Hello once again.
I want to buy a Canon Pinion Remover and I'm contemplating which of the following two (or else), is better to buy. Your opinions and advice are much appreciated.
  On 9/17/2017 at 9:38 AM, PJA said:
Hello once again.
Expand
For which purpose specifically? Not many movements need one. A nail clipper can also work.
I get by with the presto type one shown but if i came across a used one of the type pictured above (first one) i would grab it as i wouldn't imagine there's much it couldn't remove
Edited by Andyclient
Thank you all. I will be looking for the top tool and in the case I might need it I will try a nail clipper or my Chinese hand tool version, whichever will work better.
Expand
No specific use right now, but I figured that I should have it in case I may need it.
Edited by PJA
Expand
With that approach the first thing you'd need would be a large tool case :biggrin:
Earlier the 7S26 and large small seconds calibers were mentioned. Neither one needs a pinion puller.
Expand
Thank you. I tell you. What do I know? I read and watch videos online and as far as I understood is that I'll need this tool amongst others, but now after you make me aware of the fact that I really won't have to really buy it, at least not at the beginning of learning, it will help me putting more financial efforts somewhere else.
The top one is the best IF you can purchase a vintage version. The reason is for some reason Bergeon changed the design and as result the new one's do not work with the small cannon pinions.
A normal presto hand remover can be used as well, you just have pinch at the bottom to keep enough grip as you compress the sides to lift. (I believe the credit for that tip goes to mark though I cannot remember for sure)
I'd like to echo concerns I've heard from more than one senior watchmaker, of which I respect (again, I think one was mark) about pulling directly up, which can be difficult with improvised tools like pin vices and nail clippers. You run the risk of damage if by errant twitch you pull to the side and not directly up.
Edited by Ishima
It really depends on what you're getting into as time goes by. On larger movements you can even use hand levers but keep that lift vertical !
Nailclippers concern me as you may squeeze and pull at the same time which could severely damage the pinion. But they are a great "Lazy" way of tightening a pinion whilst still attached.
I've come across several movements where accessing the pinion base has been difficult and the above pictured Bergeon tool has been the only effective way to remove it.
As for the second photo. I just regard these as a waste of money if only even cheap but they do make good crown pullers, if you're dealing with a split stem.
As for buying tools in case you may need them (Excellent Philosophy) definitely buy yourself a large tool box but don't let the Mrs know what you're up too [emoji16]
Sent from my SM-T585 using Tapatalk
Newbie poster here. I have the vintage version and I have found it works well for pocket-watches and wrist-watches. The fibre tip doesn't mar the pillar-plate, etc. And it has a nice straight pull. This is probably more important with wrist-watches than with pocket-watches, but it's surely always a good policy. I'll attach a scan of the promo/instructions that came with it. Maybe a search under the name "M-C Cannon-pinion Remover" will get you some results? Good luck.
While we're talking cannon pinions. This is a must for that gigantic tool box. It's basically a fancy pair of nail clippers with a micro adjuster. Made by Bergeon and comes with a fancy price. It's the best tool I've ever used for tightening cannon pinions and in my opinion, more accurate than using a staking set.735810842ba9fdcbcf2c1c0e21417fe1.jpg
Sent from my SM-G920F using Tapatalk
Also my preferred tool for tightening cannon pinions.
I purchased a set of end cutters for about £5, drilled and tapped M5 and fitted a cap screw, job done!
Edited by Geo
As for buying tools in case you may need them (Excellent Philosophy) definitely buy yourself a large tool box but don't let the Mrs know what you're up too emoji16.png
Expand
At this point of the game I am really into wrist watches and as time and experience progress, I guess I'll see where things will lead me too. As for the nail clipper, your point is well taken and for the toolbox, I am definitely not into the tools for the sake of tools collecting as you can imagine, but since I have no knowledge I gathered from reading here and there that it's an important part of the standard toolbox.
Thanks for the advice.
That's brilliant. Wish I had thought of it
  • 10 months later...
Expand
1
I'd really like to understand how the two screw handles work. Why not just one screw? I actually feel a bit embarrassed to ask as it's probably obvious to "handy people". Actually, I've been trying to find a video or some documentation/illustrations but haven't been able to find anything really useful.
I can just guess. a) Put the cannon pinion on the shaft of for example an old oiler. b) Pinch the pliers at the dent in the pinion, and at first resistance screw in the screw in the pliers until you feel a slight resistance (Hm... will I be needing a third hand for that?). c) Screw back "a bit" and pinch! d) Done? No, I really can't vision it...
Anyone, please? Thanks!
EDIT: Or... pinch the pinion while seated on the arbor of the centre wheel? Hm... No... probably not...
Edited by VWatchie
  • 4 months later...
Mark Lovic demonstrates exactly how to use the Bergeon cannon pinion tightener tool at watchreapirlessons.com, part 3 (Fault finding). Wonderful! :woohoo-jumping-smiley-emoticon:
    • See I wondered about this because Frei only lists one part for 18 size, no left or right options whereas they specify left and right for the other sizes. (I happen to be working on a grade 88) I recall seeing an old video of Elgin making laps and jewels in the factory (maybe you were the one who shared it) I have one very weird warming tool which has springy jaws that can open wide enough to hold this type of fork flat, and it swivels so you can position either side over the heat source. It works great for melting shellac on a firmly held fork EXCEPT can you guess what its fatal design flaw is?....   ....you cannot open the springy clamp once it has been heated because you would need to pinch them both between your fingers and you get a second degree burn. Genius.
    • The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge. One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran. Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound.   From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones. Elgin watch company Escapement Terminology.PDF
    • The roller table is supposed to be held on by friction. If there is shellac under the roller table it might indicate that an improper repair had occurred prior to this as it would not be held in place with shellac. Sometimes overenthusiastic people re-shellacking the roller jewel will get shellac where it's not supposed to be. Then the picture of your roller it looks kind of damage? It doesn't quite look right it looks like somebody held with a pair of pliers or something? Then your balance wheel has limited quantity of screws? Not necessarily a problem but an indication of perhaps with the other things a prior bad repair perhaps as a guess.
    • Quartz watches like mechanical watches need to be serviced from time to time. In other words the lubrication with time we'll go bad and the watch Will not run or will not run very well in other words oh be slow because the gears are no longer turning properly due to bad lubrication. Then other things bad for quartz watches basically anything dust that normally wouldn't affect the mechanical watch will affect the quartz watch because the quartz geartrain has extremely little power. So looking at your movement up above more than likely you'd have to clean it and lubricated before the new circuit would work.
    • I be concerned if this roller table belongs !   Timegrapher will ask,  where did you get this roller table or balance staff from?   Regs
