Fellow Wrt! What Are You Repairing Currently?
Hi all, so I've been thinking for a couple of months about creating a thread where all of us can share what we are repairing currently. So here it is! Mark maybe you might want to stick this thread so all of us fellow wrt can share what they are repairing? Feel free to post. Anyways here's a couple of pic I took this year.
Ellesse watch. Eta quartz Keyless work kaput, friend ask me to service the watch too.
Citizen miyota 8200 movement. Bought this used watch and it doesn't work. And it missing a caseback glass too. So while I was servicing the movement, found out there's bits of glass fragment in the movement so i assumed the caseback glass had shattered and therefore causes the watch to stop.
Eta 2836 movement. Water damage.
Looks like fun! Btw, how do you wind one of those automatic mainsprings? I have a winder but only used it on a PW mainspring. Now to keep to the subject. Nothing major here. Nice old Waltham that is running nice. Just has a broke stem and waiting on one to get here from the netherlands. Lol
post-1223-0-59437800-1435621709_thumb.jp
Whilst you mention Quartz, here's a few photos of one of my quartz watch restorations.  Luckily I have a great contact at Citizen SC in Germany, so managed to get some rare parts from them to complete this restoration, its my own Aqualand Diver.
15461761666_a3768a1506_z.jpgUntitled by Micky Aldridge, on Flickr
15484511202_a64210d7ed_z.jpgUntitled by Micky Aldridge, on Flickr
15298298007_ef53ef287d_z.jpgUntitled by Micky Aldridge, on Flickr
15297966829_9722bbcce0_z.jpgUntitled by Micky Aldridge, on Flickr
15481731021_83a6fa9c81_z.jpgUntitled by Micky Aldridge, on Flickr
15298424608_9acb330d59_z.jpgUntitled by Micky Aldridge, on Flickr
11238557603_91ee7f923f_k.jpgGerman Aqualand 4 by Micky Aldridge, on Flickr
  • Like 6
Currently i am half way through restoring a Tudor Auto Princess which had attempted to be open by previous owner with wrong tools and then soaked in........yep WD40 GRrrrrrrrrrrrrrr
It may be an oyster case but it is not WD40 proof, as you can see from dial, it needs work. So i am currently waiting to hear back from David Bill......
The movement looked like it was dipped in goop and snot, but luckily the movement cleaned up ok and is running very well considering. I have done about 50% of the case re polish which is looking quite nice. So now i just wait for news if DB can refresh the dial.
Though this past week alone i have done 2 x Omegas PW 1 x Longines PW 1 x Lanco , plus im waiting for tools to finish my antique Omega wristwatch. Never been so busy :)
Oh and SSteel that Aqualand is looking awesome, quartz does not usually do anything for me but the watch is superb, really good job there  :thumbsu:
Hi there bsshog40, I wind the mainspring by hand. Its best to wear finger cots or maybe a glove but for me i wear glove to prevent bits of skin on the mainspring! Its very hard to wind back the spring as a beginner. I've been trying to wind the mainspring since 2012 but recently I've managed to wind it back by hand! Hope this helps :)
It's nice to see all those bits and pieces brings back a few memories. How do you guys keep your bench so clean mine was always in a mess bits of watches and clocks all over the place. When I did have a cleanup which would be about twice a year I could never find anything. I thrived on mess.
This is what I am repairing currently Vauxhall Vectra rear brakes. I heard that ominous scraping sound yesterday so bought and fitted new pads this morning. Luckily it was only the crusty rust out with braking area that touched the metal on the pad, so all is well. :)
Looks like you might need to mill off that lip soon. At least you have a lathe and can do it yourself.
Edited by ro63rto
It wouldn't be the first time. I wouldn't bother these days 'cause they are so cheap.
Got this a while ago.
Needed new crystal, seconds hand 12 marker/dial and setting lever.
Changed crystal.
Bought setting lever.
Bought donor non working watch for needed parts.
Donor watch will also allow me to practice polishing the case/bezel.
Edited by ro63rto
What optics did you use? And the "T" shaped tool, what Bergeon model is that? :D
Cheers,
Bob
Looks the same as my '07 Astra calipers compressing the piston thingies is not a walk in the park.
Isn't that because the rears don't just retract they spin while retracting?
They have to be rotated at the same time they are being pushed back. Either on its own is no good, both action must be done simultaneously. You can buy a tool for it, but there's no fun in that! ;)
By the way, what vehicle do you have the Red Dot disks on?
Yes. There are two pins that locate if I remember correctly. I still have the tool in my shed if you want it geo. I have since changed cars so no longer need it.
Alfa 156 2.0TS
Currently have a Movado Kingmatic on my bench but I've run into a stumbling bock.
I bought this off the net advertised as non-working... fair enough..I've had more successes than failures buying stuff online and the price was quite low as these watches usually fetch high prices (if running that is!).
Sellers pics.. a bit of wear thru on the plating but the dial and hands are ok....
....I really love the design of the winding rotor...
Once received no time wasted ..The movement removed from the case and the auto-winding stuff removed..The plating on these movements is almost like silver or white gold.. nice.
Dialside, calender works, date wheel and hour wheel removed..a lot of wear under the hour wheel? Well the hour wheel does not contact the main-plate so it most be the minute wheel rubbing..
uh-oh..wheres the post for the minute wheel? Major carnage!
Well this is as far as I get with this watch.. now looking at sourcing a donor movement.  These turn up frequently on the net, probably out of watches that have had their gold cases melted down for the metal...just a question of time.
Anil
Edited by anilv
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
