Chinese clone horia tool
I would like a jeweling tool to practice correcting end shakes and also to install jewels. The Horia tool with a set of pushers/anvils is out of my budget at the moment.
I noticed a Chinese version
https://www.aliexpress.com/item/4000261581571.html?spm=a2g0o.detail.1000013.1.5ee15a59YGNywJ&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=c3dcc468-4930-4773-bc9c-319ccf7b9847
At first glance they look the same and being Chinese the price difference is huge, less than 10% of the Swiss version but too expensive to take a wild punt. Some Chinese tools and equipment i have purchased have been absolutely brilliant. Does anybody have any experience with this tool?
Complete from the US, box, vintage look and all.
https://www.ebay.it/itm/Seitz-Jeweling-tool-set-with-reamers-pushers-anvils/274079345666
about £300, maybe use a reshipper to lessen customs charges.
I have nothing against the Chinese, it's just that in this case their value proposition is not that compelling.
Edited by jdm
if you don't like the Chinese version can you return it?
Visually it looks really really close to the Horia. One of the problems I found from buying Chinese stuff that visually what you think you're purchasing isn't always entirely what you get.
Then for the Seitz versus Horia tool? if you're going to insert new jewels you're going to have to acquire the Seitz tool as it has the reamers that you're going to need. Then it will let you push the jewels in so one tool does it all. But the Horia tool is so much nicer for pushing the jewels and adjusting end shake. So the absolute best world would be to have both of them.
https://www.horia.ch/en/Products/Jewellling-Setting-staking-tools.html
Thanks for the info John. This is the first jewel I need to remove. It's from a Rolex clone movement. I have another scrap movement I can source a jewel from. Will the Chinese horia tool not suffice to complete this task?
The tools mentioned here so far all probably do the same job, but they are not exactly the same. Since I do not know why the differences myself I will make a summary
  • Seitz shown above all have a (detachable) lever, and I suppose, 4mm pushers and anvils. Some use guidance is provided (attached)
  • Chinese doesn't have a lever.
  • Horia has various types:
    - No lever, 3mm or 4mm spindle (the latter is more "standard" I think), regular of fine thread, that I can probably understand.
    - With lever, come in two types: free or guided spindle, not sure why to chose one over the other.
    - With lever and bigger spindles.
    Their boxed sets include both first two types, as if the serious Watchmaker couldn't do without.
But for the amateur and/or budget minded professional the best deal is always a basic tool on Ebay, then add the bits as needed.
2001_J31073.pdf
Edited by jdm
both tools will work fine.
Normally when people are replacing broken jewels when fitting a new  jewel  it will more than likely be sized differently  which is why you would need to  ream out the hole for proper fit. As you already have a proper replacement jewel that will not need to be done.
lever versus micrometer head?  Conceivably with the lever you'll have much more pushing force.   The micrometer head in my opinion  gives you much more precise  adjustments..
then the 3 mm versus the 4 mm? The older horia tool tool that I have has a spindle of 3 mm with a base of 4 mm..  The Seitz set both the base and the spindle are 4 mm. So for compatibility reasons it's nice  to have everything at 4 mm for interchangeability..
That's great thanks. I think i'll give the chinese one a go.
A question regarding changing jewels. Are you saying if i didn't have a replacement i would not find the exact sized jewel to fit so i would have to ream out the hole and fit one with a larger diameter? The inside measurement would always have to be the same though, in this case for the centre wheel to pass through.
this is watch repair anything is possible? This means that if you look on the catalog  pages of the attached PDF you may find the exact size jewel you're looking for. But is also the possibility of the various watch companies using their own jewels and the outside diameters might not correspond to the jewel sizes found on the catalog page.
5006 A_a_F Seitz jewels.pdf
i bet those sets aren't cheap. i'm sure i can order individual ones from Cousins though.
Next problem.... what is best best way to measure the inside diameter of a jewel, they're so small
If you go to the link below scroll down to the section titled Joseph School of Watch Making And realistically download the entire book because it has really useful information. But you looking at section titled Unit 9b - Friction Jeweling. That is going to answer a lot of questions maybe not all of them but that would get you started.
https://www.mybulova.com/vintage-bulova-catalogs
  • 2 months later...
I thought i'd bump this instead of starting a new thread.
The Chinese tool arrived. I have adjusted end shakes on a few movements to get the feel of it. It works the same way as the Horia tool and has 0.01mm of slack so if you need 0.04mm correction you push 0.05 etc.
So i need to press in this jewel. I have pressed a few out of 2824 clone movements and it was super easy, i just took the measurements before and then placed them back on top.
Now i have to press this jewel into the Rolex clone movement i'm a little bit nervous, i can't get another one... So thought i'd ask a couple of questions here, if anyone would be kind enough to help me out?
1. As i can't take a measurement, is the only way to achieve the correct end shake placing the movement back together and keep taking it apart until the end shake feels right?
2. Does this jewel in the picture only go in one way (centre jewel)? I cant work out if one side is different to the other.
Interesting that you mention the "slack". Just so that I understand, if you back off the micrometer, then bring it down and touch the jewel, you get .01 movement on the mic scale before the pusher starts moving the jewel? That would be a different situation than the normal backlash in a screw, where there is slack or slop when reversing the movement of the mic.
Have fun with your tool!
The extra hundredth thing is a thing with pretty much every jeweling tool I've used, including Seitz, Favorite, Chatons SA, and Horia. I tend to use the lever types, but Horia screw types are similar. Think of the stack up of parts- the stump, the watch plate, the jewel, the pusher, the interface of pusher to spindle, then finally the micrometric screw. A micron or two of slop or mushiness here, another there, that it's typically only a hundredth is pretty fantastic.
As for orienting the jewel, if it's truly symmetric put it however you want. If there is an oil sink (however slight), that goes opposite the wheel.
  • 9 months later...
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 at 20° C) than 9504 (305 at 20°). The viscosity of Molykote DX is 285-315 at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
