Finding lost parts
Hello
I keep losing the clicksprings. My tweezers can't always hold them and sometimes they just fly away. I do use toothpicks to hold them too. I don't know if this is a stupid question, but does anyone have any advice on how to find them? Or how far they usually fly? I've recovered some, but not all and I work with cheap movement so buying new parts wouldn't make sense.
The movements I work on (Seiko 6xxx and 7xxx) usually doesn't have that kind of springs, but when they do have them (Seiko 66 or 6118 for example) I work under a transparent plastic bag so if they fly I should find them inside it.
I don't use toothpicks or pegwood to hold the spring anymore, for me it wasn't effective. Many people use a bit of rodico, and I use my finger (I wear nitrile gloves when working) covering almost all of the spring, and I use my tweezers to put the spring under tension. Then I make sure the spring stays in place while I carefully remove my finger.
To find a lost spring many people use a magnet, but I haven't tried it.
Until I lost a few click-springs myself I never paid attention to the plastic bag technique mentioned above. Since I have used it, I haven't lost one click-spring. I cut a sandwich sized baggie down the sides, put the spring near its final place, cover it with the single layer baggie and manipulate the spring, through the plastic, with my tweezers. Works every time. Good luck.
On finding getaway springs, I have used the magnetic bottom on a bolt-holding tray that is used for automotive repair. It's about 6" in diameter, with a 4" magnet on the bottom. I pass it over the area under and around my bench. And it has a very good rate of success. Good luck.
Edited by MrRoundel
Add magnet note.
Thanks for the tip. I've ordered a big 5cm magnet. I always thought they would be expensive, but apparently not. Anyways, thanks!
Thanks for the reply. I've always thought of the bag trick, but never actually practiced it. I tried cutting holes in a box and work with it like a sandblasting cabinet. It worked for a while, but soon after I just got tired of it. Anyways thanks for the tip! :)
To add to the finding side of the equation: They make magnets on sticks if you'd prefer to not be on all fours while you look.
https://smile.amazon.com/Fabcell-Telescoping-Magnetic-Pickup-tool/dp/B074P1NK2X/ref=sr_1_10?dchild=1&keywords=magnetic+rake&qid=1588463301&sr=8-10
Not necessarily the one I have or would get, but an example of what I'm talking about.
It does better with practice. Trust me.
Try not to lose them in the first place. Good tweezers and tweezering technique are essential. Get a good set of tweezers. A fine tip, medium tip and heavy tweezers. When I say good, it doesn't mean $$$$$. My favorite tweezer cost just over $1.
A good tweezer must have tips that meet evenly. No crossbite or crooked tips. And tweezers, like screwdrivers, meed regular maintenance.
When a part inadvertently flies off your tweezers, don't panic. Try to see the direction it flew off. Listen for any tell tale sounds of where it landed. Did it land on the bench or the floor. Personally, I hate it when it lands on the bench. Tell me, who has a clean, uncluttered benchtop. :D
I prefer that it lands on the floor. I use a flexible magnet strip about 14" long and sweep around where I was sitting. If that doesn't work, expand the search area. It usually doesn't fly more than 6 feet away.
Oh yes, check if it landed on your clothing too. I once had a screw drop inside my shoe.
Funny. I did something very similar. I kept having Waltham pocket watch shipper springs pinging into oblivion.
I remember when I was following the Timezone watch school courses about 15-20 years ago. One of the first things Walt Odets described was how to make a parts sweeper.
His method was to use a magnetic knife holder that people used to stick knives to their kitchen wall, add a couple of nylon feet so that is can slide around smoothly a few mm above the surface of the floor, and attach a small handle if you prefer. You can then use this to sweep around the area and then inspect it with a loupe to see what you have unearthed! :-)
24 minutes ago, eccentric59 said:
Murphy's law of lost parts states the probability of looking in the correct area of your floor is inversely proportional to the size of the part. ;)
O'Toole's corollary to Murphy's law (if it can go wrong it will go wrong) states that Murphy was an optimist.....:D
Everything I lose is almost invariably non-magnetic! A couple of weeks ago I lost the cap jewel from the 1965 Rolex cal 1200 I was working on  which is not the easiest movement to find spares for, and found it by eye under a set of drawers. (I still have no idea how I saw it)
I then patted it with a pea sized ball of rodico to clean off any dust or oil and promptly lost it inside the rodico! It took me longer to find it in there than it did when it was on the floor! :-D :-D :-D
I lost a pallet jewel once. It was there on my work mat one moment then gone the next moment. I used a torch and searched high and low. I was on all fours for almost half an hour before I gave up. I said a silent prayer and when I was stretching out my aching back, I caught a glint on the floor just outside of my search area. It really was the missing pallet jewel. :woohoo-jumping-smiley-emoticon:
So my advice is when you are already on your hands and knees, it doesn't hurt to pray.
  • Haha 2
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
