Poljot 3133 chronograph
GeorgeClarkson
Wow, that's a nice one.  Hopefully that hairspring will straighten up nicely and get the piece up an running again.
I don't think it's a redial although I must admit I'm not an expert on Soviet pieces.  The quality appears to be about equal to what I have seen in pictures of other Sturmanskies.  It looks about right for it's age.
Very nice pickup.  :thumbsu:
Hope you are right....
6 hours ago, GeorgeClarkson said:
This is also my line of thought. I analyzed the pictures of the seller, and it does appear to be exactly like you wrote. Hope we are not both wrong on this, which seems a pretty easy fix to be honest.
To be honest even if the H/S is distorted beyond rescue (which I doubt is the case) it would be far from disastrous as it would appear that replacement could be relatively inexpensive if the link below is representative.
http://www.ebay.co.uk/itm/3133-BALANCE-WHEEL-spring-spare-part-for-chronograph-POLJOT-OKEAN-SHTURMANSKIE-/282305942559?hash=item41babed41f:g:EBEAAOSwNRdX2sEY
And today I received the Sturmanskie... As we thought, the hairspring is pretty badly bent, blocking the balance wheel. The movement was fully wound so I had son difficulty in letting the power loose, since the case is so dirty I am amazed I didn't find micropigs bathing in the lurky oil traces...
The hairspring is be t on the locking pin and throughout the first curve in an unnatural way, sign that someone has tried to adjust the balance wheel but did it in a very clumsy way. I will have to see if I can still fix it.
Another thing I noticed, someone LSO put shims under the balance cock. You can barely see them but they are there. His is also why the screw stands a bit proud: the shims are not correctly placed so the screw touches them. Will have to figure out how to solve this...
Here some sellers pictures of my newly acquired "baby". It's a 1992 Poljot "Sport" with a SU 3133 movement. It's made just before the disintegration of the Soviet Union and still has "Made in USSR" printed on the dial. Shortly after the disintegration, the print was changed to "Made in Russia".
It should be posted today ............ :jig:
Poljot Sport 3133:1981639-1.jpegPoljot Sport 3133:1981639-3.jpegPoljot Sport 3133:1981639-9.jpegPoljot Sport 3133:1981639-8.jpeg
Needless to say, I can't wait !!
Edited by Endeavor
@Watchtime I bought it like that. The pictures are taken by the seller and the watch is currently in transit. I must admit that the movement looks in an amazing shape, for being 25 years old. Studying the pictures, I haven't discovered any irregularities so I hope it is not one of those: "if it is too good to be true, it probably is". If you look on the very informative website: http://www.polmax3133.com/ , on the right-hand side "1992 - 1H", then under "Sport" you see the watch depicted. If you click on "Nuclear", the author makes a remark about how pristine the movement looks, a movement of the same time period.......... so perhaps I'm lucky?
Not knowing the watch history, I go from the assumption that it needs a service. I hope to see the watch in reality by the end of this week / begin next week.........
Good luck with the Poljot - it looks very good. I had a Sturmanskie 3133 a year or two ago. It was a nice watch but the chrono mechanism was getting very sticky and the movement looked a little rough here and there, so I sold it on. Made what I paid for it, so no problem there.
The 3133 is a nice movement.
@WillFly Thanks a lot ;) I looked at Sturmanskies, but in a way I wanted to get a bit away from the "military"-style. I succeeded partly with this "Sport" issue, but (I think) it has a Sturmanskie case. A bit of both worlds :)
I'll post some pictures upon reception (first a test on the Watch-o-Scope) and perhaps later the servicing. Obviously forum member George Clarkson has done already some outstanding 3133 walk-through work.
But first my beaten up Landeron 48, which I hope to receive today. Lets call it "A nice Starter" :)
Landeron 48:2-1.jpeg
So yesterday I set myself up in checking the third Poljot 3133 I had received, this one only for the spare operating lever 8140 and spring 8335 that I needed for the Admiral watch.. And apart the fact the balance wheel assembly is completely missing, there are some other issues as well.... Check the pic... That is the minute runner wheel. Rust ate away the upper part that goes through the dial and onto which you should fix the minute runner hand.
And the  fourth Poljot 3133 "Civil" arrived today, badly packaged inside a simple bubble envelope, bit still intact. Ironically, it sports a Seiko brown leather band.... Anyways it works fine and keeps excellent time from what I could see. No need to service this one, prolly only a light polish on the glass. Here it is side by side with the bigger brother, the Sturmanskie:
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
