Last night whilst reassembling a Felsa 1560 I fired the Return Bar Spring from the keyless work across the room, 45 minutes of searching failed to find it. I'm now about to spend £5.81 plus £2.88 postage to get another one from Cousins.
It was bound to happen to me sooner or later, just hope it doesn't happen too often. :D
Welcome to the Club! Did you try the vacuum approach? - vacuum the carpet then go through the dust bag?
Magnet approach? - trail a magnet on a string over the area?
Or did you fall on your knees, cursing creation? - that sometimes helps! :mad:
You will spend hours sweeping the floor and down on your knees and in some cases you won't find the part. Then one day its there and you will swear and cuss I did I turned the air blue.:D
Hate when that happens. Lost an important and very small piece once (don't know what it's called) and let's just say that servicing that movement came to a halt.
I recently had a part take flight, and my search for half an hour was fruitless, all the time during the search I had my Optivisor on, slightly raised, it was only then, when I took it off, the missing part presented itself on the top of the brow of the Optivisor :woohoo-jumping-smiley-emoticon:
If you roll a strong flashlight slowly across the floor, sometimes the part will make a shadow and appear larger.  I have found missing parts like that.  A magnet is also a life-saver.  Sometimes I sweep the dust on the floor into a dustpan and run the magnet over the dustpan.  Most of the time, though, I'm on my knees either cursing or praying (both techniques work equally as well).  Seems my cursing sometimes makes the part mad enough to appear, and if that doesn't work, the praying may buy me a little mercy and the part, feeling sorry for having treating me so harshly, will come crawling back.
Whatever your part or whatever your technique, know that you are not alone and all your forum peers are right behind you, cheering you on (with little or no snickering).  :D
Shirley
AKA The Lighthouse Manoeuvre :)
Shirley
I tried that approach but it did not work this time.
On previous occasions I've always heard a 'tink' to give me an idea where it landed, but this time I heard nothing.
I searched, got my wife to search and tried again the next day before I gave up and ordered the part.
I'm sure tonight it will just appear back on the bench now that I've ordered a replacement...
Been there many times unfortunately !!!!   :pulling-hair-out:
Non-magnetic parts are the worst !!  I use a large loop of Gaffa Tape (which is very sticky) and inspect whats stuck to it with an eyeglass.  I have found end jewels, inca springs and even long lost bits using this method.  If I have to resort to a vacuum, I cover pipe with a fine cloth (old hanker-chief !) in which I wrap a very strong magnet.
Yep!  The quickest way to find a part is to order a replacement...  :D
Yes, isn't that the maneuver whereby you're more likely to pull in ships than find your part?  :D
Cool method!  Come to think of it... don't watchmakers have the cleanest floors in town (at least around their workbench)?  :biggrin:
Using a magnet I've found Novodiac springs in my shirt pocket, my glasses case - when it is in my shirt pocket, on shelves near my work bench and in my hair. I've never found one on the floor; however, I've found other things on the floor.
Once a newly-oiled end jewel ended up on my loop. I was wondering why things had a reddish tinge...
O yes, and after you buy the part you lost you'll almost always find it...
Dave
Hahaha!  So you were looking at life through "rose-colored glasses".
There are nice UV light LED flashlights.  The "Black Light" makes lots of stuff light up like jewels and the blue steel springs.  Handy to have around.
Also those dandy UK made Dyson Vacuums don't run you parts though the impeller before the make it to the dust bin.
Yup. Good thing I took a closer look.
Any old vacuum cleaner with a piece of the Mrs old tights over the nozzle works perfectly [emoji106]
Sent from my Honor 5c
Fired a strap pin into my printer the other week. Fortunately turning it upside down and shaking for a bit got it out. Was worried for a whike that I was going to have to learn how to take apart something bigger...
To quote Frank Lloyd Wright - rather loosely, "Move your bench."
LOL
Just wait until you fire one into your eyeball. Yes, it hurts like hell, now I wear my clear cycling glasses while doing the "big" dismantling stuff.
Will be buying a visor soon so will still be protected [emoji4]
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
