I have a question @Geo.
You clean the balance assembly put on the main plate and only at the end you take off the balance jewels and clean them separately.
How are you sure that you sufficiently cleaned the balance pivots. I believe hardened oil and dirt could remain on it (between it and the jewels). This is why, if I had a machine, I would wash the ballance on the main plate, but without the jewels on.
Thank you,
Bogdan
Hi Bogdan.
If it is a really dirty watch that hasn't been serviced for years I will strip the movement completely then soak all parts overnight in naphtha (lighter fuel) to soften any hard oily deposits. This includes the main plate and balance assembly as separate units. The next day I will attach the balance to the main plate complete with balance jewels and clean them in the ultrasonic tank with ammoniated cleaner at 50 degrees centigrade for five minute, then rinse as previously described. This has always given a good result, and I feel that it is due to the pivots vibrating inside the jewels which aids the cleaning process. It will have a pistoning effect that I imagine should help wash out the muck.
After this process, I remove the jewels and give them another clean in naphtha just for good measure.
I might be completely wrong with my assumption, but the process does work with great results for me. Before using this technique, I had the odd issue with jewels and residual muck.
There are some watchmakers that do recommend removing the jewels as you described, but I don't.
This really has been extremely enlightening. Think I've finally got my head round the cleaning cycles & can see where I've been going wrong. It may even shed light on some of the issues I've had in the past. Thanks guys
Sent from my SM-G920F using Tapatalk
Like George I have been getting on OK with Naptha for a while now and I use Isapropanol for the final rinse but my stuff is small scale as I don't really have a need to do anything in bulk. I do treat the pallets separately.
Cheers,
Vic
I recently bought a watch cleaning machine from a retired watchmaker, when I collected the machine the jars already contained solution, the watchmaker told me the rinse jars contained isopropanol. I did ask him what effect on the shellac holding the pallet jewels would the isopropanol have, saying I would be worried that it would dissolve. He said he had used it since Benzine had been unavailable to use, and as long as I rinsed for no more than 15min in each wash there would not be a problem. He also said it was very quick to evaporate in the drying stage and left no residue.
I have ordered new cleaning solution and rinse solution from Quadralene and intend to use these.
I have though cleaned 4 watches last week in the solutions in the machine and have not had a problem.
Today I decided to test and see how long it took to actually dissolve the shellac,
The image above shows 3 Russian and one Swiss set of pallets and the shellac can clearly be seen. I have been using the solution for 15min each rinse and have not had a problem so I put the pallets in a isopropanol rinse for 1hr  to see what effect it had
On the Russian pallets it has greatly degraded the shellac and almost totally washed it away on one, but on the Swiss pallets it has not even touched the shellac on those.
I will not use isopropanol again in a cleaning machine and intend to try a similar test with the Quadralene rinse to see how shellac friendly that is because the data sheet doesn't specify what ingredients are in it, but quadralene did tell me they have many watchmakers who buy their rinse and have not had any problems.
  • Like 5
  • Thanks 2
Great test & thanks for your sacrifice. It really does prove how in the wrong hands & without the correct information you could be left with a big problem.
Edited by jdm
Please don't include pictures in quoting
Thanks to WLS1971,
This chestnut has been discussed a lot on the forum but we now have some evidence thanks to your efforts.  Interesting how the shellac seemed to be of differing composition between Russian and Swiss.
Cheers,
Vic
I think isopropanol is safe to use if cleaning by hand for short periods, but I wouldn't use it in the machine again, the information given to me is probably correct in that 30 min exposure to isopropanol has little effect but at some point beyond that it softens the shellac, and once it's at that point it would attack it very quickly in the cleaning machine because of the constant agitation..
Why the shellac on the Swiss pallets was not effected I don't know they had exactly the same exposure as the Russian ones.
I cleaned last week a Sekonda pocket watch a Cyma pocket watch a Regency wristwatch with FHF movement and a ladies Lanco the exposure they received was 15min each rinse and there was no problem.
The only conclusion to be drawn from the test is avoid its use in a cleaning machine and don't soak or rinse beyond 30mins as a max which wouldn't happen any way if cleaning by hand unless you where distracted or forgot and left them too long.
Just to add when isopropanol dissolved the shellac on a pallet and balance impulse Jewel of mine , (mentioned above) this was 2 separate occasions and they were only in the solution for 480 seconds , the max setting on my ultrasonic cleaner.
They were Swiss movements , so whether it was a case that the vibrations from the ultrasonic loosened them or maybe the isopropanol was to pure at 99.9% I don't know , but I don't do use it anymore
That's interesting Andy, it's probably the extreme ultrasonic vibrations that exacerbated the problem. I only use it as a final rinse by dropping the parts in a jar of the stuff for about 30 seconds, I never use it in the ultrasonic bath.
Thats what i'm guessing Geo if people are using it for 15mins at a time without issue, i've still got the stuff , i'll experiment again using it as you do just as the final short rinse
Anyone have any suggestions on cleaning and rinse solutions for the L & R master cleaners? I think I want to use the Fine Wash but unsure if the rinse formula? There are two, one for ultrasonic and I suppose one is not? Any thoughts or recommendations would be great!
As always, thank you!
Gary
Hi everyone!
Another question about lubricants - is Moebius 8217 all purpose or is it used for Brass or Aluminum?
Tried to find an answer but to no avail in in of the forums.
"All purpose" is actually 9010...not sure, but I believe 8217 may be more like a grease? I don't have my reference now but that's my take on it at first "sight".
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
