Not certain whether this string is about jewel inspection or about buying optics, but on the subject of jewels:
  • Important that jewels be clean before inspection.  Catastrophic problems will be obvious even in dirty jewels but small cracks and chips are easily obscured by grime.  Also in dirty jewels small fibers or odd reflections are easily mistaken for jewel problems when they're not.  [See image: dirty PW jewel through at 30X magnification.]
  • Agree microscope is the cat's meow for inspecting jewels.  I use a Swift Stereo 80 binocular inspection scope I bought on EBay for $100 delivered.  Turns out there are lots of similar scopes available equally cheap.  I've used this microscope every day since I bought it.  So useful for inspecting jewels, for oiling (especially pallets), and for all kinds of quick inspections.  Buy one.  You won't regret it!
  • Before I bought the stereo inspection scope I used a biologic scope.  Don't make that mistake.  You may be able to visualize a part using a biologic scope, but lighting, positioning, focal distance are all very awkward.  Get a stereo inspection scope with built-in lighting in the column and the stage.  It's the right tool!  Digital scopes may also be a solution, but I have no experience with them.  Others here may care to comment.
  • If microscope is out of budget, in my experience, next best option is a quality hand held loupe in 12x to 15x range (a "Hastings Triplet" type for example.) For around $30 you get high magnification, clear image, and good mobility.  Belomo is a quality brand made in former Soviet bloc and available cheaper than quality German or Swiss options.
  • But don't assume that more is better.  I have 20X hand loupe.  It's powerful, but focal distance is down around 4mm and depth of field is extremely small.  Both factors limit its usefulness.
As to OP's question about sourcing American PW jewels, finding parts, especially old fragile parts, is one of the greatest limiting factors in watch repair these days.  You can't just order old PW jewels from a supply house.  My best luck has been scavenging "for parts or repair" scrap movements offered cheap on eBay or on Dave's Watch Parts.  Perhaps others may have better ideas?
On 3/7/2021 at 10:15 AM, watchweasol said:
Agreed the clip on is not the best but adequate
I dedicate a pair of glasses when doing watch work.  On those glasses, I wrap electrical tape (any tape) around the area where the clip attaches.  This provides much greater volume to grab with the clip.  I have been pretty happy with it.  I have one that I inherited that is the genuine vintage style.  The clip on it is a rotating clip.  I find it to be a little cumbersome, so I do not use it.  These are just fine.  I just ordered a stronger one today.
i've got all the numbers from bergeon 4/3/2/1 (without the halfs). Though, i usually work with # 4 or 3.
(i prefer bergeon for its quality)
As for oiling works and good inspection, i use x15 and x12 with or without automatic oiler.
After all, it is reasonable that in oder for someone to do a good job, they have to be able to have a clear picture of the movement's daily operation.
I have a cheap 10x loupe that works well for me. I thought I would splurge and buy a Bausch and Lome 1” 10x. I, literally, can’t use it. I can focus on one tiny spot in the middle and the rest is severely blurred.
Anybody else had this problem? Any suggestions for a brand that allows full field clarity? Bergeron?
Is your Bausch & Lomb a twin lens, compound loupe?
Some of the cheap loupes use an ambiguous magnification factor. I have a China loupe that has 3 interchangeable lenses. A 5x, 10x and 20x. The 5x is like my 2.5x loupe. And the 20x is no where near my 7x Bausch & Lomb.
The twin lens loupes have a very short working distance and a small field of view. I use them mainly for inspection work only as my nose is practically touching the work piece.
I guess magnification is a matter of personal preference. What works for me might not work for you. And I think many of us are still searching for the perfect solution. Magnification is addictive. It's never enough. (Ok. Maybe a 45x stereo microscope might be enough.)
So go out there and try as many as possible without breaking your bank. Good luck.
It is the lower priced one, about $16. Single glass. I assumed it would be full field optical clarity. Not even close. My $6 one labeled “India” works well for me. I’ll stick with that. I’m curious if the $160 one would provide full-fueld viewing clarity?
I can’t imagine anyone being pleased with only 10% of the available viewing area clear.
All loupes will have a sort of blurry "halo" around the view, but will have a usable inner area. With high power loupes, that's anything 10x and over, everything gets smaller, working distance, and field of view. I use Asco loupes at 10x and 12x, above that I just go to the microscope. I have both aplanetic and achromatic Ascos, the field of view is the same, as I understand the achromats are aplanetic with the addition of color correctness (good for working with gemstones); they have a decent field of view, and a noticable blurry halo. These loupes have a lens size of about 13mm. I have an old 10x around here that's "normal" size, like 20-something mm, most of its field of view is useless, and what is in more or less focus doesn't come close to comparing with the Ascos.
It's been said numerous times, but in general you want to stay under 5x for normal work, really around 3x would be best, as you will be straining your eye much more with the less forgiving higher power. In my opinion a decent binocular microscope with a range of about 7x-30x is an absolute essential, as essential as screwdrivers and tweezers. When you need more power, go to the scope; when you can't go to the scope (something on the lathe etc.) then use the high powers as needed, but they will never compare to a scope, at any price.
  • 10 months later...
I have one...bought it for electronics SMD assembly long ago.
For those who use microscopes...they must not be using them on traditional watch benches, no?  Too high...at least in my configuration.  Maybe if I got a stool rather than a chair for when using the microscope it would make sense.  Right now, the microscope is on my electronics bench which is only 28" high versus my watch benches which are about 40" high.
I never really understood why poeple would go for any magnification under 20x. I started of with the usual 5x, 10x, 15x.  but realized that im not satisfied with the magnification level so I bought a x20 and man was that better. Nowadays I mostly dont use my loupes anymore when working on my projects except when instecting gear teeth or jewels for imperfections.
Because strong magnification is good only for inspection or ultra-small work, and for these a stereo microscope is better. One can't don't general work with strong magnification, because the focal distance, field depth, and field width are too small.
Possibly because you're short-sighted (myopia), and that's a blessing for watchmaking. But a large majority of people, especially at mature age can't focus on nearby objects (presbyopia), and need a vision aid under all conditions.
I really hate my eye sight at the moment long distance glasses are a waste of time unless I need to read subtitles on the TV and my reading glasses are ok but if I need to pick a pen of the desk I need to remove them.
I have a good loupe 10x but struggle to focus when it worn like a optic (in the eye) I have a clip on 5x that falls off my reading glasses as my glasses have frames that are to thick. I have ordered so of these to try https://www.cousinsuk.com/product/watchmakers-loupes-cousins-double watch maker double's I also have a set of these https://www.amazon.co.uk/RIGHTWELL-Headband-Magnifier-Led-Lights/dp/B01GTF06PS/ref=pd_day0_sccl_1/258-7200769-0422933?pd_rd_w=z7am7&pf_rd_p=8ec13b8a-30d2-48fc-8503-84c56766370d&pf_rd_r=07628JCSZS27BFTBPPCG&pd_rd_r=d1dd052d-7456-4295-8e9a-18c92d024e12&pd_rd_wg=R3nE9&pd_rd_i=B01GTF06PS&psc=1 however they work well but find they don't have the strength required for watch repairs and general watch strip down I will let you know how I get on when they arrive.
I gave up photography because I didn't like the way my vision was going. I couldn't rely on it.
Quote
Best way to keep the eyeglass is a wire headband. Done working just pull it up, and it will be ready when starting again. No effort by facial muscles to keep it in place and can't fall. Wearable on top of glasses if these are needed. Raise head, other eye keeps normal vision to identify objects and people around.
It's something almost always present the head of watchmakers in pictures. There is a reason why good old ways are still the better ones. All the rest are IMHO useless contraptions.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
