Enlarge pocket watch roller hole ?
I have a pocket watch that required a balance staff replacement. I've bought a NOS original one. The length fits, I even mounted it onto the balance and then onto the movement and everything checked out.
Upon trying to fit the roller I realized that it wouldn't fit. From research they made 2 versions of either balances or balance staffs or I don't know what exactly but the bottom line is that all parts are genuine, it's just that I have the roller or staff from one version and the rest from the other version (the hairspring collet also fits so only the roller hole is the issue).
You can't really find these parts and I don't want to invest anymore so I was wondering if it would be possible to simply enlarge the roller hole.
I don't have a lathe but I have ordered some mini-drills that come in all sorts of useful sizes. I would have to enlarge the hole by about 0.8mm.
It would have been helpful if I could find a really thin file to do this or maybe use some sort of a wire that behaves like a file but I doubt it.
Thoughts ? Suggestions ?
The pocket watch isn't an expensive or special one by the way so that's why I'd like to give it a go rather than invest a lot of money.
6 minutes ago, Chopin said:
Oh this is exactly what I'm looking for, I think.
Are these basically "needles" with a texture similar to that of a file ? I can't find a close-up shot.
No broaches are five sided each side is a cutting face you insert and twist and the faces cut as you do so, they must be used at a perfect 90 degree angle to cut a perfectly centred hole, similar broaches are used in jewelling tools to enlarge jewel holes, the German ones that Cousins sell are cheaper than Bergeon and are very good the Indian ones I would give a wide berth.
1 hour ago, oldhippy said:
Perhaps I should have said watch movement holder.
Chopin was asking about a way to hold a balance roller. Can't use a mov.t holder for that.
The roller is very small. These holders have too large gaps to actually hold the roller.
I could use a normal vise (I have a small one) but it's hard to keep a round disk in place with a vise especially since, if at some point the roller moves or jumps out of the vise jaws I might damage it or break the roller jewel itself.
I'll figure something out I guess. Was thinking of making a hole in a cork screw or maybe a piece of wood (this one might be a bit more complicated...) but it still wouldn't really hold the roller in place if I want to drill the hole.
Opening a roller by 0.80mm is a lot, and it looks like a steel roller so going will be tough with a broach. Possible you don’t have the wall thickness to take that out even provided you have a good way to hold the roller and some buttkickin broaches. Best would be to turn down the staff.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
