Hi
Anyone use these ? It's just a small camera on a stand that plugs into your pc and gives a visual on the screen.
They are pretty cheap but then again you get what you pay for.
I see a lot of guys use the stereo microscope, just wondering which way to go. I cannot see jewels  or inspect a jewles whole with my current visor. And more immediately I have again dropped the balance cock and tangled the spring wich I will again destroy trying to untangle if I can't see it !
Thank you for any advice, Tom
I think there is one other thread or two with the specifics of what people have bought and how it works for them, try searching.
2 hours ago, thessler said:
Hi
Anyone use these ?
You mean that 6-8 USD microscope with 200x amgnification and 2MP resolution? I am using one. Excellent for checking pivots and making some lathe work without squinting and stooping over the workpiece. I have some videos on Youtube. Check them and decide!
But it is inconvenient to have another PC or notebook next to the lathe. It can be used however with an OTG capable tablet or phone which is movable. I have not tried this yet.
Thessler ;i use 9 power  magnification with eye glasses for small work.   the dentist has a hand held didital probe with even higher resolution sent to the screen.  you have me wondering if this would be a good way to send  photos to the forum?  thanks vinn
you should be able to find a usb scope camera, most are ~100 us, the good high resolution ones, you simply exchange the eye piece for the camera, the key factors for getting one is knowing the circum. of the eye piece to make sure the camera will fit.
As far as a good tri scope, the key factor you need to look for is working distance, ideally you want about 8 inches,  which require better optics then the minimal working distance scopes. do a google search for AmScope or a scambay search there are a lot of options out there. The reason I mentioned a tri-scope is the camera stays in it the scope and if you need or want to use the it the old fashion way, you do not have to find the second eye piece, mess with the focus. Unless you are doing some serious micro movements, a 40x is the most you should need, and the higher the magnification, the smaller the working distance..
OMG.... I'm going to have to look in to one of these, cheap or otherwise. Not often you run into 'bad' jewels. (unless watch has been dropped or knocked real hard), but this would help diagnose pivots and misalignments... thanks, will check them out!
So I got myself a sorry-state russian microscope (4x-100x) (I believe it's been dropped, so I fixed the broken stand, I cleaned it and I aligned the glass prisms the best I could - work in progress). For more details on the microscope model, checkout http://microscope.modelengines.info/.
Samples below. The pictures are taken with a phone by putting it on an eyepiece. The subject is a beat-up balance wheel from a Poljot 2209. Looking through the microscope, the image is clearer, with better contrast and, most important, stereoscopic.
Thank you,
Bogdan
  • Like 5
I've had one of these microscopes for quite a while I bought it second hand as a kit with 3 sets of eye pieces. I paid £65.00 for it off ebay they are built like a tank. The russian objectives are very good on these microscopes well worth seeking out as a cheap stereo microscope.
The only draw back is that the standard lens has only about 90mm working distance below it, I am trying to source a reasonably priced 190mm as this would give a much greater working distance.
What is the working distance at the maximum magnification?
Maximum magnification you are only mm from the object, however, you can easily have it up 2 inches and you are still pretty close. You could use it to project on a computer and then operate on the patient (watch).
What do you use to clean the lens? I read somewhere that ether70%/IPA 30% mix would do.
Also, I was searching for a service manual, but I think there isn't anything out there. I am having some problems with the rack/pinion assesmbly - it's a bit too loose.
I use Lidl lens cleaning wipes that come in a pack of 100 these are alchol impregnated wipes.
The tension on the rack and pinion is adjustable via the knob on the right hand side,this is a instruction/maintence manual I found online,
http://www.lzos.ru/en/pdf/MBS-10_manual.pdf
I did take mine apart to clean and regrease it as all the old grease had hardend
When you take it apart it becomes fairly obvious where the old grease is it will have  hardend so clean it off, mainly on the threads of the friction adjustment and on the rack. The only grease I had at the time was a grease I use for my mountain bike gears so I used that.I did this about two years ago and its still silky smooth on the focus adjustment.
The only other thing I have done is replace the light with a L.E.D one the old one being a tungsten light powered by a transforner the size of a electricity sub station ran very hot, I dont know how good russian electrics are but I got the distinct impression that the best place for this was the bin.
first of all: HA HA!! nice one with electricity sub-station :)) True....
I am waiting for a cheap chinese 144 LED microscope Lamp myself to replace the "Heater", but I am a bit skeptical about it being as strong as the original light.
About the rack/pinion, I wasn't referring to the rack/pinion itself but more at the pinion axle and the knobs at it's end. Those are slipping, meaning the knobs are slipping on the axle - so I am thinking maybe I put too much grease and in the wrong places.
So to reiterate the question: where did you grease the pinion axle? For example: did you grease the washers near the knob? How about the wood piece that resembles a champagne cork material?
Sorry if it's a dumb question. When I disassembled the thing, there was hardened grease everywhere. Also I struggled about 2 hours (from 2AM to 4 AM) because when I replaced the flange form the left side (from the rack-pinion assembly, the one that is fixed in 3 screws), I put it upside down - so the pinion didn't slide smoothly on the rack. Dumb, dumb, dumb....
No just grease the axle. I think the wood piece is some kind of hardend leather in mine I did not put any grease on, thats what provides the resistance to stop the focus being too loose and moving from the weight of the head. If the knobs are slipping on the axle have you tightend the two nuts that hold the knobs to the axle enough I know they where a pain to do being so far down in the knob.
I have now cobbled together a eyepiece adapter for my MBC made from a old canon extension tube and a turned aluminium tube that fits over the eyepiece.
Using it I have found the 8x eyepiece to be optically better than the 14x at low magnifications the fall off around the edges is very pronounced with only the central portion of the frame sharp as in the example below1_zpsalbllgnn.jpg
But this improves as the magnification increases,
Contrast and sharpness are good Russian optics have always been good, having taken a lot of equipment and manufacturing facilties when germany was split after the war, but there is no depth of field to speak of so focus is very shallow in all these pic I have focused on the top of the centre wheel pinion,
The scratches on the top of the pinion are pin sharp but focus falls off on the screw heads,
Hi,
This is the set up I have attached a cheap L.E.D ring flash on to the lens this was bought very cheaply off Ebay for £10.00 including postage it can be used as a flash or a constant light source and comes with a number of adapters to fit various lenses.
The eyepiece adapter is a old Canon fit cheap chinese extension tube with a aluminium tube attached which fits directley over any one of the eyepieces.
These adapters can be bought ready made off Ebay for various D-SLR cameras or compact cameras.DSC_1079_zpsmrorjmri.jpg
Edited by wls1971
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
