Hello,
another newbie question, I know. So far, I cleaned all of the watch movement parts using the ordinary lighter fluid. My system was as follows: put all of the watch movement parts in small jars with lighter fluid, leave them for about 10 minutes (except pallet fork and balance, I took them after few minutes), clean them with a soft brush, peg the pinholes, rinse the parts again in clean lighter fluid in one bigger jar, and leave them on sheet of paper to dry.
Now, I am afraid that the lighter fluid (basically naptha) would leave some residue.
Any ideas on improving this? What cleaning solutions would you recommend for rinsing the parts, and especially for cleaning balance and pallet on budget? Isopropanol maybe, although I heard it could do harm to shellac.
On 10/13/2015 at 8:03 AM, DJT2 said:
Hi guys, I've been absent of late due to decorating to keep the wife happy. But I'd like to discuss a conversation I had with a friend who is the technical manager for a leading Swiss watch manufacturer. I asked him what he felt was the best degreaser to buy at present. He said" without question & nothing can compare, isopropanol which is available from the chemist. I was surprised to hear that they also use it in the final rinse pot during cleaning". He said you can't leave the lid off as it evaporates. He said it's ideal for the last rinse because of this fact.
Has anybody else used this product. I've just order 5ltr off amazon for £15,so pretty cheap.
Well,  In my opinion that info is not quite correct.. The best de-greaser and old oil killer by far is ACETONE !. Isopropanol is one type of  alcohol and has it`s uses no doubt. I have an unopend can here. I am a Jobber Fixer (not a qualified watchmaker) and I am not in the league of you modern chaps. I use an ultrasonic bath (40KHz) and Fast Naphtha. The balance and scape are cleaned with Acetone then rinsed with Naphtha and I brush the components as required. Do NOT use acetone on any plastic`s. Just my way of doing things and it works very well for me.
18 minutes ago, bojan1990 said:
Is it advisable to clean hairspring and pallet fork with benzene or acetone and then rinse it quickly in isopropanol?
As covered many times already, benzene is never used. Refined "naphta" (gasoline, benzine) takes different names according to the country. I recommend against lighter fluid as it's mean to make a flame, not clean part, hence is not refined enough.
Now, since refined benzine leaves no residue, no rinsing is really necessary. But different people do differently.
Another thing that you will read is that IPA dissolves shellac, however not quickly, and not all of them.
1 minute ago, bojan1990 said:
I wanted to say "benzine" aka lighter fluid. What is alternative, acetone maybe? Or should everything be cleaned with IPA?
It's not the same, you should get refined benzine, for the reason explained above. That is the traditional product to clean watch parts, IPA was invented much later and for different purposes. Personally I use either and both work fine.
6 minutes ago, bojan1990 said:
Since it is easier for me to get the IPA, I will try cleaning with it. Do you leave parts for some time in the solution, clean and then rinse?
You can get refined benzine on Ebay. Leave parts few minutes into whatever solution, then let dry under a dust cover. For tiny parts like it's a good idea to use a small mesh basket.
To dissolve oil, grease, and dirt I use a liquid named "Gripen Kemiskt ren bensin". That's Swedish and translates to "Chemically pure gasoline" by Google translate ("Gripen" is the brand). I wonder if a better translation would be "refined benzine"? What do you think? The back of the bottle says (again Google translate): Naphtha petroleum hydrotreated lightly. When I try with "refined benzine", Google translate recommends I visit the nearest gas station, and I don't think that's right?
I buy the stuff at my local grocery store and it's about a quarter of the cost of Zippo lighter fluid. That is, I pay approx $2 for 125ml. I'm sure there are bigger and less expensive bottles or alternatives but I haven't looked into it. The front of the bottle reads: "Efficiently removes spots of oil, grease, and glue", and that seems to be what it does!
For my final rinse, I always use IPA, to remove any possible "cleaning fluid" (whatever I've used) residue. I know from experience that the shellac or resin doesn't go well with IPA, so I'm very careful to rinse the balance and pallet fork very quickly (max 30 sec.).
Anyway, for any parts big enough I definitely get the best results using warm water, detergent, and a soft toothbrush. The jewel pivot holes I peg out, and if necessary also treat with the chemically pure gasoline.
This post by "clockman" was the best info about cleaning I could find when I was new to this. I still think it's good!
Edited by VWatchie
Also a Swedish resident, I use the ”Gripen” benzine mentioned by VWatchie. And btw, the Gripen benzine works perfect as lighter fuel in my Zippo hand warmer I use a lot during winter ski tours, at the fraction of the cost for the original Zippo stuff.
I use two small licqeur glasses and my hobbyist u/s machine with a squeeze of regular dish wash liquid in hot tap water. If I feel ambitious (and can stand the fumes) I add a splash of ammonia.
The parts (in the natural group order) goes into the first benzine container for a few min’s and then into the u/s.
After that back into the first benzine glass again with the main purpose to push out any remaining water from hidden places in the parts. The water separating property of the benzine is a cool one!
Then over for a final rinse in the 2nd benzine glass and out to dry on a regular printer paper.
Lately I have tried to re-use the benzine by pouring off the top section (the water is heavier and stays low) but noted I get some staining, probably from dissolved oils and grease so I will stop that and use fresh stuff every time.
If I note any remaining stains on the jewels, I remove these with a wooden tooth pick.
The procedure usually takes me a 1/2 hour for a regular manual movement, which works for an amateur and hobbyist, I guess.
/Bsoderling
I am sure that someone can give you correct advice. I use an U/S cleaner with Naphtha. I clean the balance and scape with Acetone, then rinse with Naphtha and allow to dry naturally. I do not use Isopropanol. This method works very well for me. Do not get Acetone anywhere near plastic`s and you can buy 5 litres of med or fast Naphtha from you local auto paint shop at around £12. They call it Panel Wipe !!.
I read not to use lighter fuel, but a good replacement is from the Go outdoors camping store, but I can't remember the name, it's a lot cheaper than lighter fuel, anyone???
Coleman fuel. Try Panel Wipe from your auto paint shop. Pure Naphtha, as pure as you will get anywhere. £12 for 5L. It is an excellent watch cleaner. Cheap enough to clean and wash components properly at low cost. Fine for U/S.
You should go for quality not price. Anything that is made to burn is not purified enough for lab or cleaning purproses. https://www.ebay.it/itm/Petroleum-Ether-80-C-100-C-500ml-Petroleum-Spirit-Shipped-Same-Day/142061406816
10 minutes ago, ecodec said:
Fine for U/S.
Using (highly) combustible liquids in an U/S cleaner is not recommended for obvious reason, as written on the device instructions as well. The heating from the process is significant. You can do that anyway one million times and be fine, but I prefer to use only soapy water in the cleaner.
Hi,
I find this test and conclusions a bit strange...
The residue seen on the glass is what’s left after the solvent has evaporated i.e. It’s an indication of the level of impurities in the solvent, not a property of the solvent in itself (that’s not there anymore)
As such this test can be used to determine if your solvent (benzine, alcohol, acethone ...) is as clean as you want it to be.
But to determine if your solvent as such is good or bad, I see no guidance here.
On 7/22/2018 at 5:49 AM, bsoderling said:
Hi,
It's a very useful test for final stage rinsing. A popular cheap way to clean is to use lighter fluid and then rinse with %99 IPA to get rid of the film that it usually leaves behind.
So you use the test (solvent on glass sheet) to ensure the IPA is clean (= no residue ) whereas you don’t expect that from the lighter fluid that is primarily intended for burning and can be contaminated ?
That makes a lot of sense to me and I will try that next time with the benzine I use for cleaning and rinsing.
I soak the parts in Naphtha for a period. Then clean with very little heat at all from the U/S cleaner.  For the balance components and escapement I use Acetone then a wash in clean Naphtha. Sometimes for stubborn staining I use a brush.  This method has never failed me.
1
Please remember to let us know the result. Thanks!
Hello,
is there any kind of guide how to clean watch movement by hand? I found something like that in Practical Watch Repairing book, but I am wondering if there is something on Internet as well. I know that a lot of members use an ultrasonic machine for cleaning, but nevertheless I want to learn proper hand cleaning technique, especially when it comes to the hairspring (as very sensitive part of the movement).
Thanks.
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it all worked perfect 🙂 I'm very happy how this worked for me 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
