orient 46941 regulating
nickpeh
Hi,
I tried to regulate the movement from orient 46941, it seems how slow i tried to adjust the reading still the same and time shown average 3 mins faster in just few minutes. Is it the problem lies on the beat error ? By using this software, beat error showed zero, so I eliminate the idea of that...any advice from u guys?
I am kinda new to watch disassemble, in this pic config will I able to remove the balance bridge assy ? I tried to remove but seems something not releasing from lower area , I am afraid to pull due to the hairspring. Do I need to remove any parts frm dial side to release this balance bridge?
High rate / low amplitude suggests that the h/s coils are fouling up on something.
You said that you have cleaned the h/s; when you reinstalled the balance did the h/s coils sit nice and concentric or were they still bunched up as in your earlier photo?
How did you clean the h/s?
Is the h/s sitting parallel to the balance with proper clearance to the balance arms and the cock?
Have you tried demagnetising it?
53 minutes ago, nickpeh said:
After several hours of regulating , seems cant get the gained rate lowered...wondering what could be the issue.
Something is fowling the hairspring at a guess. Your original post showed a good amplitude and the beat was within tolerance so something has gone wrong since your adjustments.
Is there an easier way to demagnetise?  I soaked in kerosene and leaving it to dry , repositioned it and anchored down.
Clockboy is right.  Raw kerosine is distilled from crude oil can also contain a lot of sulphur and other undesirables so is not suited for cleaning any parts of a watch unless very very dirty with old caked oil (then need to ensure you clean off all the kerosine).  It can though be used as a penetrating oil to ease tight fitted parts.  Rather than use raw kerosine use BBQ lighter liquid fuel as this is basically de-odorised, de-sulphurised and cleaned up kerosine.
Edited by canthus
fact
I did degreased it after soaking in kerosene using solvent, but after detailed inspection, realized hairspring end was slight bent causing the balance wheel unable to stay center. I will get new one to replace.
orient 46941 movement seems no banking pins, so now is it align the balance wheel impulse pin between pallet fork?
  • Similar Content
    • H Watch Repairers—is there is a ‘standard format’ for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches?   Sometimes I can see there might be a reference to year/ month but other times am confused. I’ve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
