Watch of Today
mk3
38 minutes ago, ro63rto said:
No you are quite correct
The crown is on the left. It's like that on all 7a28/38 watches.
How unusual. I do know there are watches made for lefties, but I've only seen one watch with the crown on the left and it was an invicta ceramic diving watch.
J
J
I actually prefer the crowns on the left.
As I like to wear my watches low on my wrist, some of the larger crowns and crown guards tend to dig into my hand when my wrist bends back.
Dive watches are a classic candidate for crowns on the left. They allow full wrist movement and the crown is more protected that way too, unless you switch wrists [emoji4]
EDIT : You should know, trying to fiddle with the crown while still wearing your watch is a big NO NO as you can bend the stem or worse.
Dive watches are a classic candidate for crowns on the left. They allow full wrist movement and the crown is more protected that way too, unless you switch wrists emoji4.png
I didn't know that! It makes sense now that I think about it...don't want to get snagged in anything while diving.
J
Wearing a Mido 'chronometer' with a 'tv' case.
Its pretty chunky,
But at least the caseback is reasonably flat!
It still has its original band but its missing some links. It fits me but is at its maximum at the clasp.
Bracelet is a Stellux.
Inside is a Cal 1157 which is what Mido calls the AS1920! Sorry no movement pics.
Pretty weird design typical of the late 70s, early 80s.
Anilv
Edited by anilv
On 12/10/2017 at 1:39 PM, ricardopalamino said:
That's quite a collection you have there .
5a2dc2e06bb42_ScreenShot2017-12-10at1_25_57PM.png.5b0ba9609a88c620ac97dd332ade8d1b.png
Here's my Casio , I've had it forever too….
5a2dc4f42f24e_ScreenShot2017-12-10at1_35_08PM.thumb.png.f556aaede4d4f2c6d9a8a3dd9255105d.png
I got this new Casio Data Bank / Calculator on a whim .
I have about 25 different watches I wear to work ,...watches that I'm not afraid to bump against something that may cause a scratch or ding . My Casio WR pictured above is an example . It seems that every time I wear it one of the younger guys at work comments that it looked like the first watch they ever had . Usually given as a birthday or Christmas present .
So I was perusing watches on ebay and came across this Casio . It tells time in 2 time zones , has several alarms that can be set to go off daily or pre-set dates and times and with a snooze function on alarm 1 , a calculator , exchange rate function , stop watch and split time chronograph , data bank that can store 25 files and telephone numbers , and probably do my taxes .
My favorite feature is that you can set it so the light goes on automatically when you turn your wrist to read the time .
It also has a 10 year battery ,....it says so on the crystal .
And last , but not least ,........$34 with free shipping .
I forgot to say that it's multi-lingual.
5a4a7a0f89c94_ScreenShot2018-01-01at7_51_36AM.thumb.png.085e43120d9a75f05a68f80341abe752.png
5a4a7a472b6b4_ScreenShot2018-01-01at7_52_15AM.thumb.png.fc9540b0ce5300b76c44b8d927dc5c9e.png5a4a7a821bd8f_ScreenShot2018-01-01at7_54_02AM.thumb.png.e7008bd013c39e02d38badf3865c2729.png
5 hours ago, jdm said:
A good start for the new year with this classic!
Very nice watch you posted jdm . It is a classic beauty .
I'll get one someday.......
I started the Year with another classic that the Post Lady delivered on Sunday no less .  It is a Tissot PR516 GL [Grand Luxe ] ......
Nice heft to it with the solid link integrated bracelet .
My pictures don't do it justice .
5a4a7e8be8206_ScreenShot2018-01-01at8_22_57AM.thumb.png.6d9ad877068b8c65acf7f7b11045e275.png
5a4a7f0af035e_ScreenShot2018-01-01at8_23_24AM.thumb.png.5dd810491f315be2e7f417bce8bf9eb1.png
On January 15, 2018 at 11:26 PM, anilv said:
This doesn't get much wrist time but when I do it feels so right! On this one the inner bezel still moves.
6139-6002 from June '75.
Anilv
Hi Anliv , I have a similar gold dial Pogue and  agree about the feeling when wearing it . I remember wearing it on a job interview for good luck .
 Does yours have any water proof/resistance markings on the dial under the hands ?
VEry nice.
J
Hi Noirrac.. no it doesn't have any markings at the 9 o'clock. It not a Japanese Speed timer.
Anilv
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
