The Joy Of Watch Repair
Which of the following gives you the most ecstatic feeling? [emoji23]
o "One more turn and it's all in!" - winding the mainspring into the barrel by hand
o "Fourth wheel in... Third wheel in... Escapement wheel in... And they are all turning freely! Wee!" - aligning the train gears into their jewels
o "swing please... Swing please... Yes!" - installing and seeing the balance assembly swing into action
o "0s/day...0.0ms...270 degrees... Straight line... Not bad!" - after regulating the watch
o "Such a pretty watch!" - admiring the assembled watch head without strap on wrist while still wearing finger cots
o "You know what? I fixed this myself!" - telling your wife/children/friend your new hobby
o "I can watch all these videos all day!" - gets popcorn and sit in front of the computer to watch Mark's videos
Best feeling...
'the click as the last pivot falls into place'
Worst feeling...
'the click as you tighten down the train bridge screw (means you've broken a pivot)'
'the 'oooHH sh!t' feeling when the watch you're working on hits your lap on the way to the floor'
Anil
Balance in and instant start for me! :)
Same for me !
Nothing is more depressing than doing all the dis-assembly, getting the parts fixed and cleaned, putting it all together and when the balance goes in, nothing happens...
I would have to go with when you drop that balance in and it comes to life on its own..
the worst is finishing up a restored watch and as you rubbing off something on the train bridge with some rodico and your thumb hits the balance and you here a click and realized you just broke your balance staff... I walked away from my shop for a few days after that one..
Id have to agree with Geo, that is always a guilty pleasure for me.
Personally for me its discipline of patience, patience , and more patience. Perfecting each stage and giving my very best efforts & concentration into each part. Hand polishing alone can take days or even weeks, but results are worth it.
I agree! And I should have added that aspect of watch repair. At this stage of acquiring skills, I tend to focus on servicing the movement. But I guess knowing how to handle crystals, watch cases are just as important... And satisfying!
First swing of the balance has to be right up there, but what about that feeling when you finally track down that elusive part after 3 hours on the Internet?
S
I know the feeling! I once had a need for several parts of a movement but had a hard time finding all of them, not to mention the cost has between piling up. But when I saw someone selling the same movement albeit not working and for repair, I gambled and grabbed the item. With my fingers crossed I waited for the movement to arrive, hoping at least the parts I needed are in good condition. Fortunately, the gamble paid off! Happiness!
For me finding the reason for a fault & fixing that fault.  A real sense of achievement :woohoo-jumping-smiley-emoticon:
When a customer would say I've had this watch or clock repaired, I've taken it back many times and it still doesn't work. When you repair the fault and knowing it is going to be satisfactory. That would be one of my best feelings, because you know next time the person wants something repaired there more likely to bring it to you then to take it elsewhere.
That's me too. And when the reading on the timegrapher is perfect after fine tuning the hairspring.
    • I saw mention of the super glue and bolt method on various forums. I wondered if there’d be any problem with that given the watch is titanium. Will the glue or the acetone stain the metal? Titanium is supposed to be resistant to corrosion, but sometimes certain metals react with chemicals unexpectedly.   If it doesn’t stain or scratch the watch and can be completely removed with acetone, the bolt and glue method seems like a clever last resort approach.   However, I don’t think I’m ready to use that method on this watch. The watch is new, and it was a gift, and it wasn't cheap. Also, +10 spd really isn’t that big of a deal. I can just correct it once a week to keep it within a minute of the correct time. If I had a manual wind watch I’d have to wind it more often than every week, so I can think of it that way.   I think neverenoughwatches is right that this is the wrong watch to use to start learning how to repair watches. I think I’ll either buy the Unitas 6498 or a clone to do the watch fix course. I may also get a $200 invicata pro diver with the SW200 movement that I believe is also in the tag heuer aquaracer to start learning watch repair. It uses the “caliber 5” which I believe is just an SW200-1 or ETA 2824-2 with a tag decorated rotor.   How long would you all say it takes to develop basic competence working on mechanical watches? What level does one end up at after doing the first three watch fix courses?   I mentioned in my intro post that I was emboldened to try to regulate the tag watch by my success in swapping out a broken quartz movement on a friends 15 year old fashion watch a month or so ago. It had a Ronda 762 which was available new from Esslinger for $10. I didn’t have the right tools or any experience but I was able to remove the movement, swap the dial and hands, and reassemble the watch to fix it. It appears to work fine now. The only reason I attempted it though was because they were going to throw the watch out, so the risk was really just the $10 for the new movement. The risk on this aquaracer is much higher and probably above my risk threshold.   Also thanks very much for all your suggestions and help. I’ll post some more images of the watch shortly.
    • Thats just the tip of the iceberg, they have no idea of what is yet to come.  When you start grabbing stranger's left hands to turn their wrists to see what watch they are wearing then thats when they need to start worrying. Erm  not that i...ah-hem....have done that.
    • Can you get a top view with power off, balance at rest? The hairspring could be off center just enough that it is touching something when running (center wheel, stud, regulator). Thing is, on older stuff in particular, if you find a balance complete there's about a 99.99% chance the hairspring of the new balance will need some adjustment to work correctly.   Also, not much use getting concerned with the rate until you get the amplitude up.
    • Those pins look awfully tight. Does the hairspring slide freely between them when you adjust the rate?
    • John will ask this question anyway: how did the watch run before your service?
