This balance is not moving right
aac58
BTW, sometimes I need to grab the incablock endstones with my tweezers, for example to turn them upside-down or to hold them while oiling. It's in this moment when, sometimes, the endstone jumps to the ether, from where they look at me and laugh.
I'm using Dumond nº2 tweezers. Maybe this is not the correct tweezer for this task? Or is it just a matter of practice?
I use #e tweezers but I put the stone on my mat and hold it in place with the tweezers. I don’t try to hold out it the air. Also, try griping the stone further up the tweezer a few mm from the tips. More surface area to grip the stone and more height Incase they try to escape. ......and practice!
I always find rotating my wrists whilst gripping small parts with tweezers to flip such parts around to be harrowing experiences. I've gotten into the habit of just picking them up and dropping them a short distance from the mat until the side I want faces up haha.
Edited by CaptCalvin
For hard to replace shock springs, I  remove all to get to flat balance bridge, lay on hard surface on large mat, remove shock spring, clean, reinstal, rinse.
Reinstallation of endstone.
Get some oil on tip of screwdriver baldes.Endstone sticks to the oil.
place endstone on upper jewel, slide the screwdriver away, place shock spring on top, use any tool and hands to get the shock spring locked.
Not need to keep parts clean during assembly (by this approach) , makes it easy, low risk.
Rinse the cock with shock spring installed. Oil through upper jewel through chaton jewel, install the rest.
For those having difficulty handling jewels, shock springs, and other really small parts, using tweezers without pinging things into oblivion you might be interested in this post from way back at the beginning of 2015.
The jewel picker upper has to be one of the best cheap tools on the market simply because of the number of irreplaceable tiny parts that are prevented from going into orbit, and it's such a simple piece of kit too.
It does a good job of removing that obstinate speck of dust from the inside of the crystal without leaving any residue as well. You know the one, it's that mote that you don't spot until you have cased up the watch so you have to open it all up again, and then the air puffer won't shift it or if it does it just lands somewhere else on the crystal......  Jewel picker upper gets it every time
:thumbsu:
  • 3 years later...
On 9/25/2019 at 9:12 PM, watchweasol said:
 when removing shocks etc do it in an enclosed space (poly bag) it limits the distance they travel and you know they are in the bag somewhere !!
That is an interesting suggestion. I'll see if I can find a bag that will allow the necessary visibility of the spring..
But I definitely spend too much time on the floor, looking for those bloody springs.
So far, my best method was to hold the spring with Rodico and use tweezers to direct (not to hold) into it's slot. The risk of it flying is much reduced
Edited by Knebo
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Yes and no. I use Moebius 9501 synthetic grease and it is significantly runnier than the Moebius 9504 synthetic grease (and I assume Molykote DX) that I previously used. I haven't seen 9504 spread and it is in my opinion the best grease money can buy. However, my current method of cleaning doesn't remove it from the parts, so that's why I have decided to use the 9501 instead. I believe I read somewhere that Molykote DX too is difficult to clean off. Thinking about it, I'm pretty sure my 9501 grease which expired in June 2022 is runnier now than it was when it was new, but whether new or old it always needs to be stirred before use. So, that's why I treat the parts of the keyless works, cannon pinion, etc. with epilame. That was very thoughtful of you and something that had completely passed me by. Not sure what the epilame will do when it wears off in a non-oiled hole. Anyone?
