Watch of Today
mk3
Very wet weather here in Kuala Lumpur over the last week.  Since my transport to work a motorcycle I've been using my newer water resistant watches.
Today it's my Seiko 7s36-01E0, or more commonly referred to by the cognoscenti as the 'Atlas'.
Too chunky for other days but fine for Friday's.
Have a good weekend guys
Anilv
17 hours ago, ricardopalamino said:
Not sure what you mean by your statement of , "  I ruined for myself by hyping it up to much."
Clean looking watch though .
I should have explained that better. Essentially before I got it, given the history (Scandinavian, aviation, design and horological) I built it up in my mind and it got worse as I serviced it, everything in the movement just seem to be designed so well. But when I put it on my wrist it just cant live up to that impossible image. :)
Onward to a watch that did the opposite. My first impressions of the Alpinist was small and dull. But it really grew on me and the dial/handset combination plays with the light just beautifully.
Picture reflects the Swedish weather quite well, grey and cold.
12 minutes ago, digginstony said:
I've fallen for this mid-size Spinnaker. Fitted with the Seiko NH35 movement. Seeing as it's a "Keeper" I've corrected the beat errorbed7a6434d310909faaebcf335b12572.jpg2165bdc7b4874507d57c5bba376844c3.jpg4d8545fdba8a81c2af5f635007438a67.jpg
Great numbers--You've done a good job of regulating it. What does it look like Crown down as in the pic with you wearing?
J
Joe
1 minute ago, digginstony said:
Not sure. Watch taken off wrist and given the Seiko shuffle for a minute or so and then left for about 10 minutes
Right...Seiko's are fully automatic for winding. Looks good then. Amplitude would probably go up with a day or two on an automatic winder.
J
    • Back home...printing now.  Will report results
