Here we have a bonus watch I got in a lot a few weeks ago, thought it was quite interesting since it is a SLAVA watch made in Russia for import to Sweden.
The dial shows EXACTA SLAVA 21 jewels imp. The watch is powered by the double barrel SLAVA 2414, a quite nice movement by the way.
  • Like 7
Another of my recent haul - I’m a sucker for the 70s....surprisingly it’s keeping very good time!
Its a strange feeling having a manual wind - not usually my thing, but price was good; and the seller said it just needed batteries :D
Here we go again, another 70's beaty. ENICAR MRO STAR JEWELS.
Under the hood one finds one 17 Jewels ENICAR AR 161 ripping away at 21800 A/h.
Beautiful watch, I will have to try and track one down for myself.
Cheers Steve! Got really lucky on eBay some time ago and snagged it for around £30 as it was sold as a non runner with not very flattering pictures.
Long story short a loose screw had found its way into the escapement which had resulted in it not ticking. After removal and a service it’s running great!
aaf087dc760937bf2e2bc5c590160fea.jpg&key=76aa8cf12036917d6efa03128362c300cbbd4ba20544dbe7892457bc44d8bcec
My watch of the day, just finished this as a present for my daughter's 16th this Friday. Seiko 4004 Quartz from mid 70s. The lengths I have gone to with this watch, I even had to find a case back for it as the one it came with was from another watch and stuck on with double sided tape. She will love the retro look.
Very nice 0903 based mid 1970's export quartzB).....fairly sure that the 0903 movement is Seiko's only one with a tri-lingual day wheel......
 I am quite fond of these, there again I am a bit biased as I have a 'few' 4004's......some of them below.......
Edited by JohnD
That's quite a collection. I will need to invest in better tools before I work on another one. Replacing the glass and the case back proved to be a bit of a challenge using my poor quality squeezy hand press.
I use one of these presses....
and a lot of the 4004's require the bezel assembly, with the crystal in place pushing out from inside the case as an assembly, then reassembling with the new crystal and replacing again as an assembly......I had this aluminium die made up especially for pushing the bezels out.....(the groove is to clear any projection of the stem tube inside the case)
 It is sized to fit very close to the internal case size and sit against the very small lip of the bezel assembly that protrudes inside that dia...
Thanks John, great tips there. I will have a look round for the same press. Any tips for the rubber seal around the new crystal? I did try a few things but in the end used a 0.7mm diameter o ring pressed by the glass chamfer against the inside front of the bezel.
Today's watch is my grandads old Roamer which I acquired in 1986. It had been sat in the cupboard all this time but finally I have had it repaired and serviced. It required a new main spring.  It keeps great time although I only wear it when sat in the office. I don't know its age but I do know that the movement is an MST 430.
Good everyday watch bought new c 1998.
Seems to be offered on Ebay around  $130-200
Roamer Power 8 men's
Diameter of the watch is approx. 36 mm (excluding crown) x 41.4 mm.
Originally came with webbing strap.
Victorinox Swiss Army Men's 241302 Alliance Sport Chronograph
Another black face from my practical collection. Purchased in 2014 on one of my house swapping holidays in USA.  I changed the bracelet for a leather strap. Cost at the time USD $324.
My first watch and still have it today - Tissot Sideral Automatic with fiberglass back.
Bought way back in 1971. I believe these were gold plated including bracelet. Possible Model No 821 - 44745 or 112/429 (from original receipt).
I wore it as my daily watch and it had a very hard life. Never been serviced and still works fine.
Spotted one on ebay for $456
My first 'good' watch, had it since 1968.......
Today I found out the MOERIS is a perfect counterweight on the arm when removing the balance from a dodgy AS970 balance staff.
It is a UNITAS 6498 Pocket watch conversersion which will give you the perfect swagg when walking the stripp ;) .
With little opportunity for wearing dressy watches during lockdown, I got to thinking, what would be the perfect watch for lounging about in baggy tracksuit bottoms and staring wistfully out of the window. The least refined, least glamorous piece in the collection.
In other words what is the perfect corona virus lockdown watch?
Given that I don't have to be anywhere at any given time, it doesn't even need to be accurate. It just has to fit the bill as the perfect "nobody is going to see it anyway, so it can be as daft as you like" watch.
As you can imagine, the 404 club has a few contenders for this non-accolade, but somehow this one seems to capture the mood best.
I just hope you can hear what I am typing above the sound of it ticking. :D
Edited by AndyHull
Andy Hull, wait 'till you see my old "Corona Virus lockdown watch".  First *wrist* watch that I bought with my own money.  It's the one I wear when I'm working on the van, or doing outdoor work late into the night, banging about with tools and whatnot.  It's a Walmart brand called Eagle Ridge.  It has a thick, heavy case, and a crystal that for its price has defied getting chipped or scratched somehow.  Its a beater watch that won't die.  And it does decently with accuracy, being quartz. As a bonus, it has "DiaLight"; a sort of tribute to Indiglo.
If I'm going to be *seen* with a wrist  watch I'd rather it were my Citizen or my Bulova.  But if I want to *see* the time in dark places I just wear this.
Edited by KarlvonKoln
1977 Timex Snoopy Tennis red dial. This is in a typical 1977 Marlin case, and arrived stone dead, in a fairly tatty condition on a cheap Nato style nylon band.
I remedied the "not running" issue, by giving it a good clean and some light lubrication. I then popped it on a temporary strap to keep an eye on it as it settles down after servicing.
A few things I would like to know about it.
First, did it ever have the novelty seconds hand (typically a tennis ball, but some feature "Woodstock", Snoopy's small yellow bird sidekick), or were there some produced without?
Second,  and this is a bit of a long shot, but does anybody have a stock of new old stock novelty sends hands for it? @JerseyMo  ?
Finally, what kind of strap was it originally sold with?
It also needs a high dome crystal obviously, but I have some of those.
Edited by AndyHull
I may have the hands, it would
have had a red strap. Not a "Marlin" case rather a Mercury or if the smaller size it is a Sprite.
On 7/15/2020 at 7:33 PM, HSL said:
This is an ORION powered by an Baumgartner 582 digital.
Forgive me my ignorance, but what is a "digital" calibre? I realize the telling of time is "digital" but what's underneath? A mechanical movement like any other mechanical movement?
Edited by VWatchie
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
