Maybe its me, bit I haven't seen poljot chronographs posted in this forum. Is there a reason for this? I have a near NOS and just got me for X-mas from Russia another one to restore... The Poljot 3133 is the 'copy' of the Valjoux 7734 movement, actually built with the machines Valjoux sold to Russia, a bit improved in some aspects, but rougher finishing. Any Poljot lovers out there?
I have a couple George, the big problem is getting parts if you require them.  Apart from that they're good movements.
I like those Poljots too and am hoping to add one to my collection soon.  I've had my eye out for a Zeppelin LZ 127, which isn't actually a Poljot but uses the 3133 movement.
Interestingly, I believe the 3133 is a derivative of the Valjoux 7734 which traces it's roots back to the Venus 188.
@Geo actually the parts are no problem, since here in Germany there is plenty of. The real problem is getting them at fair prices... but that's another story altogether.
@RyMoeller:  That is a very nice watch! Yes it uses the 3133 movement from Poljot which as I said in my opening post was built using the designs and machines from Valjoux, which the russians bought from the Swiss manufacturer. They did improve the design a bit, but the overall finish is rougher.
Spare parts are available in Poland, speak to Julian Kampmann as he is in touch with the Poles. Nice to see Marc posting, but why is he not working on my 3133 Poljot ?
Thanks for the info, butbhow do I get hold of the chap?
you had to go and show a zeppelin. man! i love their designs. i keep looking at these on a regular basis. it's on my (ever growing) list. i didn't know who's movement was used in this watch.
ops, I did it again.....
I just won another Poljot 3133, a Sturmanskie at that... and also this one is not working... Guess I will have plenty of work to do!
I am getting the fix on these...
Pictures from the seller are pretty good and the condition is, apparently, pretty good, judging from them. I only hope the problem is easy to resolve...
25 minutes ago, frenchie said:
Looks good... except for the hairspring that looks a little bit bent out of shape.
Yes you are right, and this is not the only issue apparently. I also noticed that the dial looks "strange"... Hope I can find pictures of an original, untouched Sturmanskie to compare.
According to some research I made and forum posts I found on watchuseek, there should be nothing bad about the dial nor the entire watch I bought. Actually, it appears to be one of the earliest models, from the first half of the 80s. On watchuseek.com I found the graph below. The Sturmanskie black and white logo, like the one I got, is no.7
I also attached another image of an identical watch, also found on the same thread over at watchuseek.com
Looking at that balance bridge screw, I don't think you will have been the first one to have been under the bridge before, it seems a bit proud but I have never worked on one of these and maybe it's meant to look like that.
Cheers, Vic
9 hours ago, Geo said:
Is that a hacking lever sitting on the top edge of the balance wheel?  If it is, no wonder it's not running.
Don't think that's a hacking lever, looks more like the rather badly deformed terminal curve of the H/S between the stud and the regulator.
Quite common damage when someone who doesn't know what they are doing plays with the regulator, moves it all the way to the fastest position so that the regulator goes beyond the dogleg to the terminal curve, then moves it back again. The dogleg gets jammed between the regulator pins ans as a result, it gets dragged round causing the H/S to buckle out between the regulator and the stud, pulling the rest of the H/S out of true and stopping the watch.
Provided it's not been too badly b*ggered it's a relatively easy fix and the watch is back to running condition.
Cheers, Vic
It does look a bit proud to me too, Vich. These pictures are the sellers, I still did not receive the watch myself, so please wait till I update this post with my findings.
5 hours ago, clockboy said:
Keep us posted George that could be a real nice watch when re-furbed.
I will, but just from the seller pictures I can spot some problems here that are beyond the service....
This is also my line of thought. I analyzed the pictures of the seller, and it does appear to be exactly like you wrote. Hope we are not both wrong on this, which seems a pretty easy fix to be honest.
As I mentioned in one of my replies, there are other issues to this watch, apart the bet HS or just the need for a nice clean and service.
Check the picture here enclosed. Is it me, or this looks like a bad redial? If so, apparently I must be more careful with my purchases, since this would be the second time....
Clearly from the pictures attached, the seconds and minutes markers ring is offset in relation to the hour markers...
    • The watch is from 1990 and was serviced just once around 20 years ago. No idea if the mainspring barrel was ever opened or changed before now.
    • Interesting but I think we have a problem here? We probably need to split hairs on a definition problem. For instance take a real Rolex movement put it in a real Rolex case but not the one it came in take a real dial real hands and make up a watch that is 100% real and what exactly is this? If you send your Rolex in for servicing and anything's been changed at all from what it was when it left the factory Rolex will be unhappy and remove all offending components. This does become a problem of people changing things because they think it's their watch and they want to have a different dial Lord diamonds the bezel or whatever words Rolex sees all of this as evil and bad as far as a Intel Rolex only things the watch is legit if everything is exactly what it was when it left the factory and nothing's been changed including the stem everything asked me Rolex original or their very unhappy about its existence. Then you think about a fake watch what is its real purpose? Well its real purpose is to make money for somebody and fool the customer. So all the watch has to do is look pleasant on the outside and inside can be anything. Typically nobody's going to see inside. So typically anything that's not legit counterfeit movement etc. why would someone spend so much time and effort making it look just like a real Rolex when there's no need to? Unless of course you have one or two movements to impress somebody with this is what's inside your watch but even that is problematic Now we don't end up with I've interesting problem that troubles me where I work. The owner will offend a cage your watch by looking at it carefully with a microscope the timing machine etc. and he will point out all the things that he feels are not appropriate correct or whatever for your watch. But in my example above of mixing and matching legitimate Rolex parts he wouldn't necessarily be able to tell. The problem I have with this is it often times things like his claim to telling a counterfeit is look at the second hand the quality of the secondhand is not as nice as a legitimate one. But maybe somebody replaced a second hand on a real Rolex. Or the other day at work I don't know what it was in before but there was a really pretty movement transparent back and they decided it was fake because of? Now I didn't think it was fake I took one look was beautifully manufactured but they had a reason What bothers me with counterfeit Rolex is or anything counterfeit watch related it is reminding me of a witchhunt. The early days of witch hunting how can we tell a which Manon which? That makes me wonder how many super fakes are really fake at all it's basically somebody deciding it's a fake based upon inappropriate assumptions. Like the secondhand is been changed or the watch was worked on the screws are perfect or other things. Other minor problems with super fakes for instance I have a long story the not going to tell the short version is I found the website once where they claim to be counterfeiting Rolex watches. They even had a picture to prove their counterfeit watch the problem with pictures online how do we know it's really a counterfeit watch and not a real Rolex watch that you're telling us is counterfeit. Oh and they had testimonials from all kinds of people who bought their watches and were very happy with the service of course the problem with the watch is you don't know what's inside it unless you take the back off and just because somebody shows a picture online and says this is their super fake maybe it really isn't a super fake they be there just trying to say that. We end up with a interesting problem of manufacturing a watch. Does Rolex actually make every single part found in their watch? Then the year 2004's basically irrelevant. This is because initially Rolex buys stock in the company and they manufacture Rolex watches. I'm assuming over time Rolex will acquire more stock and only in 2004 do they get the whole company. But the company itself hasn't really changed other than the name on the front of the building. The real question is did they really make every single component found in the Rolex watch from the beginning of time until end of the time? A lot of the components found in a watch would be extremely specialized did they make their own jewels or their own mainsprings for instance? But that is looking at the article they employ a heck of a lot of people now I would guess now that Rolex probably does make everything in-house. Especially when they have nifty CNC equipment like for making screws were he could make a huge batch of one type it instantly switch to another type where before he needed specialized machines for one machine for one screw now manufacturing all kinds of stuff in-house becomes very simple. But still is possible that in the early days they might have outsourced something may be perhaps. But conceivably we do have minor changes in thing is due to how things have been made over time which can lead to confusions over whether this is legit or not when it may be as a change of manufacturing methods oh and regarding the screws found in your Rolex watch? In about mid-80s I went to a school reunion in Switzerland. One of things we could do was visit a factory and I picked Rolex because I wanted to see the mass production making of Rolex watches. Which is very disappointed I did not get the sea at all because didn't see them making Rolex watches in their Geneva headquarters even though the building is really fake? So what did we get to see well after sales service because after all were watchmakers we should see that. Did learn something interesting about Rolex screws if your watch was sent to Rolex the screws that come back are not the ones that went there. As they are using powered screwdrivers they don't want to risk breaking heads off and they will replace the screws of every single watch. The other one of interest was suppose there's a scratch and you can see the brass? No problem they have a solution that basically electoral plates without electricity so the scratch goes away. The research Department was quite boring and didn't look like anyone was ever there. Then it was too long ago to remember all the details other than I was disappointed I want to see manufacturing.   Yes the joys of artificial intelligence that is more like a trained monkey that's there to please you.
    • Hey everybody! I just registered to WRT. I found this forum searching for informations about ELMA watch cleaning machines (will get one ELMA tomorrow ✌️). I'm new in watch repair, collecting watch repair tools to fill up my work space 😎.   Greetings from Vienna Michael
    • Is it not covered in the manual under Profix Cap Jewels?
