New RAF style dial creation
Thank you for the reply! Here are the photos you asked for. Please do let me know if you need any more photos or information. Thank you again for the help. Sorry, I forgot to quote you. The pictures are above. Thank you
I was using the Bergeon 4040P holder ( the movement kept slipping from a tight hold) and I think I pushed the balance wheel and spring out of horizontal when I tried tightening the movement to the holder. I have since bought the metal 4040 holder which holds great. From the video can I just pry the balance wheel back to horizontal as well as the hairspring? Caravelle 11DP balance wheel video
I would suspect it to keep the oil from spreading as much as it otherwise would w/o epilame, even when subjected to rubbing by another part, such as the escape wheel teeth rubbing on the impulse face of the pallet jewels.
I think it should be between the red and black. Couple of things to take into consideration, the spring could be set affecting the power reserve or a shorter spring with will have the same effect.
