How to remove stuck Cannon Pinion
Tmuir
Tonight I've been dismantling a 1920s AS movement for a ladies watch in a silver case.
Other than needing a good clean it doesn't seen in too bad condition, but I can't remove the cannon pinion.
My cannon pinion remove cant shift it, and neither can I using a Pin vice.
What do people do to help free up tight cannon pinions as I'm worried if I just use more force I will damage it?
By penetrating oil do you mean something like the dreaded WD40, or INOX, or is there something more appropriate for watches?
I don't think I'm ready to try the nippers approach yet.
No never use that muck. I my days you could buy 3 in 1 penetrating oil.
Avoid wd40 and other automotive products of similar ilk as they have wax in them!    Use the thinnest oil you have available and warm it a bit before you put it on (better even soak the plate and pinion in a pot), you may have to leave awhile.  Could also use kerosine (parrafin oil) or BBQ lighter fuel as these are very thin and will act like a penetrating oil.  Proprietary penetrating oils will work if they do not contain a wax (for waterproofing) but are more expensive as they normally contain corrosion inhibitors as well.  These inhibitors may also convert any rust and make the matter worse on such a small item!!  It is probably just tight due to old solidified oil or grease and this will need to be softened.
Did you try this type of cannon pinion remover ?
23 hours ago, Mark said:
Is the train wheel bridge off? I can't see from the pics.
The wheel bridge was off in the photo.
For Noirrac1j, yes I have a cannon pinion remover and that couldn't shift it.
After leaving a drop of oil on it for 24 hours it still didn't shift so I refitted the bridge and cleaned it without removing the cannon pinion.
Is the cannon pinion free to turn on the shaft of the center wheel? If not, how do you intend to set the time? If it is free to turn, it should come off. I have used hairspring collet levers or hand removing levers to pull tough ones. If it is tight, anything that tends to pinch it will only make it harder to remove. The suggestion to tap the end of the centerwheel is also a good idea as long as you don't damage it.
Absolutely your choice but I cannot stress enough (for other people who may read this thread) how bad of an idea this is. A cannon pinion un-lubricated will cause the watch to stop or worse damage the escapement if the hands are set.
For every problem there is a solution and that is the job of the watch repairer to solve.
If the pinion cannot be extracted easily then it must be removed carefully by force. This may be a job for someone who has experience with this but it does need to be done for sure.
Do not leave it like that.
I totally agree.
Hi Tmuir, just checking it is not the taper pin type, where no matter how hard you pull it will not come off. You need to tap the centre pin out from the cannon pinion side
No. It's not. That's why I asked if he had removed the train bridge. He answered that he had and so it is not the taper pin style otherwise the bridge would not have come away.
Failed, I must not of had even pressure  when levering and broke the centre wheel shaft.
I managed to remove the broken shaft from the cannon pinion on my staking set, lesson learnt I will use my staking set rather than leavers next time I can remove the cannon pinion via regular means.
Can anyone identify the calibre of the movement?
I can see the bridges are different, but the placement of everything else is the same as the AS340 and if possible I would like to try and find a new centre wheel for the movement
I have a calibre 340 10.5L in the parts bin but its much later in the production run than yours and dates from 1936. There seem to be a number of differences but its pretty closeIMG_2556.thumb.JPG.cd17119f9f89ae4d70fd07b9dccabd70.JPG
I'm about to place an order to cousins for other items and they still have AS340 center wheels in stock in stock for a few pounds, so I will take my chances and order one.
This is why I still only practice on 'cheap' movements so my mistakes aren't too costly.
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
    • Hello As I am learning, does anyone have any recommendations  on Repair and sourcing in Gold Coast, Qld, Australia ? eg old Seiko coil 4002920 Thanks. Cheers, Ken
    • Is this what all you're looking for?
