Watch of Today
mk3
6 hours ago, anilv said:
The date quickset is by the button at 3 o'clock. I believe this button is a replacement...from where I don't know as it doesn't look like any pusher I've seen before.
Anil
doh! how did i miss that one? i have one just like it.
that button looks like something you'd see on an older tissot - or a junghans.
10 hours ago, oldhippy said:
If I look at anymore like this I'm going to screaming out of my home. :D
Please Amigo , don't do that . I have more but the sanity of the members of this fine forum is more important to me . I'll keep them hidden ,...even my "Dukes of Hazard " watch that plays Dixie , and my mp3 watch with over 300 songs on it ....:jig:
Edited by ricardopalamino
Okay, here's one "you won't see coming or going" (that's an old expression used by one of the jewelry store owners I worked for way back when, to describe unique). It's a 12s, two tone Hampden 325. Just a 17j and pretty plain dial, single sunk and the octo case. Just some equal time for pwatch guys.:biggrin:DSCF0371.JPGDSCF0370.JPG
On 11/6/2016 at 2:29 PM, oldhippy said:
You will still need a jeweling tool to mount the jewel properly or a staking tool. So if you have one or the other or both you don't need the above tool.
This tool pushes them out and back in.  Just make sure you choose the correct size end so that the tool only contacts the setting, not the jewel itself.  No need for a jeweling tool or staking set for jewels in settings (chatons).
Dukes of Hazard...with Dixie ...now that did it... coffee is now sprayed on my monitor in hilarity.
Well done, Ricardo, game and set on that one ...:D
Here's another alarm watch with the same Poljot movement as the previous - this time a Signal. I'm not sure of the age, but it was very well taken care of by the original owner, as the dial and case are pristine. I had to do a bit of work on this one recently, as the minute hand was about seventeen minutes off. So while I had it open, I painted the alarm set hand red to match the second hand; originally it was the same gold tone as the hour and minute hands, and was a bit confusing when checking the time. Of all the watches in my collection (not that many, actually), this is one of my favorites.
Gryf
Edited by Gryf
    • Walked by my local jeweler today and asked if I could dig around in his old watch case, and picked this guy up (along with a cool vintage compass and a Seiko kinetic5M62). My girlfriend's son asked if he could borrow one of my pocket watches for prom, so I thought if I can get this guy running it'd be a nice prom gift. Non-running. Felt like the balance was overbanked, but it turns out the train was jammed solid. Looks like it was just dried lubricant gluing the 3rd wheel in place, because it's clean as a whistle otherwise. Parts are in the ultrasonic right now.
    • Neverenoughwatches. I did read your experience with the basket. I did try to file mine to true it up..but I couldn't find the sweet spot. I figured I would just bite the bullet and get the Elma components.   Thanks Randy
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
