Watch of Today
mk3
Bulova Royal Clipper....
I have recently started to gather some watches in the Bulova " Clipper " series . These watches are very affordable and have a Classic look in both round and rectangle shapes .  I really am not sure how many different clippers there are because I am seeing a different clipper name all the time such as Jet Clipper , American , Sun , Sea ,  Golden , Midnight , Ocean , etc............
From what I gather from ongoing research , the Clippers are 17 jewel , but none have a clipper designation on the dial .
This model is called the Royal Clipper and is identifiable by the contrasting quadrant shades . I picked it up on the bay for a small price and it was advertised as having been cleaned and serviced , the crystal refinished , and a new strap .  I knew that the dial looked like it had the measles .
When I got it I had to clean up an excess of lube on the movement , replace the cracked crystal , replace the paper thin cheap strap , and lume the hands because the lume was practically not there . The case back was over polished and showed all the imperfections also . I also took a chance on cleaning up the dial .
I took the liberty of adding a couple of pics from the internet to show what the dial looks like....
And the watch....
Yeah , I cheated and hi-lighted the dial . You couldn't see the quadrants very well ,....and it looks better in person ,..honest .
You can't lie to the camera .
Looks really good
Sent from my SM-T585 using Tapatalk
Maratac GPT-2 with a Miyota 9015 movement. After regulating it with what I learned here it's keeping time dramatically better than what it was.
It's really nice to be able to regulate yourself. Unless the movement is of superb quality and has little variations between different positions, it really matters as the watch could behave differently to different lifestyles.
took the boss out today, second time in a year, trying to keep the original enamel, well, original!
17586683_1708341626130564_34483315314524
You hardly see this Elgin Direct Reading from 1957 with the crest not buffed off the face and you might see one with the red enamel maybe once a year but still having the blue enamel is a rare event!
Wow , That is a very nice watch....  I like the band on it . Is that also original ?
Today I'm wearing this BWC with a Landeron 248. Case, crown, pushers, dial and hands are in terrible condition, but I bought it some weeks ago to service my first chronograph. It was dead on arrival and now it runs well, even the chronograph functions.
Nice story with this: I had a lot of trouble with the minute counter which didn't switch and stopped the watch. As I work as an engineer in the automotive industry, I'm always thinking about geometrical problems. So I spent about 10 hours working on the eccentrics and the jumper to find the correct setting but didn't get it. In the end the solution was dirt in the bearing of the minute counter which caused too high friction. When I told this to my girlfriend she couldn't stop laughing. "Well, you may be a pro in geometrical affairs but cleaning is not your cup of tea." I have really no idea why she said that... B)
  • 4 weeks later...
Got this gmt for £74 off Amazon.
It's not that bad . 300m water resistant and fitted with a TY2846 movement. Not upto eta or seiko but not too bad with a 35 second variation on one position but 5 others with less than 20 seconds. Amplitude a bit on the low side.ca65e21a93d3231d09ac4352cd0c03b3.jpg2738432ccf61e126f599409a6076d5ad.jpg
  • 4 weeks later...
Hi guys! It's been a long time since I've posted here.... I plan on checking in a little more often..
Here's my latest creation that I'm wearing today. I designed the dial after a current Hamilton Khaki model... I posted a picture of the printing plate too!
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
