm and a rubbish bin to put all the watch bits in!!!!
I started small years ago and every time I needed to fix something unique, another special tool was required. I still don't have a lathe or a cleaning machine. Next year.
I think jeweling tool is next for me. I already have the Jacot,  don't know why I bought that first, except that a very nice one (with a bow!) came up at a good price.
I am still looking for a bow for my jacot, however, the badge reel works very well. The jeweling tool I have used a lot. Most old pocket watches that have a bad jewel have a cracked jewel on the third wheel, lower...don't know why, perhaps the forces there are greater. So I have pressed in a few jewels. I have also pressed in jewels on a 7750 watch and a few others.
Reminds me of the adage " He who has the most toys wins ". My wife usually says when another package ( my watch tools ) comes in, " Everyday is Christmas ."
Anyway, happy for you. Keep it coming!
My wife says exactly the same.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
