Just in.. Slava 2414
anilv
Hi guys..
Sharing a few pics a Slava I got off the 'bay.
Sellers pic was a bit blur but it had a movement I liked and was advertised as running.
The crystal was pretty scratched up but it was running.
A Russian 2 piece case back.
Quickset date by pushing this ..well..pusher!
As you can see , the crystal has a very high 'rise' and this contributes to the overall thickness.
And this is the reason I bid for this watch..it has a Slava 2414 (or maybe a different number as it has day and date) with twin barrels. It looks pretty clean and the finishing is slightly better than the other Slava movements I've seen. Its running pretty well these last two days but I'll probably tear it down and take some pics and post them here.
I spent a few minutes with some sandpaper and autosol and managed to clean it up a bit. Interesting dial with some constellation around the edge of the dial and some Russian words where a minute track would usually be. Also some numbers.  Anyone can shed someone light on this? Or speak Russian?
Hope everyone enjoyed their weekend. Mine is almost over as its 9pm here in Malaysia.
Anilv
Hi guys..
Anilv
These are the zodiac signs around the dial. At 6 it says made in Russia.
Sent from my E6553 using Tapatalk
I've gotten my watch :) I stripped it down last night. Cleaned. Waiting for re-assembly.
The dial is pristine and beautiful! I really love the Slava dials.
Mine is a 2414 date movement. Twin Barrel.
It had stopped running because the dial set screw had fallen into the movement!
Springs nearly flew across the room from the tension.
  • 1 year later...
got a couple of slavas myself one is the 2414 date, the other looks similar but day/date.cannot see the number yet.the hairspring is going at a rate of knots! i also need a balance for the date movement? need a case or two but struggling to find unless a buy a complete watch which i dont really want to do,plus on the day/date mvt it needs a button to change the day.if i cant find one i may just give them a clean and lube and resell them.B
  • Similar Content
    • Back home...printing now.  Will report results
