Water damage cannot loosen detent screw
This is a Bulova 11ALACD that had water damage.  Part of a bunch of old watches I inherited.  Step one is to remove the stem but I cannot because the detent screw is stuck.  I am scratching my head regarding a solution.  Drill it out?  Dicey.  I have applied power to the train wheels and the balance takes off, so I know there is hope for this movement.  The hands are essentially gone.  The dial is potentially salvageable but more likely needs refinishing.
Nothing invested in this, but it is a nice movement.  I can buy a new case for it and somehow solve the hands, but I gotta get it out of the case.
I dont think the current case is worth keeping, so a Dremel may be in order.
Any ideas?
Any ideas?
Need pictures to really understand the problem.
Any ideas?
I already drew a good picture in my head and, possibly, have some ideas, but need to see your watch first (please?).
Do you have a pin vice with a thicker handle than your screwdrivers?  You could put your screwdriver blade in that (if removable) and the thicker handle imparts greater leverage.  It often works for me.
I also put a bit of thinner watch oil on it first, and let it seep in.  Then I have a go.
Yes, I have many pin vices.  The torque amplitude might solve it.  I will give that some thought.
I apply penetrating oil to the release botton, remove the winder module with rotor attached then ratchet wheel, let oil set overnight, removing barrel bridge is then a lot easier and less risky that trying to force thing. You can remove bunch of other parts as well with the movenet still inside the case.
You would then gain access to parts inside which may have gotten rusty as well, also see if you can remove the crown off of stem which would let you slide the stem through stem tube.
DO NOT FORCE ANY PART.
Hmm… looking at the picture it looks like a setting lever button rather than a setting lever screw? I'd follow @Nucejoe's advice.
That's generally a very sound advice. Unless you're 100 % sure the energy from the force is going to land exactly where you intend it to, force usually spells disaster.
My thoughts exactly - doesn't look like it takes a screwdriver, only a round-ended tool to press it with.
OK, some great advice.  My dad would always tell me, "If it don't move, don't force it."  I will abide by that.
It is a screw not a push pin.  I think I referred to it as a detent which is a term normally applied to push pin type I think (I am rusty on all the correct terms).
I will remove the auto winding mechanism and apply the penetrating oil and see what happens.
It's a good plan to start removing the oscillating weight and the rest of auto-winding mechanism, and the balance, etc, etc. Please note that on some Bulova movements you need to loosen that screw just by one turn or less and then push it down with the same screwdriver while slightly rotating and pulling out the stem / crown.
OK, here it is with auto wind, balance wheel and pallet fork removed (latter for safety!).
As you can see...it is a mess.  Water came in through the crown where you see the most damage.
Suggestions for penetrating oil?  All I have around here presently is WD40 (I think).
Poljot: where did you find the parts list?  I was searching this morning without success.
https://www.cousinsuk.com/PDF/categories/2170_Bulova 11ALA etc.pdf
Nucejo and the others are right to loudly state the above.  So I feel it necessary to clarify my earlier statement.  I sometimes resort to putting my screwdriver blades in a pin vice only for the following reasons:
1 - the handles they came with are so slender (perhaps more than most) that with many screws, I can get no real torque at all. I don't know if all watchmaker's screwdrivers are this slender but I plan to see if I can get thicker ones.  My long, spindly fingers are having trouble with them. I also make sure that I...
2 - always oil the screw in question with the thinnest oil I have, and...
3 - know which way the screw turns.  There are only a couple reasons, on a couple kinds of parts (such as a crown wheel) that a screw would turn counterclockwise, so this is not the biggest concern...unless that's what you're working on.
4 - I can generally replace that screw with a much less rusty one from my screw bins.
So to quantify: if you're gently turning the screwdriver blade, inserted into a slightly larger handle, you do get a bit of a leverage advantage, so you must be even more cautious.  If you can sense it still doesn't want to move yet, cranking down on it even harder can do damage (no surprise there I'm sure).  I have not snapped a screw head off yet myself, but I know it happens.  Somewhere in the forum are a few posts about techniques for removing broken screw shanks from their holes, and some tools designed for that purpose.  Those who've never done it should pray they don't need to.  But it's good to read about it anyway.
Really? ?
Aren't we "forcing" every screw while removing or installing it? Aren't we forcing a crystal into bezel? Just saying..
DO NOT FORCE ANY PART. perhaps force it a little? ?
Edited by Poljot
  • Haha 2
7 minutes ago, Poljot said:
Really? ?
Aren't we "forcing" every screw while removing or installing it? Aren't we forcing the crystals into bezel? Just saying..
Ha ha,    ?
  Whenever a screw doesn't want to come out, offer it some cocacola it will.
I just drop ( some calibers) in cocacola to soak over night, ends breaking screws, try it,
remove balance and incab jewels, drop the rest in coke, specially useful for old rusted watches.
16 minutes ago, Nucejoe said:
Ha ha,    ?
Some claim that coke is excellent toilet-cleaner. I never tried as i was afraid it could permanently damage it... Dangerous stuff! However, i tried coke on a smaller scale - dropped one cent in it to soak for several minutes. WOW! It was shiny as new!
White distilled vinegar works wonders too.  If a steel screw shows signs of being rusted in place, I'll remove and set aside the balance and pallet lever, and dunk that section in vinegar.  Wouldn't try it on quartz movements though.  But mechanical ones could benefit.
Ok now, remove the ratchet wheel and barrel bridge, you then see and gain direct access to the stem and can do lot more. So far so good.
If you can remove the dial, date/ day ring and balance and balance jewels, drop the rest coke, no damage whatsoever by coke 24-48 hrs. then a tooth brush and powedered detergent cleans perfect.
I disagree with vinegar for it will damage gears and most any part if soaked for long.
The same goes for Omega calibre 268 (and likely several other calibres) which had me puzzled for a while.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
