1 minute ago, jguitron said:
Looks great!!!
Can you show a pic 90 degrees to the one you took?
I couldn’t open the vid. Maybe a Tapatalk issue?
Hi Jguitron,
Sure, here you go, I didn't sharpen like a knife, the tip will be too fragile.
Darak
Looks excellent! How challenging is it and can you reproduce the results reliably? Even on the smallest of drivers?
Thanks for sharing.
JG
Hi Jguitron,
Lansky is known for its easy sharpening system, it’s not challenging at all to sharpen either a screwdriver bit or knife with this kit and I can reproduce the results consistently, you can see the video that I post, I can view the video via the phone, just need to wait, or view it on a PC.
The screwdrivers that I fixed today are 0.6, 0.8, 1.0, 1.2 mm, all come out beautifully, but I need to say, using the Lansky kit are more fiddly, you need to take out the bit from the handle, fix it on the Lansky jig and sharpen it, versus a screwdriver sharpening kit(sharpening stone and screwdriver roller), but the Lansky kit comes with a lot of different stones of your choice and you can sharpen your knife with it.
For my use, because I’m just a hobbies, I don't need to sharpen my screwdriver that often, so the Lansky works great for me, if this hobby become more serious, means need to sharpen them every day, I might buy a professional screwdriver sharpening set, with a lot of different stones.
Darak
I'm not familiar with the tool you are using, but it looks like it is giving good results.
Screwdrivers are more forgiving than knives with shapening, to sharpen my screwdreivers I purchased a 240 grit and 400 grit diamond sharpening plate off ebay for just $3 or $4 each and have one an A&F spring loaded screwdriver holder for sharpening and find that gives me pretty good results.
The most important thing is using your Loupe to check you have inserted the screwdriver correctly before sharpening.
Also if you are removing a chip on the blade you will normally have to hold the blade at 90 degrees to the diamond plate and take a small amount off the end so they screwdriver blade once sharpened to ensure it doesn't bottom out in the screw.
  miniture screw drivers can be nicely "by eye".   it is not "an art",  but the result of a machinest's  apprentiship.   twist drills can aso sharpened "by eye".  i will admit the small ones can be dificult ---- practice.   vin
I tend to just use my "metric calibrated eye",  ;) and of course files/fine grit paper.
You can use one of these, If your eye requires a little more precise calibration.
https://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=2.5mm+metal+Watch+Screwdriver+Sharpener+Sharpen+Watchmaker+Repair&_sop=15
They do work, but you will still end up finishing by hand/eye with good magnification, and obviously they only work with straight blades, so not much use for drill sharpening or cross headed drivers.
19 hours ago, Darak said:
My nice Bergeon screwdriver set was chipped after few watch services,
I recall a fairly recent topic which where some was saying that Bergeon screwdriver had become worse and worse with time. We got the proof here.
Sharpening is a science and an industry. Trivia facts follow
Drill_Point_Geometry_nt.pdf
Edited by jdm
  • 3 months later...
In school we uses this one, also to make hollow blades on a screw driver.
https://www.beco-technic.com/werkzeuge-verbrauchsartikel/schraubendreher/zubehoer-fuer-schraubendreher/schleifwerkzeug-fuer-schraubendreherklingen/schleifwerkzeug-profi-fuer-schraubendreherklingen.html
But is very expansive.
This one is cheaper, but don't know if you can use it on al screwdrivers from the Bergeon set, because it only have 3 holders.
https://www.cousinsuk.com/product/screwdriver-sharpener-tool-horotec
But this is wat you really need:
Edited by Koen
On 10/3/2018 at 2:57 PM, Tmuir said:
Hollow ground screwdrivers are really only of use if you work on the same model of watch all the time.
The reason is if your flat ground screwdriver is too thin you just stone a tiny bit off the end to make it fatter.
On a hollow ground screwdriver you need to remove a lot more material to make it fatter, and then hollow grind it again to suit the screw you want to undo, so its harder to swap between brands of watches that you need to adjust your screwdrivers for.
If you worked as an 'in house' watch repairer of an expensive brand of watches, and always did the same movements then hollow ground is the best, but for most of us that works on what ever watch comes our way the flat ground is best being a compromise between time taken to reshape screwedrivers and the risk to 'chewing' screws.
I agree. From what I know, The British Horological Institute and watchmaker schools in the Netherlands teach to work on watches with flat ground screwdrivers.
Hollow ground is useful for screws made of a softer metal such as gold and convex screws that you sometimes see in older watches and also sometimes used as case screws.
The first thing we do in the watch corse is make all students screwdrivers hollow... ;-)
Edited by Koen
Well because with hollow screwdrivers, you have more grip the teacher say ( Omega service center ) and les chance to slip away or to damage screws...
You don't want to damage movements, especially now with open case backs. But thats what we learn the first lesson, I am only the pianist. ;-)
I have never heard such tommy rot. I well dressed screw driver blade and the correct size for the screw and you need a steady hand is all that is needed. The more expansive screwdrivers have a easier rotation in the fingers then cheap ones.
See above the good postings by Tmuir and measuretwice. Parallel blades drivers aren't given that much importance, for whatever the right and wrong reasons. Good that you are being exposed to comparison at school so you can base your own judgment, I want to do the same.
Edited by jdm
What is a hollow screwdriver?
Sent from my GT-N5110 using Tapatalk
I also find it odd to immediately have everyone's screwdrivers hollowed.
A friend of mine is also an Omega certified watchmaker but has never used a parallel blade in his life. The same goes for Anthony from NoBSwatchmaker, who's certified for Rolex, Breitling, JLC, and Omega.
No doubt that parallel blades are useful in some cases but it sounds like a personal thing from the teacher.
*edit The great George Daniels was also all about flat ground screwdrivers.
Edited by Nutiborskoku
Like I say, I am only the pianist.
But hey every body will have there thought about something... Only time will tell my experience... but for now I am a rookie and just follow the pack. ;-)
But I can understand the point that hollow blades fit better in the screws and so you wont damage them.
Again, what is a hollow blade
Quite normal in watchmaking schools, one have to do a lot of filing and tool making before undertaking actual horology subjects.
Good for building dexterity and machinist skills but really there is whole lot more than that to make, at least, a good repairer.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
