How the heck do you get rid of dust on crystal (inside)
Please tell me, how can you effectively remove the dust particle completely? I found that it's almost impossible, I used air, clothes that should attract dust bla bla but there's always some micro particle saying hello from there. What is the spell??
Clean Rodico can be used, but it also leaves a very light smear. I create a very thin cone of it, and then dab the final pieces of dust.
Can sometimes use pure water (plus a blower to get rid of beads of water when drying).
3 hours ago, chriz74 said:
I cleaned it with water but if you dry it with a dryer water will leave shrouds
Clean with water, blow what water you can off, dry it, then with a cotton rag rub over it to remove any water stains. You can buy microfibre cloths and other expensive ones but a bit of clean cotton shirt will work just as well for removing water stains. Any bits of dust that do appear off cloth will then blow straight off.
If it's glass, I use isopropyl alcohol with a glass cleaning microfibre to remove grease/dirt.
Then I spritz with distilled water to collect any leftover fibres, blow dry with a compressed air can to remove majority of water then finish off with hairdryer.
Sent from my Honor 5c
What I find useful, are a set of fine brushes I bought in the poundshop--the sets women use for doing nail painting, included in this set is a very fine fan shaped one just about right for crystal inner surface combined with an air-blower bulb, about £3 from ebay to do the dial and crystal/case before refitting. Since Ive had these, not had any issues with fibres or specks in/on the dial/crystal
Watch tools dont need to cost the earth, just as well--I'm a mega-cheapskate!
Edited by Alastair
Can you post pictures?
I was being driven to despair by one case with acrylic glass - just couldn't get rid of the last bits of dust.
Then I found this device on ebay - sold as a camera sensor cleaner (a couple of £ from China).
It's basically a bit of solid silicone on a stick. You dab at the bits of dust and it doesn't leave any marks
14 hours ago, Neileg said:
I use lens wipes to clean crystals. Very convenient and better than any other fabric/liquid combination.
i've not had a problem with dust but cat hairs are a different matter!
Neil
But make sure the wipes don't contain isopropanol if it's an acrylic crystal.
Mmm...
The ones I use are for spectacles. So far as my research shows in the UK at least, all contain denatured alcohol and water.
Thanks for the heads up.
Neil
I have a box of Zeiss lens wipes next to me here - says on the back isopropanol and ethanol.
IPA causes micro cracks and makes it go misty - I discovered that the hard way.
I just looked it up, and it seems that ethyl alcohol is ok with acrylic. It just depends what the 'denatured alcohol' is.
Mike
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
