Tool porn!
margolisd
For a newbie, what in the world is this used for?? :huh:
It's a tool kit used for fitting and removing bushes and jewels from watches or clocks. It has some other uses but that is the primary function.
The set above is a very nice example.
Sent from my SM-G950F using Tapatalk
Cool, i have seen these around ebay when scavenging around for vintage tools but had no clue it was even related to watchmaking. Makes more sense now.
Lovely set JD.  Is it all complete?
I think it is almost complete. I looked at the Seitz manual and compared it and found that some pieces were just in the wrong place, like those collets on the bottom left. There are only a few open holes. I really wanted the pivot straightening device as they are usually 300 bucks alone. I already have the lower seitz kit and a jeweled ruler and the plate holding device. So the plan is to put all the parts in the right place, determine the gaps and if I really need to fill them. And then sell the individual items I currently have. It should arrive Monday.
Sent from my GT-N5110 using Tapatalk
I managed to pick up pretty much all that you have there JD, only not as a dedicated set.  I really do like boxed sets of tools like that.
I have duplicates of almost all except the pivot straightening device which typically goes for around 300 on eBay and 450 new.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
