Ronda Rotor Removal
Hello!
My first question / project as a new member:
I have a watch with a Ronda 4438, or perhaps 4439 automatic movement. The rotor has considerable play due to wear. I have been unsuccessful at finding information about the proper rotor removal method. Referring to the attached photo - I have identified the two stake marks at the rotor hub, but I do not see any retaining components or clips (perhaps the component that I marked with arrow?).
Any guidance would be much appreciated!    Cheers, Neil5a453d9e00768_Ronda4438.thumb.jpg.baf5d8e242141eb829d27d46f85891d8.jpg
4 minutes ago, Ishima said:
No experience with this particular movement but you should be able to loosen a screw on the auto bridge near the part you highlighted, then pull that part out into a position that releases the rotor.
Think so to. Take care not dropping the screw down into the balance .
58 minutes ago, Chopin said:
That screw might do it but you could just unscrew the plate onto which the rotor is attached to and underneath you'll probably see how the rotor is removed.
Agreed, this too would be my plan of attack. More than likely fastened from the underside with a countersunk screw.
  • 9 months later...
Ronda is a giant old timer in horology with darn good desgns.
I would remove the rotor/ winder assembly for the sake of the ballance etc.
It is self expalnatory once you see it. You be surprised of perfection in such an inexpensive watch.
Regards joe
Normally with Ronda you can find tech sheets even with their really really cheap quartz watches they'll usually be something. For this there is almost nothing? There are other people in other discussion groups asking the same questions. About all I could find out was it's really cheap and it was really cheap before quartz watches came in and wiped out the really cheap mechanical watches.
Then as a new member are you new to watch repair or just new to the group? Because if you're new to watch repair this really shouldn't be Your first watch to work on. One of the problems with really cheap watches especially cheap mechanical watches are even though there are screws they weren't always meant to be disassembled and repaired. So they usually present interesting challenges not usually found on Better watches that were meant to be serviced.
https://17jewels.info/movements/r/ronda/ronda-4139/
  • Similar Content
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
