Hello once again.
I want to buy a Canon Pinion Remover and I'm contemplating which of the following two (or else), is better to buy. Your opinions and advice are much appreciated.
43 minutes ago, PJA said:
Hello once again.
For which purpose specifically? Not many movements need one. A nail clipper can also work.
I get by with the presto type one shown but if i came across a used one of the type pictured above (first one) i would grab it as i wouldn't imagine there's much it couldn't remove
Edited by Andyclient
Thank you all. I will be looking for the top tool and in the case I might need it I will try a nail clipper or my Chinese hand tool version, whichever will work better.
No specific use right now, but I figured that I should have it in case I may need it.
Edited by PJA
With that approach the first thing you'd need would be a large tool case :biggrin:
Earlier the 7S26 and large small seconds calibers were mentioned. Neither one needs a pinion puller.
Thank you. I tell you. What do I know? I read and watch videos online and as far as I understood is that I'll need this tool amongst others, but now after you make me aware of the fact that I really won't have to really buy it, at least not at the beginning of learning, it will help me putting more financial efforts somewhere else.
The top one is the best IF you can purchase a vintage version. The reason is for some reason Bergeon changed the design and as result the new one's do not work with the small cannon pinions.
A normal presto hand remover can be used as well, you just have pinch at the bottom to keep enough grip as you compress the sides to lift. (I believe the credit for that tip goes to mark though I cannot remember for sure)
I'd like to echo concerns I've heard from more than one senior watchmaker, of which I respect (again, I think one was mark) about pulling directly up, which can be difficult with improvised tools like pin vices and nail clippers. You run the risk of damage if by errant twitch you pull to the side and not directly up.
Edited by Ishima
It really depends on what you're getting into as time goes by. On larger movements you can even use hand levers but keep that lift vertical !
Nailclippers concern me as you may squeeze and pull at the same time which could severely damage the pinion. But they are a great "Lazy" way of tightening a pinion whilst still attached.
I've come across several movements where accessing the pinion base has been difficult and the above pictured Bergeon tool has been the only effective way to remove it.
As for the second photo. I just regard these as a waste of money if only even cheap but they do make good crown pullers, if you're dealing with a split stem.
As for buying tools in case you may need them (Excellent Philosophy) definitely buy yourself a large tool box but don't let the Mrs know what you're up too [emoji16]
Sent from my SM-T585 using Tapatalk
Newbie poster here. I have the vintage version and I have found it works well for pocket-watches and wrist-watches. The fibre tip doesn't mar the pillar-plate, etc. And it has a nice straight pull. This is probably more important with wrist-watches than with pocket-watches, but it's surely always a good policy. I'll attach a scan of the promo/instructions that came with it. Maybe a search under the name "M-C Cannon-pinion Remover" will get you some results? Good luck.
While we're talking cannon pinions. This is a must for that gigantic tool box. It's basically a fancy pair of nail clippers with a micro adjuster. Made by Bergeon and comes with a fancy price. It's the best tool I've ever used for tightening cannon pinions and in my opinion, more accurate than using a staking set.735810842ba9fdcbcf2c1c0e21417fe1.jpg
Also my preferred tool for tightening cannon pinions.
I purchased a set of end cutters for about £5, drilled and tapped M5 and fitted a cap screw, job done!
Edited by Geo
As for buying tools in case you may need them (Excellent Philosophy) definitely buy yourself a large tool box but don't let the Mrs know what you're up too emoji16.png
At this point of the game I am really into wrist watches and as time and experience progress, I guess I'll see where things will lead me too. As for the nail clipper, your point is well taken and for the toolbox, I am definitely not into the tools for the sake of tools collecting as you can imagine, but since I have no knowledge I gathered from reading here and there that it's an important part of the standard toolbox.
Thanks for the advice.
That's brilliant. Wish I had thought of it
  • 10 months later...
1
I'd really like to understand how the two screw handles work. Why not just one screw? I actually feel a bit embarrassed to ask as it's probably obvious to "handy people". Actually, I've been trying to find a video or some documentation/illustrations but haven't been able to find anything really useful.
I can just guess. a) Put the cannon pinion on the shaft of for example an old oiler. b) Pinch the pliers at the dent in the pinion, and at first resistance screw in the screw in the pliers until you feel a slight resistance (Hm... will I be needing a third hand for that?). c) Screw back "a bit" and pinch! d) Done? No, I really can't vision it...
Anyone, please? Thanks!
EDIT: Or... pinch the pinion while seated on the arbor of the centre wheel? Hm... No... probably not...
Edited by VWatchie
  • 4 months later...
Mark Lovic demonstrates exactly how to use the Bergeon cannon pinion tightener tool at watchreapirlessons.com, part 3 (Fault finding). Wonderful! :woohoo-jumping-smiley-emoticon:
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
