Watch of Today
mk3
If you folks get tired of me posting my watches, just let me know! :huh:
I wasn't sure how a white dial would look as a pilot style watch. I got really lucky with the Printing of this dial. It turned out very clean with nice, sharp edges..
BTW, I test all my watches with the same strap...no, I didn't buy hundreds of them![emoji3]
Job well done!
Hi guys,
Wearing a Titoni Cosmo 22 today.
Titoni was a popular brand based in Switzerland but with its primary market in Asia. It seems to be still around but not as popular as before. Their 'Airmaster' line was very popular back in the day and they also have a 'Seascoper' diver model. The early model Seascopers go for good money. I have a later one which I'll post here one of these days.
I believe the original company was 'Felca' which changed its name to Titoni in the early sixties.
I've had this for around 20years now. This watch was brought to me for repair but it would've have cost too much to repair (ETA 2836) as it was badly damaged by water. The owner ended up buying a new watch and this was left with me as he had no use for it. A few years later I managed to get hold of a bunch of movements off the internet and one of these was a running ETA2836. This was serviced and installed in this watch, together with the original Titoni Rotor. The dial and chapter ring were badly damaged. The blue part was touched up a bit by dabbing a sharpie on it. The black parts were the worst and these were refilled with the same sharpie. Hands escaped the carnage and still have the blue line, matching the dial. The seconds hand is not original to the watch, neither is the crown The chapter ring was totally unusable and I sanded it back to bare metal and sprayed it with some silver paint. The sharpie was again pressed into service to draw the hour marks. If I open this watch again I'll re-do it in a darker colour, it's too garish now. I'll probably replace the crown and day-wheel (damaged writing) at the same time.
The case-back has the Titoni Sakura flower deeply embossed.
I've not touched the movement since I serviced it and with a few shakes it was off and running.
It's on an aftermarket bracelet and wears well for a large (@ 37-8mm) watch.
Anilv
Just bought this Buren 17 jewel automatic watch on eBay for $9. Auction stated it wasn't running. When I tore the movement down I noticed  the two dial screws had come loose and jammed up the works. Just took a good cleaning and a polishing to the crystal to make it look almost brand new!
I posted a picture of the Buren watch from the actual auction listing as well.B)
Hi guys,
Anilv
A good looking running watch
Nice watch and strap. Cousins do a nice brown crocodile strap as well
Thanks [emoji106]
I did see theirs but....
• Don't take PayPal
• Take longer than 7 days to send
• More expensive than Vietnam
Sent from my Honor 5c
This is what I have on tonight...
Seiko 7009-3040 - bought it off eBay from thailandsmiles (?). Supposed to be a military model with the secondary hour markers. Keeps great time and has a pretty decent reserve. The crown is really hard to pull out to adjust... I'm certain it needs some cleaning. The lume is extremely limited and pretty faded, and it's extremely light. I almost forget I'm wearing it. I don't know if the folded metal band is original, but it fits the lugs well and looks decent with the watch.
I was scrolling this thread backward so the picture before the description, and immediately wondered how strikingly Thai or perhaps Indian that fake dial looked like :) Take my comment amicably, I was talking to a collector today and he told me that the shiny bullhead for same on ebay are made in Thailand with fixed push buttons... nothing wrong with that, I just hope I will be able to find these wonderful factories myself and post about!
Today, I'm test driving a manual wind 1960's Waltham wristwatch. Swiss made, AS 1803 movement with red date function in a 14k gold filled case.
Service on it was pretty straight forward.. although the stem that was installed was in terrible condition...it was made by someone who didn't do a very good job...
Funny thing is I was going to make a new one but recognize this stem as something I may already have. Turns out that a ETA 2824 stem fits perfectly in this movement. I have a whole batch of those so I didn't have to make one!:jig:
By the way if anyone knows where I can find a replacement plastic Crystal with magnified date for this Waltham watch feel free to let me know!
You can polish the present crystal practically to perfection. Otherwise you can use a generic crystal, and reuse the "cyclop". It's simply glued on and will come off with a bit of heat.
I actually did polished all the scratches out, but there's a couple of small cracks around the edges.  Also, the cyclops is mounted underneath the Crystal and not on top..I'm not so sure I can add heat to a plastic Crystal to try and remove it? If worse comes to worse, i can easily source a plastic Crystal without it. The date is pretty large without the magnifier but I think it's pretty cool looking with it..
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
