This balance is not moving right
aac58
59 minutes ago, jdm said:
IPA, not water, dissolve shellac and even the glue used on etachron HS studs. As mentioned by Master nickelsilver and most cleaning threads.
IPA will indeed dissolve shellac. Water will eventually damage shellac (which is why you get watermarks on French polished tables, shellac is very slightly absorbent), however it would probably take many hours in water, or very hot water  to loosen the jewels in a balance, so in the real world, it is generally not a problem.
It depends on the alcohol concentration too. I use 99.9% isopropyl, but have a distiller so at some point it ends up a bit less. 70% would take significantly longer to clear out shellac. Anyways I always check and often leave parts in for 6 minutes or so in the alcohol BUT I adjust stones a couple of times a day, so I just pop the fork on the heater which is always on and add shellac. If you don't want to do this keep soak time under a minute for (warm) 99% alcohol and maybe a minute or two for lesser concentrations, unless you're planning on reshellacing.
You distill your own alcohol and you make ISOPROPYL? [emoji37]
8 hours ago, ITProDad said:
I have a cleaning machine that was designed to use isopropyl as the rinse, and it has a built in distiller. Clean, go in the rinse, push a button and it drains into the reservoir, then about 6 minutes later there's fresh alcohol in the rinse container. It's slick! Hasn't been made in about 50 years (Greiner told me people were using it for other alcohols... the distillation temp of ethanol is close enough to work haha).
We have got to see pictures of that... not that I'm planning on taking up the twin traditional Scottish pursuits of uisge-beatha production and dodging the Excise man.
HM Revenue and Customs can relax, I'm just intrigued about the mechanics of it all (honest). I presume there is a small electric heater, but how does the condenser work?
Edited by AndyHull
There she is! The first bath is the cleaner, it's circulated through a filter which also has a magnet, and is ultrasonic of course. The second bath is the alcohol. The reservoir is in the case at the bottom right, it's a bit over 1 liter capacity. The condenser is behind the 1st bath, the vent at the top left is where the hot air (it's air cooled) escapes, and is also the dryer for the parts (clever!). The rightmost section is the eplilame treatment. There is stearic acid in the bottom, which gets heated to its melting point; the parts sit above that and with the lid closed sit for about a minute. This deposits a microscopic layer of the stearic acid vapor, which is the original epilame (Moebius used to sell it in liquid form as Aretol).
I don't know what I'll do when the old girl dies...
Why, fix it of course. What else would you do? :biggrin:
That is  pretty sophisticated little machine.
When was it produced?
From the styling, I would think it was designed in the late 1960s, but I could of course be wrong.
Mid 60s, the ultrasonic is tube (valve) based, as well as the switching for the distiller. I asked Greiner why they stopped making it, and in addition to the misuse for ethanol, they said it would need lots of mods to meet newer safety standards and would end up 3 times the size and 5 times the price. It's extraordinarily well built for sure.
Very cool! Or brilliant! Depending on where you reside. That is an excellent idea
The donor arrived this morning. I've cleaned the motion works and the base plate, I've lost one endstone and I've installed the other one on the "new" balance bridge, and I've replaced the faulty balance with this one.
I'm quite pleased... No, I'm very happy to be honest, I'm slowly getting better results.
BTW, sometimes I need to grab the incablock endstones with my tweezers, for example to turn them upside-down or to hold them while oiling. It's in this moment when, sometimes, the endstone jumps to the ether, from where they look at me and laugh.
I'm using Dumond nº2 tweezers. Maybe this is not the correct tweezer for this task? Or is it just a matter of practice?
Hi When handling jewels and endstones, or need to inspect the same it is sometimes prudent to use a bit of Rodico to stop them from dissapearing. Some times caused by gripping the parts too strongly. You will get more adept the more you do. Also when removing shocks etc do it in an enclosed space (poly bag) it limits the distance they travel and you know they are in the bag somewhere !!
Just use your other hand to shelter/cover the cap stone as you try to flip it over. It helps a bit, not 100% but better than nothing.
Anilv
On 9/26/2019 at 1:45 AM, jdrichard said:
So what was the problem with the wobbly balance. I now need to know because the suspense is killing me.
Sent from my iPhone using Tapatalk Pr
Hi jd,  a Simple feel of side and endshake at the cock side. One can tell No pivot inside the jewel hole.  either pivot jumps out or no pivot( broken). One or two such observations you,ll be as good with such diagnostic of pivot as you are with making them.  Regards joe
On 9/25/2019 at 7:29 PM, aac58 said:
... I've lost one endstone and ...
Found!!!
I've downloaded a new video editor program, and I was playing a bit to get used to it. Then I saw someting below the balance that shouldn't be there...
  • Haha 3
BTW I "found" something similar in my HMT spares the other day, unfortunately it was the cause of the spares movement's woes.
One of the lugs was missing. In this case, the reason for its demise was corrosion (as you can see from the nasty blotches on the surface of the jewel). On the plus side, I already have a "spare" spare one, and replacement HMTs are cheap as chips anyway/
HMT and Citizens use same shock absorbers.. I've used parts from the handwind HMT to fix Citizen 0200 movements.
Anilv
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
