ETA cal. 2824-2 (17 jewels) disassembly/assembly
I have no experience of Rolex, but that doesn't seem normal. Do you know about the history of this watch? The barrel appears to have been dry for a long time, judging by the wear on the inside of the lid. In any case, it needs a good clean and fresh grease.
The problem/challenge with these things is that you don't know what brilliant solutions previous watch-tinkerers have come up with. Are all parts even "original"? Did the watch run ok (-ish) when you got it? One possibility is that a replacement staff has been fitted and turned out to be a loose fit. Some of this has been discussed in the following thread:
@GuyMontag good find! Even the micro stellas are cloned in the Daytona fake! Around $2600 is mentioned in the thread. https://www.reddit.com/media?url=https%3A%2F%2Fpreview.redd.it%2Fnewest-development-from-ace-v0-61r4zxq1q2xd1.jpeg%3Fwidth%3D1080%26format%3Dpjpg%26auto%3Dwebp%26s%3Dd5dd3a29a3d1668077d4a4c894a09c76f6f66de9
See I wondered about this because Frei only lists one part for 18 size, no left or right options whereas they specify left and right for the other sizes. (I happen to be working on a grade 88) I recall seeing an old video of Elgin making laps and jewels in the factory (maybe you were the one who shared it) I have one very weird warming tool which has springy jaws that can open wide enough to hold this type of fork flat, and it swivels so you can position either side over the heat source. It works great for melting shellac on a firmly held fork EXCEPT can you guess what its fatal design flaw is?.... ....you cannot open the springy clamp once it has been heated because you would need to pinch them both between your fingers and you get a second degree burn. Genius.
The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge. One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran. Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound. From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones. Elgin watch company Escapement Terminology.PDF
