Hi from rookie Truls
Truls
Hi, I'm just starting learning about watch repair and bought myself some tools and microscope, very happy to be in this group. Of watches I have Seiko "Pogue", vintage Longines Flagship, vintage Yema mechnical (kids watch), and a vintage Omega Seamaster on its way :)
Edited by Truls
Welcome,
If I might suggest, that you don't go pulling apart your vintage, rather expensive watches you named in that list, until you buy some £10 - £20 watches and played around with those to get a feel for what you are doing. We are all here to help and before long you will have the confidence and a little more experience to tackle those watches you mentioned
Welcome aboard! As @Jon stated, teaching yourself watchmaking on more expensive watches is a potentially expensive lesson in the making. In line with Jon's statement, $10 to $20 watches are a great place to start. May I suggest old mechanical Timex's as there are heaps of mid 70's models available for a song on eBay.  They're super simple and generally easy to troubleshoot and fix and once you do, they become surprisingly reliable timekeepers. Good luck and don't be afraid to ask us for help should you get stuck.
Thank you for your adivices. As you mention it is best to start with some cheaper mechnical watches. And this is my intention. Therefore I started to look for some Seiko's but they are a little to hard to come by cheap options here, so at the moment Im looking for anything mechanical, maybe prefereble hand wound. Im sure I'll back here looking for answers :)
Thank you for your introduction and welcome to this friendly forum.
I always recommend you start with a pocket watch. Just practice taking it apart and putting it together. Most are like a watch movement. Get to know the names of the parts as well. Don't touch the fusee pocket watches as those are completely different. Some thing like this is a good start.
1 hour ago, watchweasol said:
Hi If you want cheap wrist watches look for the Russian ones  Wostock, Racketa etc usually pick them up non working for a pound or two
Couldn't agree more and remember that Russian movements are more like the Swiss movements in design unlike the Japanese movements. You might find my walkthrough of the Vostok calibre 2409 useful.
Other than that, I agree a lot with @oldhippy. I think the most ideal movement to get started with is a Unitas calibre 6497 or 6498 (or a clone), and once you've finished servicing it you'll find hundreds if not thousands of options on eBay if you wish to case it and wear it. It is also the movement used on watchrepairlessons.com which in my opinion is the best and most affordable way to learn about basic and semi-advanced repairing and servicing.
Good luck!
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
