Roger Smith's Heating Apparatus
SparkyLB
I'm watching the 10-part "Hand Finishing" series of videos for the 50th or so time; something of which I can't seem to get enough.  Would the forum be so kind and tell me what the white honeycomb-looking mineral(?) is that he uses to protect his table from the heat of his torch?
I know bricks would work fine, but I'm curious.  If it's available to me, I'm going to acquire some.
I'm going to give hands a try.
2 hours ago, nickelsilver said:
I haven't seen the video but there used to be asbestos pads for torch work which were replaced by another mineral later on. He probably has an old school asbestos pad or modern equivalent.
Thank you, nickelsilver.
In case you're interested, it's at 50 seconds in.  Don't blame me if you become attached to these 10 short videos!  :)
I liked how he heated a brass block to indirectly blue the hands. I also appreciated it when he admitted to not getting the colour correct on one of the hands. That’s always a bummer. I think you’d be more likely to get consistent heating by using brass filings, but the visibility is inferior compared to his method.
Agreed, since is not as efficient holding onto heat as cast iron or copper; there's more of a gradient.  This would cause brass heated from one side to always be much hotter where the flame is.  I like how Roger never brings flame close to metal to be blued.  Seems that Roger Smith's intention is to move the piece about such that the finished product can be as uniform as possible.  He admits the improbability of bluing 3 hands identically.  It's a learned skill, but what isn't?
As for the bed of shavings offering inferior visibility, this seems like a large part of the equation.  If you watch, the color starts on the bottom and rises quite fast to the top.  If embedded in shavings, one might very easily miss this transition.
One of my horology tutors used to blue steel over a naked flame. I can’t remember the correct term for it, but he was very good at it. The key is to be very gradual, so you sweep through quickly so that the colour doesn’t progress much at a time.
I believe bluing of parts etc was done over a spirit lamp aka  Donald De Carles book , as its easier to control the process.  Some years ago I watched a TV programme on Roger Smith from his workshop on the Isle of Man  the  man is a Genius in the watch making world , Hand build chronometers brilliant.
As regards the heat pads  There used to be asbestos from storage heaters, the modern ones Fischer I believe use the ceramic pads so a source there if you are looking for some, but keep the asbestos bagged up and dampen before use.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
